#263344 - 28/09/2005 12:03
Re: Microsoft Word .DOC files on macintosh
[Re: drakino]
Download the control panel RCDefaultApp - that will let you set defaults for true filetypes, file-extensions, URL types, etc... Very handy program.
#263345 - 28/09/2005 12:32
[Re: drakino]
Quote: Right click
Or Ctrl-Click if you have a single-button mouse. Or you can click and not let go for a while, IIRC.
#263346 - 28/09/2005 15:56
Quote: Or you can click and not let go for a while, IIRC.
That only works on the Dock from my experience.
#263347 - 28/09/2005 16:01
[Re: loren]
and Firefox/Thunderbird
#263348 - 12/10/2005 15:49
[Re: andym]
Looks like you'll have a fun new app to play with on that mini
Front Row -- A new way to experience media. Music, photos, and video from Sofa. Remote control. Apple style. Looks like an iPod shuffle. Music interface from iTunes but with great full screen display.
#263349 - 12/10/2005 16:21
Re: Mac Mini as a TV-room media player
Hey Tony, it looks like Apple just announced a remote control with a whopping six buttons ![](/ubbthreads/images/graemlins/shocked.gif) . It sounds like it's context-sensitive, but given that it's Apple, it'll probably work pretty well.
#263350 - 12/10/2005 16:24
Definitely interesting. The real question is whether Apple has come up with an easy way to share iTunes files between apps. Right now, I've got a big G4 tower in the office. If I could buy a Mac Mini to use as a DVD player and everything else, that would be attractive, but I'd want them to be able to share my music files (most likely, mounted from my file server). Let's hope some kind of multi-machine-sharing is part of the story.
EDIT: Apple has now updated their web site, with some screenshots of FrontRow and the cute remote control, which seems to be all about being a part of the new iMac G5. It's entirely unclear if there's a Mac Mini variant on this.
#263351 - 12/10/2005 16:55
[Re: DWallach]
#263352 - 12/10/2005 17:34
[Re: loren]
So it's MCE but by Apple?
#263353 - 12/10/2005 18:12
[Re: DWallach]
Dan: Since the multi machine library sharing has been built into iTunes for a long time, i'm pretty sure it'd work the way you are saying... unless I'm missing something? I have all of my music shared out via iTunes on my main PC, which is picked up as a shared library on my powerbook so I can listen to it all from there.
#263354 - 12/10/2005 18:23
[Re: loren]
You can share it from machines that don't have iTunes by using mt-daapd. It'll only let you stream though, if you want to transfer the actual files over then you'll have to mount a network share etc...
#263355 - 12/10/2005 18:43
[Re: loren]
Sorry, Loren. I didn't see your post about Front Row before I made mine... ![](/ubbthreads/images/graemlins/blush.gif)
#263356 - 12/10/2005 18:44
[Re: loren]
What I'd *like* to do is keep all my content on my file server and mount it from multiple Macs. This would also make things simpler for syncing data to my laptop for DJing. If I have to run everything through iTunes, then I loose some of the functionality that I'd otherwise want.
#263357 - 12/10/2005 18:46
[Re: DWallach]
What's keeping you from doing just that? Mounting it on different macs?
#263358 - 12/10/2005 19:47
[Re: loren]
It doesn't seem that you can order Front Row and the remote seperatly. Seems short sided seeing as the mac mini is the obvious candidate for the remote.
#263359 - 12/10/2005 19:49
[Re: loren]
Quote: What's keeping you from doing just that? Mounting it on different macs?
If I go that route, I have to be careful to never have more than one iTunes running at the same time, otherwise changes to the XML flat-file database might not be saved. Also, at least when I tried doing this from the Mac to the PC, I ended up being able to copy over the music files fine but my playlists ended up not working. I need to try again with the newest iTunes and see if the situation has changed.
#263360 - 12/10/2005 19:52
[Re: DWallach]
Ah. If you want to be able to modify stuff from various computers then no, it won't let you do that. The best you can do is serve it out via DAAP and be content with just listening and selecting tracks.
#263361 - 12/10/2005 20:56
[Re: matthew_k]
Quote: It doesn't seem that you can order Front Row and the remote seperatly. Seems short sided seeing as the mac mini is the obvious candidate for the remote.
Rabid speculation:
Remember when Apple said that this was "the year of HD"? My dual-1GHz G4 tower doesn't have enough juice to do 1080i in real-time, so I presume the Mac Mini (with only a single G4, up to 1.4GHz) is similarly disinclined. It's entirely possible that the G5's can do it, but I don't really know.
Maybe Apple is saving up a "Mac Mini AV" for when they switch to Intel processors (and/or fancier graphics cards) that can handle HD. They're starting out with content at toy resolutions, mostly to convince Hollywood that FairPlay can work. Then, maybe next year, we'll finally see all of this HD stuff happen for real.
#263362 - 12/10/2005 21:44
[Re: DWallach]
Yup, my Top 'O The Line POWERbook that they're still selling can't do HD. You can't even get the thing with a decent high resolution/definition screen.
It can still play video and music just fine. A remote for the mac mini seems like a no brainer. A USB IR sensor wouldn't cost much, even if they did have to paint it white.
Ah well. If you want OSX, you run it on what Steve wants you to run it on.
#263363 - 12/10/2005 21:48
[Re: matthew_k]
Quote: A remote for the mac mini seems like a no brainer. A USB IR sensor wouldn't cost much, even if they did have to paint it white.
I've got an ATI remote wonder plugged into my Mac Mini right now, as a matter of fact...
I need to take the time to set it up a bit more, such as programming keys and stuff.
#263364 - 14/10/2005 19:23
Okay, next Mac question.
I have enabled Windows File Sharing on the mac mini. I have told it that all the accounts on it can use windows file sharing.
But unless I'm logged in to one of those accounts, I can't connect to the share. I can only connect to the share when I'm actually logged in.
Can that be fixed somehow? So that someone could connect to a share when it's just sitting at the login screen. You know, like Windows NT does.
#263365 - 14/10/2005 19:29
Is the machine actually network accessible at all during those times?
#263366 - 14/10/2005 19:40
Quote: Is the machine actually network accessible at all during those times?
Good question. I don't know.
You mean, like, respond to a ping?
And, if it didn't, why would that be?
#263367 - 14/10/2005 19:45
Interesting. Okay, it doesn't respond to a ping when I'm logged out.
Is there a setting that turns off the AirPort when I log out?
#263368 - 14/10/2005 19:49
#263369 - 14/10/2005 19:58
Super. Tell me what you changed so I can fix it on my Mini.
#263370 - 14/10/2005 21:00
Network properties, airport, there's an "options" button at the bottom, and then in that dialog there's an option to disconnect from wireless networks when you log out.
#263371 - 17/10/2005 00:57
Hunh. When I click that Options button, nothing happens. Well, the button turns blue for an instant, but nothing beyond that.
Ideas?
#263372 - 17/10/2005 01:19
Only the obvious question. Is the user you are logged in as, an admin?
That panel won't give you the time of day if not.
#263373 - 17/10/2005 01:36
[Re: gbeer]
Yup. It's greyed out otherwise. I'm clearly clicking the button, it just doesn't make anything happen. It's really academic at this point anyway, though, as it's not disconnecting the network when I log out.
