Hi, I have ran into a problem when I tried to synch my player today. I am hoping that this is just my lack of knowledge about Linux and the player making itself evident here and it is a simple fix.
Right now when I try to use emplode to connect, it appears to try to finish up the synch and during or shortly after "Waiting for the empeg-car to respond" I get a message saying "The download process failed during stage 4: Error 0xfffffffb"
I have tried several times with the consumer and devoper images being reloaded on the player. A few weeks ago I did manage to get displayserver working on it by following the instructions elsewhere on the BBS. I don't think I have attempted a synch since then, so I'm not sure how that affects matters or if it was something else I did. Ever since my synch attempts today, whenever the player reboots it spends about a minute at "Building the music databases..." and this is also true when I try to connect via Emplode and it attempts to finish up it's synch while 'waiting for empeg-car to respond'.
Here is what I am seeing through Hyperterminal when the player is powered up:
empeg-car bootstrap v1.00 20000601 (
[email protected])
e000 v1.01
Copying kernel...
Calling linux kernel...
Uncompressing Linux.................................... done, booting the kernel
Linux version 2.2.14-rmk5-np17-empeg38 (
[email protected]) (gcc vers
ion 2.95.2 19991024 (release)) #116 Wed Oct 4 14:32:42 BST 2000
empeg-car player (hardware revision 7, serial number 90000770)
Command line: mem=12m temp=49
Memory: 11000k/12M available (968k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
empeg display initialised.
empeg dspaudio driver initialized
empeg infra-red support initialised.
empeg state support initialised 0089/88c1 (save to d0005480).
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:0
2
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5 chan
ge_root: old root has d_count=1
Wѽչչсɽс okay
Freeing unused kernel memory: 8k initI see this is a developer image!
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Com>&BSta
rting player
empeg-car 1.01.
hda: read_intr: status=0x59 { DriveReady SeekComplete DataRequest Error }
hda: read_intr: error=0x40 { UncorrectableError }, LBAsect=140354, sector=7298
end_request: I/O error, dev 03:03 (hda), sector 7298
I'm not sure what this means or what to do at this point to fix the problem so any help is appreciated. Thanks,
Duane
