Page 3 of 3 < 1 2 3
#26682 - 15/02/2001 12:45 Re: empegTaxi usb test [Re: tfabris]
Okay, the new version you replaced at the same link works great. Thanks!
This is really great, I'm looking forward to the version with the serial stuff built-in.
How are you planning on doing uploads? If you don't have a way of doing uploads right away, may I make another "in advance" suggestion?
Have it default to listing the contents of /drive0/fids and /drive1/fids in either most-recent order and/or largest-file order. In my case, both of those situations would list my taxi file if I'd chosen to upload it via Emplode.
#26683 - 15/02/2001 12:55 Re: empegTaxi usb test [Re: tfabris]
Jazzwire
Loc: Guernsey
I was thinking of grepping the *1 files for user supplied keywords... =)
Your idea would work nicely as a secondary filter...
Watch this space... =)
Jazz
(List 112, Mk2 12 gig #40. Mk1 4 gig #30. Mk3 1.6 16v)
Jazz (List 112, Mk2 42 gig #40. Mk1 4 gig #30. Mk3 1.6 16v)
#26684 - 15/02/2001 12:59 Re: empegTaxi usb test [Re: Jazzwire]
Or better yet...
There might be a way to easily figure out which *1 files are in "Unattached items"? Or am I dreaming?
#26685 - 15/02/2001 13:09 Re: empegTaxi usb test [Re: tfabris]
I dunno if you can find this out from the console, but I think the first two characters of a .zip file are always "PK"...
#26686 - 17/02/2001 15:07 Re: empegTaxi usb test [Re: tfabris]
bonzi
We would need 'file' command and corresponding /etc/magic file. Handy to have anyway... Extracting first two bytes of every file with dd would be much slower.
Dragi "Bonzi" Raos
Zagreb, Croatia
#26687 - 02/03/2001 16:00 Re: Windows 2000 Networking Question [Re: tfabris]
amold
what you need is to use the iphelper API to add a virtual address to the interface. there's probably a sample for that in the SDK or in the knowledge base.
#26688 - 03/03/2001 13:34 Re: Windows 2000 Networking Question [Re: tfabris]
amold
or, get ipadd.exe from ftp.blarg.net:users/amol/ipadd.exe
the address will only last as long as the app is running.
#26689 - 05/03/2001 16:56 Re: Windows 2000 Networking Question [Re: amold]
Thanks! This looks like exactly the sort of thing I was looking for.
#26690 - 06/03/2001 14:48 Re: Windows 2000 Networking Question [Re: amold]
OMFG... THAT WORKED!!!!!!!!!!!!!
THANK YOU!!!!!!!!!
#26691 - 06/03/2001 14:58 Re: Windows 2000 Networking Question [Re: tfabris]
Okay, next question.
How do I tell my web browser not to try to go to my company's proxy server whenever I type in an address that starts with "10.x.x.x"?
I can't believe I have to ask this question. I go into the proxy options, and where it says "do not use proxy server for addresses beginning with", I put in "10." And it still tries to go to the proxy server. I have "do not use proxy server for local addresses" checked, and it still tries to go to the proxy server. WTF?!?!
Incidentally, I get the same results with either IE or Netscape.
#26692 - 06/03/2001 15:28 Re: Windows 2000 Networking Question [Re: tfabris]
Not sure about Netscape for this, but IE needs 10.*.*.* entered if you want to ignore the 10.x.x.x subnet. I still have no clue what "Do not use proxy server for local addresses" actually does though.
#26693 - 06/03/2001 16:32 Re: Windows 2000 Networking Question [Re: drakino]
Hmm. Still having trouble.
With IPADD running, I can now ping the Empeg, and Emplode has no trouble connecting to it and synching on the 10.0.0 subnet, but my web browser won't talk to displayserver. I think it's still going out to the proxy server, even with 10.*.*.* in that box. I'm going to mess around a bit more...
#26694 - 06/03/2001 18:37 Re: Windows 2000 Networking Question [Re: tfabris]
Do you have either "Automaticially detect settings" or "Use automatic configuration script" checked? I've found that those will cause IE to ignore or overwrite your local ignore settings.
Also, do your proxies access internal sites? Mine do, and the symptoms I would see is that Displayservers home page worked fine, and a few others, but the java applet would never load. That was my only way of knowing if my browser went through the proxy or not.
#26695 - 06/03/2001 19:16 Re: Windows 2000 Networking Question [Re: drakino]
Grr. Yes, that's checked. When I get back into work tomorrow, I'll try turning that crap off. Hope it works.
Not sure. They shouldn't. I'm not getting to talk to displayserver at all, even though I can ping the empeg and Emplode will talk to it just fine.
Page 3 of 3 < 1 2 3
