Page 2 of 3 < 1 2 3 >
#267184 - 24/10/2005 18:58 Re: NewNewFace Problem for discussion [Re: Taym]
rutherk1
Man
Thats just perfect.
#267185 - 24/10/2005 19:54 Re: NewNewFace Problem for discussion [Re: rutherk1]
loren
Yeah, I'd dip into the coffers for some of that. Beautiful.
|| loren ||
#267186 - 28/10/2005 11:28 Re: NewNewFace Problem for discussion [Re: loren]
morrisdl
Loc: Rochester, NY USA
Great work and a nice update - I am in for a silky
#267187 - 02/11/2005 20:01 Re: NewNewFace Problem for discussion [Re: morrisdl]
Qtqc
Those are perfect. Any idea about when there ready for sale?
#267188 - 03/11/2005 03:44 Re: NewNewFace Problem for discussion [Re: speedy67]
zaskar
Loc: Toronto, Ontario
I want one:) What's the timeframe for sales.
#267189 - 07/11/2005 18:12 Re: NewNewFace Problem for discussion [Re: zaskar]
speedy67
Loc: South-West-Germany
Hi, i'm just back from the UK and havn't talked to my friend yet. But i hope to get a web site online for ordering in about 2 or 3 weeks. I want to get this going before christmas...
There will be batches of 10 pieces, cause we can do them only at night, when the machines are free. So watch out for an announcement...
cheers, Thomas new owner of the MK1 00123 MK2 12GB 090000815 (my first one) MK2a 040103735 (from 303) and ???
#267190 - 09/11/2005 20:48 Re: NewNewFace Problem for discussion [Re: speedy67]
Derek
Loc: NRW, Germany
The screws in the original empeg handle are self tapping. If you can't get around drilling right through the new handle when you make it, you at least don't have to tap the holes. This leaves a smaller, tidier hole on the outside of the handle. The only thing is that the end user has to be careful when inserting the screws for the first time - they will be quite tight!
#267191 - 11/11/2005 00:55 Re: NewNewFace Problem for discussion [Re: speedy67]
jpt
Maybe I'm just an idiot, but I don't see any screws in the handle on the original faceplate? In fact it seems like putting screws there would keep the handle from moving...
Regardless I'd most likely be interested in a black one. They look awesome! Don't know if I'll be able to afford them before end of year though, so hopefully there will be more than one batch
MkIIa #40104178, 22GB
#267192 - 11/11/2005 01:55 Re: NewNewFace Problem for discussion [Re: jpt]
JaBZ
Loc: NZ
Don't have mine in front of me, but look on the inside of the handle, I believe the handle is screwed to the spring arm?
#267193 - 11/11/2005 10:12 Re: NewNewFace Problem for discussion [Re: JaBZ]
speedy67
Yep, it's screwed from the inner side, and cause the original handle is die-cast, there are no holes from outside needed.
Derek, the holes will be small at the outside, even if we cut the thread. Leaving this to the customer may end in worn out threads from the beginning, cause you need a good feeling with the material, if you cut the thread with the screws, not to use too much force on it.
And yes, there will be more batches than one, don't worry. But it'll take time.
#267194 - 11/11/2005 17:34 Re: NewNewFace Problem for discussion [Re: JaBZ]
jpt
Yup, I am just an idiot Anyway one more voice for the "leave em open" school, black finish flathead screws in black anodized metal will not look bad at all (especially if they are close to flush but even if they are somewhat sunk).
#267195 - 17/01/2006 19:29 Re: NewNewFace Problem for discussion [Re: speedy67]
peakmop
Loc: 384400 km from the Moon
I wonder what's the status of this project?
#267196 - 17/01/2006 20:37 Re: NewNewFace Problem for discussion [Re: peakmop]
schofiel
I'll pass on part of an answer on behalf of Thomas.
He and his g/f Tanja visited me not so long ago, and he showed me the current state of play. The big issue is the quality of finishing of the hinge holes as has been previously discussed.
Since then, Thomas has moved house and is currently waiting for a broadband connection, so I suspect you might have to be a little patient before he replies.
Rest assured though - they are going to be made.
#267197 - 19/01/2006 13:09 Re: NewNewFace Problem for discussion [Re: speedy67]
Glen_L
Loc: Elk Grove, CA
Any NewNewFace status update?
No longer a stranger, finally a full-fledged member! \:D
#267198 - 19/01/2006 13:13 Re: NewNewFace Problem for discussion [Re: Glen_L]
Uh. Rob posted an update on behalf of Thomas 2 days ago...
#267199 - 19/01/2006 13:14 Re: NewNewFace Problem for discussion [Re: Glen_L]
CrackersMcCheese
Uh....
#267200 - 19/01/2006 13:14 Re: NewNewFace Problem for discussion [Re: CrackersMcCheese]
Too slow!
#267201 - 19/01/2006 21:39 Re: NewNewFace Problem for discussion [Re: tman]
Glen_L
Loc: Elk Grove, CA
How embarassing...I did a search to dig up the thread and didn't read for updates before posting to it. Well, at least the project is still alive, that's the important thing.
#267202 - 28/02/2006 02:46 Re: NewNewFace Problem for discussion [Re: tman]
natewhip
Quiet One
Loc: Idaho
I was wondering if there was an update on the status of the newface???
#267203 - 28/02/2006 12:08 Re: NewNewFace Problem for discussion [Re: natewhip]
dcosta
Loc: Massachussetts
Yeah, I want 2. what's up?
__________ davecosta Hijacked 60GB MKIIa 2.0b13
#267204 - 28/02/2006 21:49 Re: NewNewFace Problem for discussion [Re: dcosta]
schofiel
He's busy with:
- new g/f
- new job
- new house
- various other issues.
Don't worry - it's not forgotton - it's just on the back burner. I have seen the stuff, it's good gear, and nearly ready to go. Be patient a little longer.
#267205 - 02/03/2006 04:06 Re: NewNewFace Problem for discussion [Re: schofiel]
jpt
Finally, a question that's not a status nag!
Is the depth of this faceplate going to be identical to the original one? I'm going to be installing the empeg in my TSX when it gets here, and I'll eventually want the new black face, but I need to know if this will be a consideration when installing (it's also going to be my first DIY install so I am maybe a little paranoid here).
#267206 - 13/03/2006 10:51 Re: NewNewFace Problem for discussion [Re: jpt]
speedy67
Sorry guys for being away such a long time...
No, the project isn't doomed and didn't vanish in the hell of empeg-add-ons...
As Rob said, i've been very busy with work, moved to a new house, together with my girlfriend, which is a very time-consuming task for itself (ikea-visits every now and then) and i'm still waiting for a properly working DSL-line in my house. The Telekom doesn't get it into a stable state.
Reading the board and posting at my job isn't as easy than the time before, my boss can look at my screen, cause i have got a new place in the office.
The other thing why there was no update is, my friends company, where the faces are made, is totally overloaded with work, so he doesn't get access to the machines at the moment. As soon as there is a chance to make some, he will jump in.
Enough excuses...
@jpt: the NewNewFace is thicker than the original fascia, it's even a little thicker than the NewFace from Tim (303). Thats because of the handle. This way it's strong enough to allow to carry the player with it.
No more news for now. Stay tuned...
#267207 - 07/04/2006 13:11 Re: NewNewFace Problem for discussion [Re: speedy67]
Cool.
(This thread kept showing up as having unread posts for me. This post will hopefully prevent that.)
#267208 - 07/04/2006 14:47 Re: NewNewFace Problem for discussion [Re: JBjorgen]
Hmmm.... me too. Now it really will have an unread post for you to read.
#267209 - 23/06/2006 11:57 Re: NewNewFace Problem for discussion [Re: speedy67]
peakmop
We are still tuned, I guess...
#267210 - 23/06/2006 13:13 Re: NewNewFace Problem for discussion [Re: peakmop]
speedy67
Things are going on. Slowly, but still going... Please, be patient a little more...
cheers,
Thomas
#267211 - 23/06/2006 14:08 Re: NewNewFace Problem for discussion [Re: speedy67]
spider
thanks for the update, any news is good news.
#267212 - 12/09/2006 12:28 Re: NewNewFace Problem for discussion [Re: speedy67]
Glen_L
Loc: Elk Grove, CA
Still no NewNewNews?
#267213 - 12/09/2006 12:32 Re: NewNewFace Problem for discussion [Re: Glen_L]
speedy67
I hoped, to have some ready at the meet, but my friend didn't got the time. I'm so sorry to say please wait a (hopefully) little longer.
