#265012 - 11/09/2005 19:34 Land Rover (Defender) install a good idea?
dap2
Hi all,
Has anyone installed an Empeg in a Land Rover Defender? And while I'm on the subject - what would be the consequence of mounting an Empeg vertically (i.e. pointing straight up?) - one of the favoured mounting positions for a head unit in a Defender is in a box between the driver and passenger, pointing straight up.
Thanks,
Andrew.
Edited by dap2 (11/09/2005 19:45)
#265013 - 11/09/2005 19:55 Re: Land Rover (Defender) install a good idea? [Re: dap2]
Mounting vertically is NOT an option. The internal HD mounts for the empeg need to be within a few degrees of horizontal to do their thing (vibration isolation etc..).
If mounted vertically, the drive tray may eventually come loose, with possible catastrophic results.
#265014 - 11/09/2005 19:58 Re: Land Rover (Defender) install a good idea? [Re: mlord]
dap2
Doh! Of course - thanks.
Andrew.
#265015 - 11/09/2005 22:31 Re: Land Rover (Defender) install a good idea? [Re: dap2]
Of course It could be modified to work if you're feeling adventurous. I think the biggest problem would be the drive tray coming off of the rubber mounts because of the vertical stress. If you replaced the mounts with something more rigid...say a tube-like spacer with a bolt through and a nut with loctite, you could probably get it to work.
I wouldn't risk it though
#265016 - 12/09/2005 00:41 Re: Land Rover (Defender) install a good idea? [Re: mlord]
FireFox31
Loc: East Coast, USA
A friend of mine has his empeg mounted vertically in the arm rest between the two front seats. It works, for now. But wow, I really have to get him to move it; to the glovebox if nothing else.
FireFox31
