#25500 - 24/01/2001 07:52 Tweak order: Add full album
Wire
Loc: Jylland, Denmark
Hi,
I'd like to add the full album by "double-clicking" 3 on the remote.
As it is now, I have to press 3, 3, 3, 3, 3, 3, 3, 3, 3 ... etc. until the Empeg tells me "No more matches".
Also the music stops sometimes when doing Tweak-order functions, for some reason I do not know.
Lars
Lars MkII 40gig 090000598
#25501 - 24/01/2001 15:08 Re: Tweak order: Add full album [Re: Wire]
The empeg stops playing during tweak orders sometimes as the tweaking is done in the same thread as the audio playback. This isn't the case on 1.1, where any amount of tweaking doesn't break the audio playback.
#25502 - 24/01/2001 15:16 Re: Tweak order: Add full album [Re: Wire]
jstrain
Loc: philadelphia pa
this is a pretty good idea, although i thought i remembered reading that the empeg cannot distinguish between double clicks and two clicks. this is not a big deal however, since i believe there are some unused number buttons in this context.
alternatively, depending on how you set up your playlists (my only playlists are by artists with albums as sub-playlists), you could just unshuffle the player and then rewind to the start of the album. although not as nice as one button press, you cannot do worse than pressing 3s. best case, you unshuffle on the first track of the album and have no other button presses.
jeremy
12 gig, green...
12 gig, green...
