#253274 - 03/04/2005 15:00 Empeg rebooting - clever people help please!
Major_Sarcasm
Loc: Isle of Wight, UK
Hi guys.
Can someone please advise on a problem? I installed Mark's Hijack version 419 yesterday. Put the player in the car for the drive to work this morning and got some errors, although I think this may be coincedence. Music kept pausing and an error like "hda irq timeout" or similar kept flashing on the display. I can't recall the exact error and, as you'll see below, I can't boot the player to make a note of it.
The player would recover from these errors and continue playing. Wondered if I had a HDD failing (I have 2x10GB) and so I brought the player indoors this evening to investigate via hyperterminal.
Unfortunately, since I powered up the player indoors, I've had "segfault error" flashing up for a split second being replaced with "sigkill error" whilst the player reboots continuously. I connected via hyperterminal and got the following text capture (it rebooted twice I think before I pulled the plug and killed the capture):
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v419 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Wed Mar 23 18:44:43 EST 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30102438) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x97b70
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005080).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
hdb: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:86
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: GMT
/drive0/var/ttsclock: getopts: `Option
': not a valid identifier
Saved AC volume was 90
Volume=90
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
player(31): memory violation at pc=0x02035784, lr=0x00000000 (bad address=0x022024c8, code 2)
pc : [<02035784>] lr : [<00000000>]
sp : be3ffbe4 ip : cccccccd fp : be3ffc0c
r10: 02177e48 r9 : 00000000 r8 : 02177e44
r7 : 00000002 r6 : 021518a0 r5 : 00000000 r4 : 00000000
r3 : 022024c0 r2 : 02177e44 r1 : 0000000b r0 : 02176740
Flags: Nzcv IRQs on FIQs on Mode USER_32 Segment user
Control: C0F6D17D Table: C0F6D17D DAC: 00000015
Function entered at [<02035718>] from [<020211e0>]
r10 = BE3FFD2C r9 = 00000000 r8 = 00000000 r7 = 02135800
r6 = 02135800 r5 = 02135800 r4 = 02177D78
Function entered at [<020211a8>] from [<0201fec4>]
r5 = 02177D78 r4 = 00000002
Function entered at [<0201fe38>] from [<0201f31c>]
r8 = 021357F4 r7 = 02177D78 r6 = 02170938 r5 = BE3FFC74
r4 = 02177D78
Function entered at [<0201f300>] from [<0201e588>]
r5 = 00000002 r4 = 00002D4B
Function entered at [<0201e4ec>] from [<02003f08>]
r8 = 02177BA0 r7 = BE3FFD2C r6 = 02177BA0 r5 = 00000000
r4 = BE3FFD2C
Function entered at [<02003eec>] from [<02002c78>]
Function entered at [<02002aac>] from [<020037d0>]
r10 = 02177C38 r9 = BE3FFD2C r8 = BE3FFD30 r7 = BE3FFD2C
r6 = 02177BA0 r5 = 00000000 r4 = BE3FFD2C
Function entered at [<02003574>] from [<020ad4f0>]
r10 = 020AD438 r9 = 02177BA0 r8 = 00002C0C r7 = 00000080
r6 = 0000000C r5 = 02177BA0 r4 = BE3FFD64
Function entered at [<020ad438>] from [<020b4824>]
r5 = 02177BB8 r4 = BE3FFE40
Function entered at [<020b475c>] from [<020e9bbc>]
r4 = 00000000
Function entered at [<020e8330>] from [<020b45a0>]
r8 = 02156F2C r7 = 02156F18 r6 = 020AD438 r5 = 00000007
r4 = 00000001
Function entered at [<020b44f0>] from [<020e9bbc>]
r5 = 00000000 r4 = 00000000
Function entered at [<00000020>] from [<bffffc3c>]
Function entered at [<0000fff4>] from [<00010000>]
Unable to handle kernel paging request at virtual address 0000fff8
memmap = C0F6C000, pgd = c0f6c000
*pgd = c0f74801, *pmd = c0f74801, *pte = 00000000, *ppte = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c00e3938>] lr : [<c0019910>]
sp : c087bf44 ip : c087bf00 fp : c087bf90
r10: 00000002 r9 : c0f9a0e0 r8 : 0000000c
r7 : 00000000 r6 : 0000fff4 r5 : 00010000 r4 : fffffffc
r3 : 60000013 r2 : c0104284 r1 : 00000001 r0 : ffffffec
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Process player (pid: 31, stackpage=c087b000)
Stack:
c087bf20: c0019910 c00e3938 60000013
c087bf40: ffffffff c0f9a0f8 c0f992a0 c087a000 c087bfb8 022024c8 c0011ba4 00000000
c087bf60: 022024c8 00000002 c087bfb8 00000005 022024c8 00000000 00000002 00000000
c087bf80: 02177e48 c087bfb4 c087bf94 c0012100 c0011948 c010297c 00000000 021518a0
c087bfa0: 00000002 02177e44 00000000 c087bfb8 c000a0c8 c0012028 02176740 0000000b
c087bfc0: 02177e44 022024c0 00000000 00000000 021518a0 00000002 02177e44 00000000
c087bfe0: 02177e48 be3ffc0c cccccccd be3ffbe4 00000000 02035784 80000010 ffffffff
Backtrace:
Function entered at [<c001193c>] from [<c0012100>]
r10 = 02177E48 r9 = 00000000 r8 = 00000002 r7 = 00000000
r6 = 022024C8 r5 = 00000005 r4 = C087BFB8
Function entered at [<c001201c>] from [<c000a0c8>]
r8 = 02177E44 r7 = 00000002 r6 = 021518A0 r5 = 00000000
r4 = C010297C
Code: ebfcd771 e2440010 (e5961004) e1a035a1 e59f20cc
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting playTimezone: GMT
er
Vcb: 0x4086d000
player(46): memory violation at pc=0x02035784, lr=0x00000000 (bad address=0x022024c8, code 2)
r4 = 02177D78
r4 = BE3FFD2C
r4 = 00000000
r4 = 00000001
CPU: 0
sp : c08e1f44 ip : c08e1f00 fp : c08e1f90
Process player (pid: 46, stackpage=c08e1000)
Stack:
c08e1f20: c0019910 c00e3938 60000013
c08e1f40: ffffffff c0f9a0f8 c0f994e0 c08e0000 c08e1fb8 022024c8 c0011ba4 00000000
c08e1f60: 022024c8 00000002 c08e1fb8 00000005 022024c8 00000000 00000002 00000000
c08e1f80: 02177e48 c08e1fb4 c08e1f94 c0012100 c0011948 c010297c 00000000 021518a0
c08e1fa0: 00000002 02177e44 00000000 c08e1fb8 c000a0c8 c0012028 02176740 0000000b
c08e1fc0: 02177e44 022024c0 00000000 00000000 021518a0 00000002 02177e44 00000000
c08e1fe0: 02177e48 be3ffc0c cccccccd be3ffbe4 00000000 02035784 80000010 ffffffff
Backtrace:
r6 = 022024C8 r5 = 00000005 r4 = C08E1FB8
r4 = C010297C
er
Can anyone shed light on this please? If it is just a HDD, I can replace and upload all my songs again without too much hassle as I keep a copy on my PC, but I noticed some memory errors in that text and now I'm worried.
As an aside, I reinstalled the v2.0 final developer image and Hijack 419 before getting the above capture. It had no effect on the symptoms. I should also mention that the unit had no problems like this (music pausing, etc) before today.
Thanks.
Steve
#253275 - 03/04/2005 19:40 Re: Empeg rebooting - clever people help please! [Re: Major_Sarcasm]
SonicSnoop
Loc: Triangle, VA
What version of hijack were you using before ugradeing? Have you tried going back to that and seeing if it works or does the same? Have any 3rd party software running on it? Just a couple ideas of what I would check. Im sure the real brains around here will be in shortly.
#253276 - 03/04/2005 20:00 Re: Empeg rebooting - clever people help please! [Re: Major_Sarcasm]
Your player software is crashing. Sometimes this is due to a corrupted tune.
I think the usual "fix" is to wipe the flash savearea, by manually using Control^C to kill the player, and then restarting it with the flag (??) to tell it to reset its saved settings.
But for your case, I think I'd like you to try a Hijack fix for it.. I'll release Hijack kernel v420 shortly (in a few minutes, at the link above). This version of Hijack automatically attempts to clear only the current playlist setting when the player crashes, rather than all of the player's settings. Let me know if it solves the problem or not (by posting here).
Edited by mlord (03/04/2005 20:03)
#253277 - 03/04/2005 20:15 Re: Empeg rebooting - clever people help please! [Re: mlord]
Usually the temporary fix is to start the player with no playlist as described here. That'll prevent the player app from crashing immediately, but won't solve the basic problem which is that he was getting hard disk error messages.
#253278 - 03/04/2005 21:39 Re: Empeg rebooting - clever people help please! [Re: mlord]
Major_Sarcasm
Hijack v420 has no obvious effect. It's still rebooting ad infinum with the same hijack messages flashing up.
In answer to the 1st reply, I did try initially reverting back to hijack 417, but it just rebooted with no error messages, but it did take slightly longer to reboot. I noticed that it had lost it's position and wasn't showing a current playlist just before it rebooted.
When I was getting the hda messages earlier, they were appearing on several different tracks, so I don't think it's one specific song that's causing the errors.
Steve
#253279 - 03/04/2005 21:57 Re: Empeg rebooting - clever people help please! [Re: tfabris]
Major_Sarcasm
Tony, your temporary fix of starting the player with the player -i switch worked, I have now managed to boot the empeg without the looping reboots - thanks.
Soooo. Do I have a hard disk on the way out? Is there any way to find out which one?
Steve
#253280 - 04/04/2005 00:58 Re: Empeg rebooting - clever people help please! [Re: Major_Sarcasm]
You'll not know now that you've done the "player -i".
Too bad.
#253281 - 04/04/2005 08:38 Re: Empeg rebooting - clever people help please! [Re: mlord]
Major_Sarcasm
Damn.
Mark, what did your 419/420 error messages mean? The brief flash of the "segfault error" and then the longer "sigkill error" whilst the unit was rebooting. Just after the reboot, it would flash the "segfault" again before being replaced with "sigkill".
I have now selected several playlists at random, including one that gave me a hda error yesterday, so far with no problems / errors. I will go out in the car later, as I'm off-shift, and do a more thorough test.
Steve
#253282 - 04/04/2005 11:38 Re: Empeg rebooting - clever people help please! [Re: Major_Sarcasm]
Those errors indicated the player was getting confused internally.
This could have been due to a corrupted playlist or track, or due to hard drive read errors (Faulty cable, shoddy soldering of IDE header, etc..). The hard drive errors may come and go with temperature changes, vibration, dumb luck, etc..
#253283 - 05/04/2005 07:21 Re: Empeg rebooting - clever people help please! [Re: mlord]
Major_Sarcasm
Hmm, thanks for that.
The IDE cable has been replaced, although it was a little while ago so I suppose it could be faulty again, and the soldering on my IDE header was done early last year to a reasonable standard, again I suppose it could be that, but it seems (hopefully) unlikely.
My field test yesterday yielded no unexpected results, so, a result in itself! The Empeg behaved perfectly, as it usually does. I selected a bunch of different playlists, including ones that had given me errors a couple of days ago, and no problems arose.
Hopefully whatever was troubling the unit has gone away for the moment.
Thanks for your help guys, it was much appreciated! Even if the root cause wasn't identified, I have a useable Empeg again at least for the moment.
Steve
