Page 2 of 2 < 1 2
#264198 - 18/09/2005 22:27 Re: Maybe I spoke too soon [Re: pgrzelak]
Tony - a recommendation for the disk upgrade FAQ. If
people cannot build their new drives due to memory limits,
this procedure can be used to finish the build job.
I'm trying to take a stand and, each time this comes up,
whine and moan and complain and:
a. Beg someone at empeg to make a proper builder image
that works with big drives...
b. Beg someone to somehow hack the existing builder image to
make it work, or...
c. Beg Mark Lord to build large-disk diskbuilding into Hijack
or somehow help us by coming up with another solution.
We really need something. Really really.
#264199 - 19/09/2005 12:12 Re: Maybe I spoke too soon [Re: tfabris]
Well, unlike the player image, there's no copyrighted data that would need to be included in a builder image, so this should be doable. Let's see. You'd need a kernel that had its root image on a ramdisk, the ramdisk itself containing a simple binary to do the following: create the partitions, turn on the swap partition, create the music filesystem, and burn in the filesystem, if desired. (I don't think we have to create the root filesystem, as the upgrade does that for us.) So the total things you'd need are the kernel, that init binary (or sh and a script, possibly), fdisk, swapon, mkfs, and dd and rm (or something to burn in with). Not a piece of even remotely copyrighted software there.
#264200 - 19/09/2005 21:40 Re: Maybe I spoke too soon [Re: pgrzelak]
Squid2k1
Loc: Ocean Floor
You should be fully functional at this point. You may just
want to do an fsck set when you get time, just to clear the
marker on the root partition.
Yes, for the first time in two weeks I did not have to sing to myself for my 35 minute commute! Thanks for everything!!!!
Squid2k1 --- 18GB of revived Green Mk II Fury - Fast As A Shark
#264201 - 20/09/2005 10:03 Re: Maybe I spoke too soon [Re: pgrzelak]
Happy Birthday schofiel
It looks to me like you have built a second drive, bigger than 40G, using the original builder image, and then cabled it in as slave.
When you add content to your player, the player distributes it across the disks it has available, and then records the meta data (tags, name, location etc) in the static database.
If you have simply shoved a new disk in in place of a dead second drive, it is now complaining that it can't find the tracks it expected to be there (from the old one).
You need to build this disk by hand using the instructions on Roger's website (www.differentpla.net) instead of using the builder. This will take a bit of command line magic using an installed developer image. You will then have to re-build the track database, which you can find in the FAQ.
#264202 - 20/09/2005 10:06 Re: Maybe I spoke too soon [Re: tfabris]
a) empeg don't exist no more.
b) this would take motivation, something missing from the board these days.
c) Mark?
Page 2 of 2 < 1 2
