#259713 - 04/07/2005 02:46 Playlists missing/shuffled/etc
Narkotic
I have a Mark2a 60gb empeg. It has two 30gb Fujitsu (original) drives in it. I am at about 45gb at this point w/ music. The other day, I went to add another album to it, I went in my room for a bit and came out to see Emplode crashed. My player was playing but there were no playlists. I tried to sync a few times w/ emplode but it would crash each time it finished reading from the player. I gave up for the day.
The next day, I decided to try it again. This time, emplode didn't crash, and it started to add all my playlists very quickly into the player, and started to do the rest of the synchronise process. After it finished, emplode crashed and alas, I had no playlists.
I then proceeded to follow the FAQ entry to delete the databases/playlists/tags to let it rebuild. It seemed to have worked, I had playlists once again; however they are all over the place, with alot of them empty/missing entries. I've tried to rebuild about 3 times and get the same exact results each time.
Prior to this, about a week or so ago, one of the drives started clicking and then the player would say no harddisk found. I flicked the drives w/ my finger and it started back up. I'm thinking these old drives are starting to bite the dust. I'm having no errors upon bootup, it finds both drives and goes right into the player software.
Is there any way to get back to where I was? Or is this it... It's so bad i'm going to have to reload everything i'm thinking. This might be a good time to get a single 100gb drive and start over.
Thanks! (good job on the FAQ tony, it's saved me a few times)
#259714 - 04/07/2005 10:26 Re: Playlists missing/shuffled/etc [Re: Narkotic]
Boot log, please.
#259715 - 04/07/2005 15:49 Re: Playlists missing/shuffled/etc [Re: Narkotic]
Your described behavior resembles something that happened to me when I was trying out one of the V3 Alpha builds. Are you running 2.0 final or V3 alpha?
Probably a moot point, though, because you've got hard disk trouble. In terms of the unit keeping its playlist data, very little can be counted on once you've started having disk trouble. Sure you could reload everything, but if you're having disk trouble the problems would just come back.
As Mark said, a boot log would be very helpful.
#259716 - 04/07/2005 16:14 Re: Playlists missing/shuffled/etc [Re: mlord]
Narkotic
Bootlog: (w/ hijack ir translate errors i've been too lazy to fix)
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v345 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Thu Oct 16 17:41:00 EDT 2003
Processor: Intel StrongARM-1100 revis
empeg-car player (hardware revision 9, serial number 40103852)
Command line: mem=16m
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9c388
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005300).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:0
c
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
[hijack] ERROR: "80B800CE=20DF10"
[hijack] ERROR: "80B800CF=20DF11"
[hijack] ERROR: "80B800C9=20DF16"
[hijack] ERROR: "80B80006=20DF0C"
[hijack] ERROR: "80B800CB=20DF12"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
#259717 - 04/07/2005 23:37 Re: Playlists missing/shuffled/etc [Re: Narkotic]
Mmm.. thanks.
I had thought that perhaps one of the two drives might be misbehaving, but the boot log shows no problems there. And you are running v2.00 software, so that part is also fine.
Odds are good that you're going to have to reupload it all..
Unless Tony has any other ideas.
#259718 - 05/07/2005 03:55 Re: Playlists missing/shuffled/etc [Re: mlord]
StigOE
Maybe try the smartctl to see if the drives themselves have something to report?
Stig
#259719 - 05/07/2005 04:15 Re: Playlists missing/shuffled/etc [Re: StigOE]
Narkotic
Could you elaborate please?
#259720 - 05/07/2005 05:06 Re: Playlists missing/shuffled/etc [Re: Narkotic]
StigOE
Read this and possibly this for getting and using smartctl.
[Edit] And here is the inevitable FAQ entry...[/Edit]
Stig
Edited by StigOE (05/07/2005 05:10)
