Ok. I decided to go through all passible checks that came to my mind.
So,
1. Entered the shell by pressing q via com port, and proceeded with the file system check.
empeg:/# ro
empeg:/# umount /dev/hda4
empeg:/# umount /dev/hdc4
umount: /dev/hdc4: not found
empeg:/# swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
empeg:/# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Deleted inode 2107 has zero dtime. Fix? yes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Block bitmap differences: -11338 -11339 -11340 -11341 -11342 -11343 -11344 -11345 -11346 -11347 -11348 -11349 -11350 -11351 -11352 -11353 -11354 -11355 -11356 -11357 -11358 -11359 -11360 -11361 -11362 -11363 -11364 -11365 -11366 -11367 -11368 -11369 -11370 -11371 -11372 -11373 -11374 -11375 -11376 -11377 -11378 -11379 -11380 -11381 -11382 -11383 -11384 -11385 -11386 -11387 -11388 -11389 -11390 -11391 -11392 -11393 -11394 -11395 -11396 -11397 -11398 -11399 -11400 -11401 -11402 -11403 -11404 -11405 -11406 -11407 -11408 -11409 -11410 -11411 -11412 -11413 -11414 -11415 -11416 -11417 -11418 -11419 -11420 -11421 -11422 -11423 -11424 -11425 -11426 -11427 -11428 -11429 -11430 -11431 -11432 -11433 -11434 -11435 -11436 -11437 -11438 -11439 -11440 -11441 -11442 -11443 -11444 -11445 -11446 -11447 -11448 -11449 -11450 -11451 -11452 -11453 -11454 -11455 -11456 -11457 -11458 -11459 -11460 -11461 -11462 -11463 -11464 -11465 -11466 -11467 -11468 -11469 -11470 -11471 -11472 -11473 -11474 -11475 -11476 -11477 -11478 -11479 -11480 -11481 -11482 -11483 -11484 -11485 -11486 -11487 -11488 -11489 -11490 -11491 -11492 -11493 -11494 -11495 -11496 -11497 -11498 -11499 -11500 -11501 -11502 -11503 -11504 -11505 -11506 -11507 -11508 -11509 -11510 -11511 -11512 -11513 -11514 -11515 -11516 -11517 -11518 -11519 -11520 -11521 -11522 -11523 -11524 -11525 -11526 -11527 -11528 -11529 -11530 -11531 -11532 -11533 -11534 -11535 -11536 -11537 -11538 -11539 -11540 -11541 -11542 -11543 -11544 -11545 -11546 -11547 -11548 -11549 -11550 -11551 -11552 -11553 -11554 -11555 -11556 -11557 -11558 -11559 -11560 -11561 -11562 -11563 -11564 -11565 -11566 -11567 -11568 -11569 -11570 -11571 -11572 -11573 -11574 -11575 -11576 -11577 -11578 -11579 -11580 -11581 -11582 -11583 -11584 -11585 -11586 -11587 -11588 -11589 -11590 -11591 -11592 -11593 -11594 -11595 -11596 -11597 -11598 -11599 -11600 -11601 -11602 -11603 -11604 -11605 -11606 -11607 -11608 -11609 -11610 -11611 -11612 -11613 -11614 -11615 -11616 -11617 -11618 -11619 -11620 -11621 -11622 -11623 -11624 -11625 -11626 -11627 -11628 -11629 -11630 -11631 -11632 -11633 -11634 -11635 -11636 -11637 -11638 -11639 -11640 -11641 -11642 -11643 -11644 -11645 -11646 -11647 -11648 -11649 -11650 -11651 -11652 -11653 -11654 -11655 -11656 -11657 -11658 -11659 -11660 -11661 -11662 -11663 -11664 -11665 -11666 -11667 -11668 -11669 -11670 -11671 -11672 -11673 -11674 -11675 -11676 -11677 -11678 -11679 -11680 -11681 -11682 -11683 -11684 -11685 -11686 -11687 -11688 -11689 -11690 -11691 -11692 -11693 -11694 -11695 -11696 -11697 -11698 -11699 -11700 -11701 -11702 -11703 -11704 -11705 -11706 -11707 -11708 -11709 -11710 -11711 -11712 -11713 -11714 -11715 -11716 -11717 -11718 -11719 -11720 -11721 -11722 -11723 -11724 -11725 -11726 -11727 -11728 -11729 -11730 -11731 -11732 -11733 -11734 -11735 -11736 -11737 -11738 -11739 -11740 -11741 -11742 -11743 -11744 -11745 -11746 -11747 -11748 -11749 -11750 -11751 -11752 -11753 -11754 -11755 -11756 -11757 -11758 -11759 -11760 -11761 -11762 -11763 -11764 -11765 -11766 -11767 -11768 -11769 -11770 -11771 -11772 -11773 -11774 -11775 -11776 -11777 -11778 -11779 -11780 -11781 -11782 -11783 -11784 -11785 -11786 -11787 -11788 -11789 -11790 -11791 -11792 -11793 -11794 -11795 -11796 -11797 -11798 -11799 -11800 -11801 -11802 -11803 -11804 -11805 -11806 -11807 -11808 -11809 -11810 -11811 -11812 -11813 -11814 -11815 -11816 -11817 -11818 -11819 -11820 -11821 -11822 -11823 -11824 -11825 -11826 -11827 -11828 -11829 -11830 -11831 -11832 -11833 -11834 -11835 -11836 -11837 -11838 -11839 -11840 -11841 -11842 -11843 -11844 -11845 -11846 -11847 -11848 -11849 -11850 -11851 -11852 -11853 -11854 -11855 -11856 -11857 -11858 -11859 -11860 -11861 -11862 -11863 -11864 -11865 -11866 -11867 -11868 -11869 -11870 -11871 -11872 -11873 -11874 -11875 -11876 -11877 -11878 -11879 -11880 -11881 -11882 -11883 -11884 -11885 -11886 -11887 -11888 -11889 -11890 -11891 -11892 -11893 -11894 -11895 -11896 -11897 -11898 -11899 -11900 -11901 -11902 -11903 -11904 -11905 -11906 -11907 -11908 -11909 -11910 -11911 -11912 -11913 -11914 -11915 -11916 -11917 -11918 -11919 -11920 -11921 -11922 -11923 -11924 -11925 -11926 -11927 -11928 -11929 -11930 -11931 -11932 -11933 -11934 -11935 -11936 -11937 -11938 -11939 -11940 -11941 -11942 -11943 -11944 -11945 -11946 -11947 -11948 -11949 -11950 -11951 -11952 -11953 -11954 -11955 -11956 -11957 -11958 -11959 -11960 -11961 -11962 -11963 -11964 -11965 -11966 -11967 -11968 -11969 -11970 -11971 -11972 -11973 -11974 -11975 -11976 -11977 -11978 -11979 -11980 -11981 -11982 -11983 -11984 -11985 -11986 -11987 -11988 -11989 -11990 -11991 -11992 -11993 -11994 -11995 -11996 -11997 -11998 -11999 -12000 -12001 -12002 -12003 -12004 -12005 -12006 -12007 -12008 -12009 -12010 -12011 -12012 -12013 -12014 -12015 -12016 -12017 -12018 -12019 -12020 -12021 -12022 -12023 -12024 -12025 -12026 -12027 -12028 -12029 -12030 -12031 -12032 -12033 -12034 -12035 -12036 -12037 -12038 -12039 -12040 -12041 -12042 -12043 -12044 -12045 -12046 -12047 -12048 -12049 -12050 -12051 -12052 -12053 -12054 -12055 -12056 -12057 -12058 -12059 -12060 -12061 -12062 -12063 -12064 -12065 -12066 -12067 -12068 -12069 -12070 -12071 -12072 -12073 -12074 -12075 -12076 -12077 -12078 -12079 -12080 -12081 -12082 -12083 -12084 -12085 -12086 -12087 -12088 -12089 -12090 -12091 -12092 -12093 -12094 -12095 -12096 -12097 -12098 -12099 -12100 -12101 -12102 -12103 -12104 -12105 -12106 -12107 -12108 -12109 -12110 -12111 -12112 -12113 -12114 -12115 -12116 -12117 -12118 -12119 -12120 -12121 -12122 -12123 -12124 -12125 -12126 -12127 -12128 -12129 -12130 -12131 -12132 -12133 -12134 -12135 -12136 -12137 -12138 -12139 -12140 -12141 -12142 -12143 -12144 -12145 -12146 -12147 -12148 -12149 -12150 -12151 -12152 -12153 -12154 -12155 -12156 -12157 -12158 -12159 -12160 -12161 -12162 -12163 -12164 -12165 -12166 -12167 -12168 -12169 -12170 -12171 -12172 -12173 -12174 -12175 -12176 -12177 -12178 -12179 -12180 -12181 -12182 -12183 -12184 -12185 -12186 -12187 -12188 -12189 -12190 -12191 -12192 -12193 -12194 -12195 -12196 -12197 -12198 -12199 -12200 -12201 -12202 -12203 -12204 -12205 -12206 -12207 -12208 -12209 -12210 -12211 -12212 -12213 -12214 -12215 -12216 -12217 -12218 -12219 -12220 -12221 -12222 -12223 -12224 -12225 -12226 -12227 -12228 -12229 -12230 -12231 -12232 -12233 -12234 -12235 -12236 -12237 -12238 -12239 -12240 -12241 -12242 -12243 -12244 -12245 -12246 -12247 -12248 -12249 -12250 -12251 -12252 -12253 -12254 -12255 -12256 -12257 -12258 -12259 -12260 -12261 -12262 -12263 -12264 -12265 -12266 -12267 -12268 -12269 -12270 -12271 -12272 -12273 -12274 -12275 -12276 -12277 -12278 -12279 -12280 -12281 -12282 -12283 -12284 -12285 -12286 -12287 -12288 -12289 -12290 -12291 -12292 -12293 -12294 -12295 -12296 -12297 -12298 -12299 -12300 -12301 -12302 -12303 -12304 -12305 -12306 -12307 -12308 -12309 -12310 -12311 -12312 -12313 -12314 -12315 -12316 -12317 -12318 -12319 -12320 -12321 -12322 -12323 -12324 -12325 -12326 -12327 -12328 -12329 -12330 -12331 -12332 -12333 -12334 -12335 -12336 -12337 -12338 -12339 -12340 -12341 -12342 -12343 -12344 -12345 -12346 -12347 -12348 -12349 -12350 -12351 -12352 -12353 -12354 -12355 -12356 -12357 -12358 -12359 -12360 -12361 -12362 -12363 -12364 -12365 -12366 -12367 -12368 -12369 -12370 -12371 -12372 -12373 -12374 -12375 -12376 -12377 -12378 -12379 -12380 -12381 -12382 -12383 -12384 -12385 -12386 -12387 -12388 -12389 -12390 -12391 -12392 -12393 -12394 -12395 -12396 -12397 -12398 -12399 -12400 -12401 -12402 -12403 -12404 -12405 -12406 -12407 -12408 -12409 -12410 -12411 -12412 -12413 -12414 -12415 -12416 -12417 -12418 -12419 -12420 -12421 -12422 -12423 -12424 -12425 -12426 -12427 -12428 -12429 -12430 -12431 -12432 -12433 -12434 -12435 -12436 -12437 -12438 -12439 -12440 -12441 -12442 -12443 -12444 -12445 -12446 -12447 -12448 -12449 -12450 -12451 -12452 -12453 -12454 -12455 -12456 -12457 -12458 -12459 -12460 -12461 -12462 -12463 -12464 -12465 -12466 -12467 -12468 -12469 -12470 -12471 -12472 -12473 -12474 -12475 -12476 -12477 -12478 -12479 -12480 -12481 -12482 -12483 -12484 -12485 -12486 -12487 -12488 -12489 -12490 -12491 -12492 -12493 -12494 -12495 -12496 -12497 -12498 -12499 -12500 -12501 -12502 -12503 -12504 -12505 -12506 -12507 -12508 -12509 -12510 -12511 -12512 -12513 -12514 -12515 -12516 -12517 -12518 -12519 -12520 -12521 -12522 -12523 -12524 -12525 -12526 -12527 -12528 -12529 -12530 -12531 -12532 -12533 -12534 -12535 -12536 -12537 -12538 -12539 -12540 -12541 -12542 -12543 -12544 -12545 -12546 -12547 -12548 -12549 -12550 -12551 -12552 -12553 -12554 -12555 -12556 -12557 -12558 -12559 -12560 -12561 -12562 -12563 -12564 -12565 -12566 -12567 -12568 -12569 -12570 -12571 -12572 -12573 -12574 -12575 -12576 -12577 -12578 -12579 -12580 -12581 -12582 -12583 -12584 -12585 -12586 -12587 -12588 -12589 -12590 -12591 -12592 -12593 -12594 -12595 -12596 -12597 -12598 -12599 -12600 -12601 -12602 -12603 -12604 -12605 -12606 -12607 -12608 -12609 -12610 -12611 -12612 -12613 -12614 -12615 -12616 -12617 -12618 -12619 -12620 -12621 -12622 -12623 -12624 -12625 -12626 -12627 -12628 -12629 -12630 -12631 -12632 -12633 -12634 -12635 -12636 -12637 -12638 -12639 -12640 -12641 -12642 -12643 -12644 -12645 -12646 -12647 -12648 -12649 -12650 -12651 -12652 -12653 -12654 -12655 -12656 -12657 -12658 -12659 -12660 -12661 -12662 -12663 -12664 -12665 -12666 -12667 -12668 -12669 -12670 -12671 -12672 -12673 -12674 -12675 -12676 -12677 -12678 -12679 -12680 -12681 -12682 -12683 -12684 -12685 -12686 -12687 -12688 -12689 -12690 -12691 -12692 -12693 -12694 -12695 -12696 -12697 -12698 -12699 -12700 -12701 -12702 -12703 -12704 -12705 -12706 -12707 -12708 -12709 -12710 -12711 -12712 -12713 -12714 -12715 -12716 -12717 -12718 -12719 -12720 -12721 -12722 -12723 -12724 -12725 -12726 -12727 -12728 -12729 -12730 -12731 -12732 -12733 -12734 -12735 -12736 -12737 -12738 -12739 -12740 -12741 -12742 -12743 -12744 -12745 -12746 -12747 -12748 -12749 -12750 -12751 -12752 -12753 -12754 -12755 -12756 -12757 -12758 -12759 -12760 -12761 -12762 -12763 -12764 -12765 -12766 -12767 -12768 -12769 -12770 -12771 -12772 -12773 -12774 -12775 -12776 -12777 -12778 -12779 -12780 -12781 -12782 -12783 -12784 -12785 -12786 -12787 -12788 -12789 -12790 -12791 -12792 -12793 -12794 -12795 -12796 -12797 -12798 -12799 -12800 -12801 -12802 -12803 -12804 -12805 -12806 -12807 -12808 -12809 -12810 -12811 -12812 -12813 -12814 -12815 -12816 -12817 -12818 -12819 -12820 -12821 -12822 -12823 -12824 -12825 -12826 -12827 -12828 -12829 -12830 -12831 -12832 -12833 -12834 -12835 -12836 -12837 -12838 -12839 -12840 -12841 -12842 -12843 -12844 -12845 -12846 -12847 -12848 -12849 -12850 -12851 -12852 -12853 -12854 -12855 -12856 -12857 -12858 -12859 -12860 -12861 -12862 -12863 -12864 -12865 -12866 -12867 -12868 -12869 -12870 -12871 -12872 -12873 -12874 -12875 -12876 -12877 -12878 -12879 -12880 -12881 -12882 -12883 -12884 -12885 -12886 -12887 -12888 -12889 -12890 -12891 -12892 -12893 -12894 -12895 -12896 -12897 -12898 -12899 -12900 -12901 -12902 -12903 -12904 -12905 -12906 -12907 -12908 -12909 -12910 -12911 -12912 -12913 -12914 -12915 -12916 -12917 -12918 -12919 -12920 -12921 -12922 -12923 -12924 -12925 -12926 -12927 -12928 -12929 -12930 -12931 -12932 -12933 -12934 -12935 -12936 -12937 -12938 -12939 -12940 -12941 -12942 -12943 -12944 -12945 -12946 -12947 -12948 -12949 -12950 -12951 -12952 -12953 -12954 -12955 -12956 -12957 -12958 -12959 -12960 -12961 -12962 -12963 -12964 -12965 -12966 -12967 -12968 -12969 -12970 -12971 -12972 -12973 -12974 -12975 -12976 -12977 -12978 -12979 -12980 -12981 -12982 -12983 -12984 -12985 -12986 -12987 -12988 -12989 -12990 -12991 -12992 -12993 -12994 -12995 -12996 -12997 -12998 -12999 -13000 -13001 -13002 -13003 -13004 -13005 -13006 -13007 -13008 -13009 -13010 -13011 -13012 -13013 -13014 -13015 -13016 -13017 -13018 -13019 -13020 -13021 -13022 -13023 -13024 -13025 -13026 -13027 -13028 -13029 -13030 -13031 -13032 -13033 -13034 -13035 -13036 -13037 -13038 -13039 -13040 -13041 -13042 -13043 -13044 -13045 -13046 -13047 -13048 -13049 -13050 -13051 -13052 -13053 -13054 -13055 -13056 -13057 -13058 -13059 -13060 -13061 -13062 -13063 -13064 -13065 -13066 -13067 -13068 -13069 -13070 -13071 -13072 -13073 -13074 -13075 -13076 -13077 -13078 -13079 -13080 -13081 -13082 -13083 -13084 -13085 -13086 -13087 -13088 -13089 -13090 -13091 -13092 -13093 -13094 -13095 -13096 -13097 -13098 -13099 -13100 -13101 -13102 -13103 -13104 -13105 -13106 -13107 -13108 -13109 -13110 -13111 -13112 -13113 -13114 -13115 -13116 -13117 -13118 -13119 -13120 -13121 -13122 -13123 -13124 -13125 -13126 -13127 -13128 -13129 -13130 -13131 -13132 -13133 -13134 -13135 -13136 -13137 -13138 -13139 -13140 -13141 -13142 -13143 -13144 -13145 -13146 -13147 -13148 -13149 -13150 -13151 -13152 -13153 -13154 -13155 -13156 -13157 -13158 -13159 -13160 -13161 -13162 -13163 -13164 -13165 -13166 -13167 -13168 -13169 -13170 -13171 -13172 -13173 -13174 -13175 -13176 -13177 -13178 -13179 -13180 -13181 -13182 -13183 -13184 -13185 -13186 -13187 -13188 -13189 -13190 -13191 -13192 -13193 -13194 -13195 -13196 -13197 -13198 -13199 -13200 -13201 -13202 -13203 -13204 -13205 -13206 -13207 -13208 -13209 -13210 -13211 -13212 -13213 -13214 -13215 -13216 -13217 3218 -13219 -13220 -13221
Fix? yes
Free blocks count wrong for group #1 (0, counted=1884).
Fix? yes
Free blocks count wrong (4498, counted=6382).
Fix? yes
Inode bitmap differences: -2107
Fix? yes
Free inodes count wrong for group #1 (1274, counted=1275).
Fix? yes
Free inodes count wrong (2582, counted=2583).
Fix? yes
/dev/hda5: ***** FILE SYSTEM WAS MODIFIED *****
/dev/hda5: 1513/4096 files (0.5% non-contiguous), 10002/16384 blocks
empeg:/# fsck -fay /dev/hda4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
/dev/hda4: 18576/762368 files (13.3% non-contiguous), 59562302/97578810 blocks
empeg:/#
empeg:/# fsck -fay /dev/hdc4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdc4 is mounted.
fsck.ext2: Device not configured while trying to open /dev/hdc4
Possibly non-existent or swap device?
empeg:/# swapoff /swapfile
empeg:/# sync
empeg:/#
__________________________________________
Unplugged the empeg, and reapplied power. The player rebuilt the database. Here's the output on the com port:
___________________________________________
empeg-car bootstrap v1.02 20001106 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v431 (
[email protected]) (gcc version 2.95.3 20010315 (release)) #2 Tue May 24 19:50:51 EDT 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 40103216) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x98b7c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004c00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHU2100AT, ATA DISK drive
hda: FUJITSU MHU2100AT, 95396MB w/8192kB Cache, CHS=12161/255/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0c:90
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Comply.þStarting player
Timezone: MET
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Using non-standard cache size 90 (adjustment 10)
player.cpp : 564:empeg-car 3.00-alpha7 2004/02/13.
! tags.cpp : 61:Failed to open tags (0xc0041002).
q
q
^A
Prolux 4 empeg car - 2.1490 Feb 13 2004
Vcb: 0x40693000
Since I could not get to the shell by pressing q, I pressed Q in the player:
player(19): user memory violation at pc=0x00000000, lr=0x020c76e8 (bad address=0x00000000, code 2)
pc : [<00000000>] lr : [<020c76e8>]
sp : be9ffc70 ip : 02195080 fp : be9ffc84
r10: 00000000 r9 : be9ffca8 r8 : 405d36cc
r7 : c004100e r6 : be9ffca8 r5 : 405d3568 r4 : be9ffcb4
r3 : 405d37fc r2 : 0000000c r1 : be9ffc70 r0 : 405d37fc
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0F3D17D Table: C0F3D17D DAC: 00000015
Function entered at [<020c7698>] from [<02017d3c>]
r4 = 00000000
Function entered at [<02017a00>] from [<020e68d8>]
r10 = 020E6804 r9 = 405D35BC r8 = 00002009 r7 = 00000080
r6 = 00000009 r5 = BE9FFD38 r4 = 405D35BC
Function entered at [<020e68a0>] from [<020bdbfc>]
r5 = 021D85A0 r4 = 405D3568
Function entered at [<020bdbd0>] from [<020e6890>]
r4 = 405D35BC
Function entered at [<020e6804>] from [<021208f8>]
r5 = 405D35D4 r4 = BE9FFE40
Function entered at [<02120830>] from [<021571cc>]
r4 = 00000000
Function entered at [<02155940>] from [<02120674>]
r8 = 021E70A4 r7 = 021E7090 r6 = 020E6804 r5 = 00000005
r4 = 00000001
Function entered at [<021205c4>] from [<021571cc>]
r5 = 00000000 r4 = 00000000
Function entered at [<fffffff4>] from [<bffffbc0>]
Function entered at [<0220a13c>] from [<00000019>]
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
Timezone: MET
Player received SIGINT, user interruption
Starting bash.
Here I decided to proceed with
fsck.ext2 -fay -b 32768 /dev/hda4
which I read about in the FAQ.
empeg:/empeg/bin#
empeg:/empeg/bin#
empeg:/empeg/bin# ro
empeg:/empeg/bin# rom
empeg:/empeg/bin# fsck.ext2 -fay -b 32768 /dev/hda4
fsck.ext2: Bad magic number in super-block while trying to open /dev/hda4
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
empeg:/empeg/bin#
Recycled power, and it rebuilt the database again.
I started Jemplode. It rebouilt the database. Then it complained I had no fid n. 2.
I could then upload a number of tunes without any problem. However, from the serial port output, I got this:
_____________
ksock_rw(recv): error: -32
kftpd: ksock_rw() failed, rc=-32
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc0d0
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc0f0
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc100
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc110
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc120
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc130
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc140
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc150
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc160
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc170
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc180
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc190
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc1a0
! playlist_common.cpp: 773:Failed to get FID info for FID 0xc1b0
Restarting system.
___________________
Still, on the UI of jemplode all seemed ok.
Then, I tried to uploade more tunes, and the first playlist stopped at 20%, as I coul read in jemplode. Now, it is there, sopped. I am trying to wait until I get some error. I will have to go through the entire file system check again. I think there is some problem with alpha7/ethernet.... I don't think it is cabling, since this happened with different cables in different locations.
