#259746 - 05/07/2005 10:08 Building music database - FAQ doesn't help
fairlight
Loc: Duisburg, NRW, Germany
Hello,
I just upgraded my empeg with a bigger second harddisk; everything is working perfect - exception to the "building music database" everytime I boot the player. The harddisks are ok, the filesystem too (fsck didn't report any error). I just had a look in the FAQ, where is mentioned that I have to delete several database-files in /drive(0|1)/var. But there aren't any files!? Any idea what's going wrong with my empeg? I have installed the 2.00 dev-image with the newest hijack-version.
Thanks,
Falk Brockerhoff
#259747 - 05/07/2005 10:10 Re: Building music database - FAQ doesn't help [Re: fairlight]
I suspect a boot log is going to be useful.
#259748 - 05/07/2005 10:16 Re: Building music database - FAQ doesn't help [Re: fairlight]
What size? Did you follow the Drive Upgrade Guide to the letter?
As Andy says, we'll need to see a serial log showing the bootup sequence, before we can diagnose further.
#259749 - 05/07/2005 15:02 Re: Building music database - FAQ doesn't help [Re: Roger]
fairlight
Hello,
yes, I followed the "Upgrade Drive"-Howto and mounted a 30Gig and a 40Gig drive - there is no data I want to "take over" from the old 10Gig harddisk.
Here's the serial output:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v435 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Sun Jun 26 17:59:37 EDT 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 10101928) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004c80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N030ATCS04-0, ATA DISK drive
hdb: ST94019A, ATA DISK drive
hda: IC25N030ATCS04-0, 28615MB w/1768kB Cache, CHS=58140/16/63
hdb: ST94019A, 38154MB w/2048kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:88
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... ԕ'Sѕ۽с*Ɂ2ѕ)jchange_root: old root has d_count=1
Mounting proc
Starting player
Timezone: Europe/Berlin
! tags.cpp : 61:Failed to open tags (0xc0041002).
Edited by fairlight (05/07/2005 15:14)
#259750 - 05/07/2005 15:42 Re: Building music database - FAQ doesn't help [Re: fairlight]
I would go ahead with that FAQ entry and skip the lines deleting the old files. The method should regenerate the database for you.
#259751 - 05/07/2005 15:48 Re: Building music database - FAQ doesn't help [Re: pgrzelak]
I'd do the deletion lines anyway in case the files were there and you just didn't happen to see them because you typed the LS command wrong or something. Worst that could happen is it says file not found.
#259752 - 05/07/2005 15:53 Re: Building music database - FAQ doesn't help [Re: pgrzelak]
fairlight
Hello,
this works. I already read this FAQ-entry, but was too confused finding noting in /drive(0|1)/var, so that I didn't finished the steps *selfslap
Thank you!
Falk
#259753 - 05/07/2005 16:09 Re: Building music database - FAQ doesn't help [Re: fairlight]
Updating FAQ entry to say some or all of the deletions might not work.
#259754 - 06/07/2005 00:21 Re: Building music database - FAQ doesn't help [Re: fairlight]
self
*selfslap
OWWWWWW
#259755 - 06/07/2005 08:28 Re: Building music database - FAQ doesn't help [Re: self]
Very good...
