#256990 - 26/05/2005 13:25 Empeg repair: Is anyone doing it now?
Flawed
Dare I ask if anyone is doing empeg repairs now? I've corresponded with Rob many many months ago about getting either one or both of my 2 busted empegs fixed but he hasn't replied back to me in well over 3 months. I'm tired of burning cd's. I know that he was taking some time off and was supposed to be getting back to it at the end of April. It's a month past that and I'm just curious if anyone has heard from him or knows if he's currently working on requests. If not, I think I should just sell these things as they currently do me no good and I could likley find another solution.
Thanks!
#256991 - 26/05/2005 13:31 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
robricc
I don't know if Rob is starting-up repair service again. Eutronix in the US should be able to help. Mark Lord may be able to help if you're in Canada. I don't know if he's fixing empegs anymore either though.
#256992 - 26/05/2005 13:32 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
RobS is the best choice for Empeg repair -- he has access to schematics, original replacement parts, and by far has the most experience of anyone (current) repairing these beasts.
Stu/Eutronix (link at top) also dabbles, and can fix common problems. But troubleshooting capabilities appear limited, due to no schematics and the need to recoup time spent diagnosing things.
I also repair empegs, but encourage people to go elsewhere first, and treat me as the option of final resort. I can diagnose/fix nearly anything, even without schematics. But shipping things to me in Canada can be pricey at the border.
#256993 - 26/05/2005 13:44 Re: Empeg repair: Is anyone doing it now? [Re: mlord]
Flawed
Well stuart had one of them once to replace the CS4231A chip but was unable to get it working again. He didn't charge me anything despite having invested several hours in it. Honestly, I'm just frustrated and want to get something working. I have pictures of the boards somewhere and boot logs too I think. And shipping to Canada can't be 1/2 as bad as going to the netherlands! Rob seemed to think the ide headers and the CS4231A chips were hosed. I'll see if I can dredge up his last email about it.
Edited by Flawed (26/05/2005 13:46)
#256994 - 26/05/2005 13:49 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
robricc
If you and Mark work something out, I will be crossing the border in two weeks. I can mail it to Mark for you from within Canada.
#256995 - 26/05/2005 13:53 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
All such things begin at the same place.. post a boot log here.
#256996 - 26/05/2005 14:59 Re: Empeg repair: Is anyone doing it now? [Re: mlord]
Flawed
Boot log of the first unit. This is my main one and was sent back to Rob for repair shortly after I got it due to intermittent Disk Not Found errors.
I'll also upload some pics of both units and link to them in a few minutes. This unit is 1st empeg.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v394 ([email protected]) (gcc version 2.
95.3 20010315 (release)) #2 Fri Jun 4 16:34:01 EDT 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30102325) 16MB DRAM
Command line: mem=16m
Memory: 15016k/16M available (980k code, 20k reserved, 364k da
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
SA1100 serial driver version 4.27 with no serial options ena
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9a38c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0005300).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: ÉC²5Ô0´8ÁTÄA°5­0 , ATA DISK drive
hdb: ÉC²5Ô0´8ÁTÄA°5­0 , ATA DISK drive
hda: ÉC²5Ô0´8ÁTÄA°5­0 , 24191MB w/18190kB Cache, CHS=49151
/16/63
hdb: ÉC²5Ô0´8ÁTÄA°5­0 , 24191MB w/18190kB Cache, CHS=49151
/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:1
5
Partition check:
hda: [PTBL] [3083/255/63] hda1 < > hda2 hda3 hda4
hdb: [PTBL] [3083/255/63] hdb1 < > hdb2 hdb3 hdb4
Timezone: /usr/share/zoneinfo
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
#256997 - 26/05/2005 15:04 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
Flawed
Here's teh second log file. This one is the one that Stuart tried to replace the chip on. Well, he did really but it still doesn't work. This one is a spare unit.
e000 v1.04
Copying kern
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #17 Wed Jul 24 18:23:20 BST 2002
empeg-car player (hardware revision 9, serial number 10101594)
Memory: 15024k/16M available (964k code, 2
Signature is 206f6972 'rio '
i2c: Failed to receive ACK for data!
i2c_write: device select failed
I2C write failed (fff, d223)
I2C write failed (927, 0)
I2C write failed (8f9, 90d)
I2C write failed (8ef, 800)
empeg dsp mixer in
Could not find CS4231A (version=81)
empeg state support initialised 0089/88c1 (save to d0005400).
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:3
a
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
#256998 - 26/05/2005 15:11 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
Flawed
#256999 - 26/05/2005 20:21 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
Excellent! A model case of how to provide exactly the right information!
But it does look a little ugly. There are definitely "lifted pads" on the IDE header of unit#1 -- a result of the crooked factory solder job, short IDE cables, and possibly a bit much heat from the soldering iron later on. I can fix that.
Dunno about the CS4231A on unit#1 -- it's failing right now, but since it shares the bus with the bad IDE header, anything is possible. But the USB & ethernet also share that bus, and they look okay in the logs. Won't know until the header is fixed up.
The one thing I cannot do is replace large surface mount chips like the CS4231A. I can diagnose them, but lack the steady hand to swap them out for new ones.
Unit#2 looks like it may have three bad pads on the CS4231A -- a couple of them are definitely lifted, and I cannot tell about the third. This I can fix, but whether anything else is wrong, well.. fix what we know about first, and then see what else is still failing.
I suggest you take robricc up on his transport offer, and let him remail them to me on the North side of the border. Getting stuff back to you is easy, it's only the incoming direction that's tricky here.
There are a couple of ways we could tackle this.. I basically only fix units when I have time and feel like it -- that way the job is done well, but timing then becomes quite unpredictable.
One way is I can offer you one good working Mk2a in trade for the two duds. You keep your drives, I keep my drive. Then someday I might fix one or both of the dead units, at my own risk.
Or I could diagnose/fix them as best I can, and you pay whatever we agree upon for a fee once that happens. Normally I charge around US$100 for attempting severe repairs, or more if it takes an inordinate amount of effort.
On the plus side, those are NOT the worst units I've seen (and fixed) to date. But they're up there.
Edited by mlord (26/05/2005 20:23)
#257000 - 26/05/2005 23:24 Re: Empeg repair: Is anyone doing it now? [Re: mlord]
Ladmo
Loc: Oklahoma
I think I may hold the record for having the worst unit...We'd have to ask Rob S. as he has had the unit for months now, and is still tweaking on it...Of course, since I had a backup machine, I told him to take his time, as repairs to single machine owners would come first (gotta have the tunes, man!
All in all, if Rob can fix the unit without me having to take out a second mortage, he'd be my hero!
#257001 - 27/05/2005 16:11 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
schofiel
Hi. I'm here. I am still doing repairs.
I have a new job and finally have a flat, rather than a hotel, which means it will be possible to do repair work again. I have already brought over a large amount of spares and my tools, so I will be posting when I am ready to go again. Watch this space!
#257002 - 27/05/2005 16:15 Re: Empeg repair: Is anyone doing it now? [Re: schofiel]
schofiel
One possibility: to save on costs, you could pass the units to someone visiting the empeg User meet in a few weeks time. You need to get organising immediately.
I now have access to a microscope and a QFP chip removal kit, plus I have a fair number of CS4231A chips.
Don't loose heart, Charles! What happened to cbarbour?
#257003 - 27/05/2005 16:51 Re: Empeg repair: Is anyone doing it now? [Re: schofiel]
Flawed
cbarbour still works. I just switched to the more common way of reaching me. cbarbour is my work email.
Guess I need to figure out how I want to proceed now. Any idea if you could give me a realistic idea of when you can repair my units? Don't worry about trying to make me happy, just let me know how long you think it will be before you can really get to them.
That will help me determine which way to go.
Thanks! Glad to hear things are smoothing out for you too...
#257004 - 27/05/2005 20:29 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
robricc
I'm going to the meet in the Netherlands. I can take it there too if you would like.
#257005 - 27/05/2005 20:34 Re: Empeg repair: Is anyone doing it now? [Re: robricc]
Say Rob.. when are you going to be in Montreal next? I'll be there (down the road 2 hours from here) on June 15 for a VMware seminar -- attendies get a free license, so I figured "why not!".
#257006 - 27/05/2005 20:40 Re: Empeg repair: Is anyone doing it now? [Re: mlord]
robricc
I'll be there the weekend of the 11th for the Montreal Grand Prix. I'm not so into F1, but I'll probably have a good time. There's also casino gaming around, so that always makes a trip better...
#257007 - 28/05/2005 11:44 Re: Empeg repair: Is anyone doing it now? [Re: schofiel]
Ladmo
Loc: Oklahoma
Rob,
Would that work in reverse? If you have a machine ready, would you give it to someone to bring back to the states and mail from the states to the states? Would that save any significant money? Assuming your bill was paid, of course!
Just wondering.
#257008 - 29/05/2005 19:29 Re: Empeg repair: Is anyone doing it now? [Re: Ladmo]
This fall, make sure to tune in to WMPG's hottest new reality show, Rob Riccardelli: Mule.
#257009 - 29/05/2005 23:07 Re: Empeg repair: Is anyone doing it now? [Re: wfaulk]
Oh, don't be cruel, his ears aren't that big
#257010 - 31/05/2005 12:41 Re: Empeg repair: Is anyone doing it now? [Re: schofiel]
Flawed
So Rob, do you have an estimate for me on how long you think it would take you to repair it?
#257011 - 31/05/2005 18:31 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
schofiel
The amount of time it takes to do repair work I won't estimate: I simply proceed carefully to do the repair properly and tot up the time. I appreciate that there is the risk that this could turn into a huge bill - but I don't allow this to happen, by various means. The idea is to get the unit repaired, not bankrupt the owner.
As to when I can look at the unit: I originally said that I would be able to start work again at the start of April. For various reasons (some of which will come clear in the next month or so) this has been delayed. I have all the repairs I was working on in January here with me with all my spares and tools, and "sometime soon" I will post here to let people know what's happening.
So have a little more patience, don't give up hope and - above all - don't even think about binning your beastie: I havn't been beaten by one of these yet
#257012 - 31/05/2005 19:57 Re: Empeg repair: Is anyone doing it now? [Re: schofiel]
Thanks for the update Rob. I was beginning to worry that mine was a lost cause too. I'll wait a little longer.
#257013 - 01/06/2005 17:36 Re: Empeg repair: Is anyone doing it now? [Re: schofiel]
Flawed
I phased that poorly. I meant to ask when you would be able to start looking at the units. Not a completion date. I'm just curious if it's going to be something you could start on relatively quickly or if it would take you 2 months to even begin to look at it. Does that clarify my question a bit?
Thanks!
#257014 - 19/08/2005 12:18 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
Flawed
I'm going to bump this up to the top again. I just sent Rob an email but if he doesn't get around to replying, perhaps this will help elicit a response. If not, I think I'll see if Mark would still be interested in repairing or swapping them.
#257015 - 20/08/2005 11:01 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
Ladmo
Loc: Oklahoma
Just so you know, I have recently asked ML if he could do a 'header job' on my back up player, and he said he was too busy. But he may mean just too busy for mine. He may have time for yours...If not you may want to try Stu if you are not too concerned about the cost.
#257016 - 20/08/2005 12:00 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
Yes, I'm a bit backlogged in the repair department right now (and my own custom home dock just now stopped functioning -- likely the internal power supply died -- so that also now wants my attention.
I can still offer the two-bad-ones for one-good-one (no drives in any) immediate exchange, though.
#257017 - 23/08/2005 18:10 Re: Empeg repair: Is anyone doing it now? [Re: mlord]
Flawed
Well screw it. I'm tired of having a hole in my dash and people asking me if I got ripped off. I'll take you up on your offer Mark. I'll shoot you mail in a bit.
Thanks!
#257018 - 25/08/2005 10:21 Re: Empeg repair: Is anyone doing it now? [Re: Flawed]
Someone apparently posted then deleted a message and I'm tired of seeing this thread marked as unread. Thus this post.
