#264953 - 10/09/2005 19:03 empeg freezes after startup
iopcool25
Loc: New York
i have the mkII and im using v3alpha11and the latest hijack 439
The empeg loads sucessfully but once it gets to playing a song. It is stuck on the last song I play and wont move from there.
I did a ram test and all was ok and I rebuilt the database but it did nothing. This started when i tried to sync for empeg via network cable
only thing i can do on the empeg is hold down the rotary button to get the hijack features and use those. Cant play any music it wont move from that perticular song please help.
#264954 - 10/09/2005 19:14 Re: empeg freezes after startup [Re: iopcool25]
It might be a bad track or playlist. Try this...
#264955 - 10/09/2005 19:31 Re: empeg freezes after startup [Re: pgrzelak]
iopcool25
Loc: New York
ok that worked but whats this mean
! tags.cpp : 61:Failed to open tags (0xc0041002).
Tried to mount /dev/hdc4 but got error 6 16384) initialized: 16 RAM disks of 40
Error mounting partitions (possibly already mounted)2 (Dag Brattli)eg single channel IDE
#264956 - 11/09/2005 10:05 Re: empeg freezes after startup [Re: iopcool25]
Well, hdc4 is the second hard drive's music partition. If you only have one drive, it means nothing. If you have two hard drives, I would recommend a power off, capture the next complete boot log and post it here. I suspect it was just a one time artifact of stopping the player while booting. If not and you still have trouble, you may have to rebuild the databases by hand and manually check your disk drives.
#264957 - 26/09/2005 19:27 Re: empeg freezes after startup [Re: pgrzelak]
Raas
Hi All,
I'm getting a similar problem, nothing works apart from the hijack menu. My computer doesn't for some reason have hyperterminal on it either so am using Tera Term. Working with V3A11 developer version.
Check this for a log.. problem is, none of the commands in the faq have any affect at all. Any ideas anyone?
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315
(release)) #15 Mon Jul 25 18:52:48 BST 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 30102459)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005b00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK2018GAS, ATA DISK drive
hda: TOSHIBA MK2018GAS, 19077MB w/0kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:9
b
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
serial_notify_thread.cpp: 116:@@ N11
serial_notify_thread.cpp: 117:@@ F0x8190
serial_notify_thread.cpp: 118:@@ TStreamline
serial_notify_thread.cpp: 119:@@ APendulum
serial_notify_thread.cpp: 120:@@ GDrum & Bass
serial_notify_thread.cpp: 170:@@ S1
serial_notify_thread.cpp: 180:@@ #8190 0:00:02
Much appreciated.
Looks like I was a little premature. This is from the bottom...
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Starting bash.
empeg:/empeg/bin#
Edited by Raas (26/09/2005 19:39)
#264958 - 26/09/2005 20:21 Re: empeg freezes after startup [Re: Raas]
From that shell prompt, try "player -i", then after the player application loads with a blank playlist, type "q" to quit, "exit" to exit back to the player and reboot. Better???
#264959 - 26/09/2005 20:38 Re: empeg freezes after startup [Re: pgrzelak]
Raas
Paul, you are an absolute star my friend!!
I'm on business to Newcastle and Cardiff from tomorrow and thats a hell of a drive, you just saved my sanity.
Muchos Gracias!
#264960 - 26/09/2005 20:54 Re: empeg freezes after startup [Re: Raas]
That's temporarily solved the problem, but you now need to remove the offending track or else your player will crash again the next time it tries to play it. I don't know if the track was the one in your log above, or if it was one that was being precached future playback.
#264961 - 26/09/2005 20:58 Re: empeg freezes after startup [Re: tfabris]
I agree with Tony. Make sure you verify that the track is not damaged - you may want to remove it or replace it. Still, I am glad it is working for your trip. And, for more detail, check out the FAQ entry...
#264962 - 28/09/2005 16:05 Re: empeg freezes after startup [Re: pgrzelak]
Raas
Thanks guys,
The track hasn't casued the problem since, but I will replace it when I get the chance.
That faq entry would have saved me a good few hours. I will work on my search skills for the future.
cheers
