Long test complete. No errors:
q
Restored terminal settings
No secondary hard disk
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# cd /drive0/var/smartctl
empeg:/drive0/var/smartctl# ./smartctl -s on /dev/hda
smartctl version 5.33 [arm-empeg-linux-gnu] Copyright (C) 2002-4 Bruce Allen
Home page is
http://smartmontools.sourceforge.net/=== START OF ENABLE/DISABLE COMMANDS SECTION ===
SMART Enabled.
empeg:/drive0/var/smartctl# ./smartctl -l error /dev/hda
Home page is
http://smartmontools.sourceforge.net/=== START OF READ SMART DATA SECTION ===
SMART Error Log Version: 1
No Errors Logged
empeg:/drive0/var/smartctl# ./smartctl -t long /dev/hda
Home page is
http://smartmontools.sourceforge.net/=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-line mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 55 minutes for test to complete.
Test will complete after Sun Apr 17 20:04:32 2005
Use smartctl -X to abort test.
empeg:/drive0/var/smartctl# ./smartctl -l selftest /dev/hda
Home page is
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 4635 -
# 2 Short offline Completed without error 00% 4634 -
Home page is
No Errors Logged
empeg:/drive0/var/smartctl# exit
logout
Shell exit
Starting player
Timezone: US/Pacific
