#270252 - 21/11/2005 12:27
Help - power but no sound
I've installed a cheap CD head unit to keep my going whilst my empeg is being repaired but I'm having trouble with it.
I get power ok, and am able to tune the radio in, but I don't get any sound from my speakers.
I have an amp in the boot and forward and rear speakers. I've tried plugging the pre-out into either set of RCA plugs leaving the other pair loose. No sound anywhere.
When I removed the empeg sled I noticed that there was a blue wire coming from the direction of my amp. It had a bullet connector that conneced onto a blue wire on the empeg loom. Any idea what this is, and could it be causing the problem?
What else could be the issue? A blown fuse somewhere? If the speakers were shorting out somewhere, could this cause an issue?
Any suggestions would be appreciated.
Or should I just GAMI?
Mk2a RioCar 120Gb - now sold to the owner of my old car Rio Karma - now on ebay...
#270253 - 21/11/2005 12:29
Re: Help - power but no sound
[Re: furtive]
Blue? Is that the amp remote line??? If so, that will certainly need to be connected.
#270254 - 21/11/2005 12:31
[Re: pgrzelak]
Thanks.
Connected to what?
#270255 - 21/11/2005 12:51
[Re: furtive]
Assuming your empeg is going into an input line on the other head unit, it should connect to that head unit. If you are going from the other radio to the aux in on the empeg, it should connect to the empeg.
Basically, if it is what I think it is, the blue line you see is the amp remote line - the wire that (when 12v is applied to it) signals the amp to turn on and do its thing. It might be that everything else is correct, but the amp (not seeing the remote signal) is turned off. Do you have a status LED or any blinkenlights on the amp to show that it is turned on? (Note: This is completely different from the amp's power feed, but you probably already know that.)
#270256 - 21/11/2005 12:56
[Re: pgrzelak]
There should be an amp remote wire on the head unit also. Just connect it to that.
I know this sounds stupid, but it's gotten me a couple times. Remember that the AC and DC volume settings are separate, so you shouldn't assume that just because you can hear music in the house, that the volume is set properly in the vehicle. You'll want to move it from -infinity to 0db when you have it running into the aux input of another head unit.
#270257 - 21/11/2005 13:00
[Re: JBjorgen]
Whoh there. I don't have a working empeg. I have therefore removed my empeg sled and loom and am plugging this new headunit into the ISO plug instead.
I didn't see an amp wire coming out of the headunit. Just a bunch of wires going into an ISO plug.
I guess I just need to test each of the (blue) wires coming out of the ISO plug until I find one that has 12v on it with the headunit turned on and 0v with it turned off, then just connect that wire to the loose blue one? Sounds easy enough.
Right, question 2 - I have a 4 channel amp so have 2 pairs of RCA connectors but the headunit only has a single pair. Can I just get one of these and join the front and rear's together?
![](http://www.maplin.co.uk/images/Full/29191i0.jpg)
#270258 - 21/11/2005 13:08
[Re: furtive]
Quote: Whoh there. I don't have a working empeg.
Oh. Right. I went back and read the beginning of the thread. I forgot about that.
You should be able to consult the manual that came with the head unit and find which of the wires is the amp remote. Then just remove that wire from the ISO plug or clip it (far enought back that you can reconnect it for future use) and connect it to the blue amp remote wire heading toward your amp.
IIRC, if you split the RCA, you'll lose some volume (level voltage), but as long as you have enough power in your amplifier to compensate, I think it should be ok.
#270259 - 21/11/2005 13:14
[Re: JBjorgen]
Thanks. Unfortunately the "manual" for the headunit is sparce to say the least. The installation guide says "plug in the connector". I guess you get what you pay for. It looks pretty though. Amp should be more than powerful enough - it's one of these: http://www.caraudiodirect.co.uk/product_...42aa1a5d26f0b27
#270260 - 21/11/2005 13:25
[Re: furtive]
What kind of cheap CD head unit? Does it have an "amp remote" line or equivalent?
I found a PDF of the genesis profile four. The last connection at the very end is labeled as the remote line. Your blue wire should probably be connected to this line on the amp, and to the "remote" wire output on your head unit (if one exists).
#270261 - 21/11/2005 13:30
[Re: pgrzelak]
This type of cheap headunit.
#270262 - 21/11/2005 13:44
[Re: furtive]
Hmmm... The head unit's site seems to say it uses an ISO out adapter. It might be that it uses the same position in the ISO adapter that the empeg uses (pin 5 in the wiring diagram). Still looking...
Edit: Aha! Over on their support FAQ page, they answer about connecting the amp remote out line with:
Quote: Where can I connect the remote wire of my amplifier?
If you are using an after market radio you would connect the remote of the amplifier to the remote wire of the radio labeled; (remote, amp turnon or pwr. ant) on most radios a blue wire or on others a blue with a white tracer. If you are interfacing the amplifier with a factory (OEM) radio you will connect the remote terminal to an accessory wire that powers up only when the key is in the on position.
Edited by pgrzelak (21/11/2005 13:49)
#270263 - 21/11/2005 14:40
[Re: pgrzelak]
Ah ok, thanks. All I need to do is take the wire from pin 5 and connect it to my amp remote wire and everything should be good to go. I'll give it a go.
How on earth did you find that FAQ on their website? I couldn't find it anywhere - just a load of word documents in Chinese!
#270264 - 21/11/2005 15:55
[Re: furtive]
Greetings!
I think that will work, assuming their ISO connector is standard (not a certainty), but there should be some labeling on the head unit.
As for the PDF and information, I found myself in the support section after a few googles, and was able to get to their FAQ page. That is what I linked. I hope it will help.
#270265 - 21/11/2005 16:44
[Re: furtive]
Quote: Right, question 2 - I have a 4 channel amp so have 2 pairs of RCA connectors but the headunit only has a single pair. Can I just get one of these and join the front and rear's together?
Depends on the direction you're going. I think, assuming that what you're talking about is a 4-channel amp and a 2-channel head unit, yes that's possible.
But you're not joining in that case, you're splitting. So your word "join" is confusing there. What you'd be doing in that case is splitting the outputs of the head unit to go into the 4 inputs of the amp.
However. does your amp have pass-through connectors on it? If so, use those instead, do not use the Y-splitter adapter you pictured. Only use the Y-adapter as a last resort if your amp doesn't have pass-through connectors. Illustrations of various ways to hook things up are here.
If you're going the other direction, trying to take four output channels and combine them into two input channels, that really is joining, and you should not do it.
#270266 - 21/11/2005 16:52
According to the Genesis Profile Four amplifier PDF Paul linked above:
Quote: 1. If only one set of pre-outs are available plug these Into Inputs 1&2. Signal will be fed to Inputs 3&4 Internally. Do not use 'Y' cables.
#270267 - 21/11/2005 17:08
[Re: furtive]
To make sure it's the amp remote wire, use a little jumper wire from the amp's power line to the amp remote input. Then turn on your new HU and see it it works.
Then you'll know you're solving the right problem.
#270268 - 21/11/2005 17:31
[Re: matthew_k]
Yeah, just don't hook it up that way permanently, or you'll get speaker-damaging pops when you turn the car on and off.
#270269 - 21/11/2005 17:31
[Re: JBjorgen]
And yeah, what Meatballman said.
#270270 - 23/11/2005 12:33
Many thanks for everyones advice. I popped home at lunchtime today, ripped the dash apart again andset to work. I cut the blue wire coming out of the headunit loom (as if defusing a bomb movie-style) and crimped the two ends back together in a female bullet connector so that I could then plug inthe male bullet connector coming from my amp. I now have sound from the front speakers. For some reason though, nothing from the rears despite connecting it up as per the Genesis instructions. I tried plugging the rear RCA's into the headunit and got sound, but nothing when trying to get the amp to automagically sort things out. Any ideas why? Anyway, front speakers working is better than no speakers working ![](/ubbthreads/images/graemlins/smile.gif)
#270271 - 23/11/2005 13:10
[Re: furtive]
Okay. Progress!
Now, you are not getting anything out of the rear speakers? Except when you plug the rear RCAs into the front head unit outputs? Do you have the fader controls set correctly? Another thought, make sure (if you are not using a sub) to have the lowpass filter off on the amp. Are you using Y cables? Can you clarify your existing wiring and options on the head unit? Thanks.
#270272 - 23/11/2005 13:19
[Re: pgrzelak]
Right, looking again at the wiring diagram for my amp it shows that the front preouts are on the far left - but these are the ones I have removed as they were driving the rear speakers!
So it looks like when my amp was installed the wiring was done incorrectly. So if I move the connections from the right hand connectors to the left ones, I should be good to go I think.
If you can excuse my poor MS Paint skills, the attachment shows roughly how it's all wired up.
#270273 - 23/11/2005 13:41
[Re: furtive]
That should do it! It looks like you should have a nice setup when you are done. Cool!
#270274 - 23/11/2005 13:49
[Re: furtive]
Quote: Right, looking again at the wiring diagram for my amp it shows that the front preouts are on the far left - but these are the ones I have removed as they were driving the rear speakers!
What's front and channels on an amp is typically not set in stone, but which signal (front/rear left/right) you plug in where on the amp. Though often you're constrained by what filter options are available for what channels on the amp and how you typically set up a system (front system HP filtered to reduce the stress from deep bass, rear channels LP filtered to run a sub ). The labelling on the amp should [hopefully] be consistent between input and related output, but you're of course free to ignore any 'front', 'rear', 'left', 'right' labels if it better suits your setup - cable runs, filtering etc...
Hmm, as I interpret that, you're running everything off the HU and the amp actually doesn't power anything at all... And you've got two speakers in parallell on each channel in the rear, possibly creating a too low impedance for the HU, but yhat's not the impression I got from the posts earlier in the thread...
#270275 - 23/11/2005 14:00
[Re: mtempsch]
Yeah, but John already posted a snippet from the manual for the amp that said that if something is plugged into the front inputs but not the back, then the amp would send the signal to all four speakers. In that case, it does make a difference.
#270276 - 23/11/2005 14:04
[Re: mtempsch]
Quote: Hmm, as I interpret that, you're running everything off the HU and the amp actually doesn't power anything at all... And you've got two speakers in parallell on each channel in the rear, possibly creating a too low impedance for the HU, but yhat's not the impression I got from the posts earlier in the thread...
Oppsies - my bad. All the dirty yellow squiggly lines should be going to the amp, not the headunit.
#270278 - 25/11/2005 11:49
[Re: mtempsch]
Right, many thanks guys. Just popped home and fixed it. Swapped the cables over so they were plugged into the right ports on the amp, and also un-pressed a little button that should have been out according to the amp instructions and I now have glorious sound coming from all 8 speakers ![](/ubbthreads/images/graemlins/cool.gif) The headunit seems to forget it's settings every time I turn off the ignition, but looking at the comments on the site I bought it from that looks like a common fault caused by incorrect loom wiring - just need to swap the red and yellow cables over I think.
#270279 - 25/11/2005 11:54
[Re: furtive]
Excellent!!! ![](/ubbthreads/images/graemlins/smile.gif)
#270280 - 04/12/2005 10:21
[Re: pgrzelak]
Erp! It's stopped working! It worked fine for a couple of days and now no sound again ![](/ubbthreads/images/graemlins/mad.gif) I've had the dash apart and have recrimped the connection - it's definitely good. So what else could be causing a lack of sound? I've no idea if the amp is powering on or not - there doesn't seem to be a way to check, but I'm guessing it's not. I tried to check for some sort of voltage on the blue wire when turning the headunit on, and there didn't seem to be anything coming from it at all.
#270281 - 04/12/2005 11:06
[Re: furtive]
Have you checked the player on AC power, just to be certain it is not the empeg itself?
