#259868 - 06/07/2005 19:09
OSX, MS Intelimouse and PS2 Converters
I returned from vacation this week to find that the office had bought "us" (me) a mac mini for "the workbench" (my office). It's a great little machine, but I've run into one problem. I'm quite fond of the intelimouse with it's five buttons and a scroll wheel. It works great when hooked up directly to the USB port of the mini. However, the mini is on a PS2 KVM switch, and when the intelimouse has its PS2 connector connected, then routed through the KVM to the USB/PS2 converter, the intelimouse software doesn't recognize it as an intelimouse, so there's no back/foward/expose action.
Is there a software solution to this problem? We've got plenty of mice around, but I think I'll live without the extra buttons before I deal with switching mice every time I switch computers.
#259869 - 06/07/2005 19:36
Re: OSX, MS Intelimouse and PS2 Converters
[Re: matthew_k]
I have also had problems getting a USB mouse to work through a KVM switch.
I believe this is a limitation of the KVM switch, not a limitation of the mouse or the computer.
My solution was to just have two mice. Everything else but the mouse could be KVM-switched, so I had a second mouse for the second computer.
I believe, also, that there are newer KVM switches that will accept USB mice and keyboards. I think they're more expensive though.
#259870 - 06/07/2005 19:47
[Re: matthew_k]
*sigh* I've been searching for a solution almost exactly like this for months now (I even have an old thread here) but no solution has been found. I still have two mice sitting here. The problem is, I believe, that the conversion of USB to PS/2 is a no-go. Logitech mice have the converter because (as I was told in the other thread) Logitech builds their USB mice with PS/2 speaking parts. I recently ordered a convertor from a site that Rob R linked me to (for another issue), and when it didn't work, I sent several emails to the site asking what was up, and they were basically like "well...they work for us!" I have the sneaking suspicion that they made these converters, then tested them on Logitech products
#259871 - 06/07/2005 20:00
Quote: I believe this is a limitation of the KVM switch, not a limitation of the mouse or the computer.
It's not really the KVM switch, as the buttons work on a windows computer connected through the PS2 connector and the kvm switch. It also doesn't work if I cut out the KVM switch entirely but leave the usb converters. To be clear, i'm going mac mini->usb/ps2 converter->intellimouse's ps2/usb converter->intellimouse.
If I plug this same chain into a windows box, the back and forwards buttons work perfectly. It seems that Microsoft didn't do a good job on their OSX drivers, surprisingly enough.
#259872 - 06/07/2005 20:03
Right, I do remember that thread. Luckily I'm trying to get this working with a mouse that speaks PS2 along with USB. It just doesn't get along with the mac mini.
#259873 - 06/07/2005 20:05
When using it with a KVM it's not the USB -> PS/2 converter. It's that the KVM actually emulates the mouse and doesn't just switch it in and out as needed. Most machines don't like you hotplugging PS/2 devices so the KVM talks to your real mouse and then pretends to be one to the host computer. If the KVM doesn't know how to emulate the extra features on your mouse then you don't get it.
#259874 - 06/07/2005 20:26
[Re: matthew_k]
Ah, I see. Your problem is getting the extra buttons to work. My problem was getting the USB mouse to work *at all* through a KVM switch.
#259875 - 06/07/2005 20:36
Exactly. It works, it just doesn't see that it has extra buttons. I think Microsoft thought that since macs never had PS2 ports that their software didn't need to support them.
#259876 - 06/07/2005 22:49
[Re: matthew_k]
Loc: Virginia, USA
I use a program called ControllerMate to map the buttons on my mouse to keyboard commands. But if you can't map them in the expose preferences then I don't think OS X is seeing them at all and I doubt there is a software solution.
#259877 - 07/07/2005 08:09
[Re: Dylan]
Quote: But if you can't map them in the expose preferences then I don't think OS X is seeing them at all
You may be on to something here.
Have you tried pulling out any intellimouse software on the Mac, so that it reverts to the base OS X driver? Then open the Expose control panel and see if it shows Mouse buttons above the third one.
I uae a Logitech MX 900 on my Powerbook, and never bothered with any specific mouse drivers, since OS X just saw all the buttons and used them.
#259878 - 07/07/2005 12:38
[Re: matthew_k]
Ahhh, okay I see. That makes sense. I guess MS supplies a converter with their mice too? Now I get what you're talking about.
Someday maybe my IS department will spring for USB-capable KVMs.
#259879 - 08/07/2005 20:54
[Re: drakino]
Ok, without the MS driver it's still not seeing the extra buttons. I suppose I'll have to give them up for the time being.
The next problem is that I (metaphorically) Brought My Own Keyboard, which works fine almost all of the time. When SSHing into one of the linux servers, the backspace key functions as a delete key in pico/nano. It works as a backspace key everywhere else. It even works as a backspace key when using nano locally. Odd. I havn't googled this yet, but if anyone wants to point me in the right direction I'd appreciate it.
#259880 - 09/07/2005 00:14
[Re: matthew_k]
#259881 - 09/07/2005 01:36
[Re: drakino]
Tom, but without third-party software you can't do anything (except perhaps Expose) with the extra buttons on the MX900. Game pad Companion works for this purpose: http://www.carvware.com/gamepadcompanion.htmlAnd for non-Bluetooth mice, USB Overdrive also works (he's been promising BT support for at least a year now). The program Dylan mentioned, Controllermate might work as well, but it looks extremely and unnecessarily complicated/confusing/awkward to use. As for the first part of this thread: Replace the KVM switch and don't use the adapters with the mouse. Bruno
#259882 - 09/07/2005 05:30
[Re: hybrid8]
About all I care about from a mouse on my Powerbook is a working right click, side buttons mapped to expose, and the scroll wheel working. OS X does this fine built in, and when running a game like World of Warcraft, I can map all 5 buttons to anything.
I used a trackball for a long time with a simple 3 button arrangement. When I moved back to mice, I never got used to the back/forward functionality in web browsers, instead usually using backspace as back.
For his purposes though, it was more of a test to see if maybe the 3rd party mouse drivers were getting confused by the KVM, or if (as it seems to be the case) the kvm or converter combination was not passing through the buttons.
#259883 - 09/07/2005 15:20
[Re: hybrid8]
Loc: Virginia, USA
ControllerMate does have a confusing UI but it works well. Gamepad Companion was the first program I tried but it doesn't automatically restart itself after putting the machine to sleep - obviously a problem with a notebook.
Edited by Dylan (09/07/2005 15:21)
#259884 - 09/07/2005 15:26
[Re: drakino]
Loc: Virginia, USA
Quote: About all I care about from a mouse on my Powerbook is a working right click, side buttons mapped to expose, and the scroll wheel working.
No forward/back? I've gotten too used to having that on the mouse. I also remapped the (redundant) buttons around the wheel to be CMD-Q (quit) and CMD-H (hide). Then the final button on the top (the one meant for app switching in Windows) I have mapped for expose.
#259885 - 09/07/2005 18:48
[Re: drakino]
Quote: ]For his purposes though, it was more of a test to see if maybe the 3rd party mouse drivers were getting confused by the KVM, or if (as it seems to be the case) the kvm or converter combination was not passing through the buttons.
It's passing through the buttons, the exact converter combination works perfectly in windows. OSX just isn't seeing/looking for them I guess. I'll try the various gamepad software on monday when I get back to the office.
Synergy has always looked interesting but at the moment I've only got one monitor on my desk.
#259886 - 11/07/2005 15:27
[Re: matthew_k]
ControllerMate works perefectly. I can highly reccomend it, the only downside is that there doesn't seem to be any way to use a mouse event to trigger a mouse event. This settled the scroll button as exposé or open-in-new-tab question. It's so nice to have things be consisitent accross computers now.
