#254170 - 14/04/2005 02:59 No Hard Disk found Frustrations...
Dpolette
I recently purchased a second unit advertised as working, but when it was received, I ran into the "No Hard Disk Found" error. Thus I started the troubleshooting process found on the RioCar.org website. I replaced the cable and bought a new hard drive for starters to no avail. Then I used the disk builder utility when ran until it tried select the 'pump". It errored out. Then I tried to follow the Hyperterminal instructions and received the following:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg49 ([email protected]) (gcc versi
on 2.95.3 20010315 (release)) #130 Mon O
empeg-car player (hardware revision 9, serial number 10101520)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
ttyS00 at 0xf8010000 (irq = 15) is a
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005480).
empeg RDS driver initialised
empeg power-pic driver initialised (
empeg single channel IDE
Probing primary interface...
hdb: TOSHIBA MK3018GAP, ATA DISK drive
ide0: unexpected interrupt, status=0xff, count=1
hdb: TOSHIBA MK3018GAP, 28615MB w/0kB Cache, CHS=58140/16/63
empeg-flash driver initializ
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:f
0
Partition check:
hdb: unknown partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0005500).
0
Partition check:
At this point I'm totally clueless. I tried to use some of the commands in Hyperterminal but I received no response. I'm not even sure if I'm doing it correctly...no text or other cusor movement appears in the Hyperterminal window.
What am I doing wrong? I'm using the Windows NT operating system.
I believe the hard drive is not formatiting correctly? I'm clueless. Please help...
#254171 - 14/04/2005 08:11 Re: No Hard Disk found Frustrations... [Re: Dpolette]
Well, first off, you are only detecting a hard drive "b". There is no primary hard drive (hard drive "a") located in your boot log.
Is this a one disk or two disk player? If it only has one drive, check to make sure that you do not have a jumper on it to make it a slave drive. If it is a two disk system, your primary drive is not responding.
I also do not like that interrupt error near your drive check. It makes me think there might be some other problem - either a bad primary disk or a bad IDE header (since you already replaced the cable).
Also, if the builder "errored out", that is a bad sign. At best, this new drive is not partitioned. But I suspect it is more a configuration issue with a jumper or two drives conflicting.
#254172 - 15/04/2005 02:46 Re: No Hard Disk found Frustrations... [Re: pgrzelak]
Dpolette
I seem to recall a link on the BBS to an external site showing how to change in jumper setting on a Toshiba HD. I can't find it now...anyone help?
#254173 - 15/04/2005 06:06 Re: No Hard Disk found Frustrations... [Re: Dpolette]
mtempsch
page 121 of this tech pdf, at least for your MK3018GAP drive
