Page 2 of 2 < 1 2
#279010 - 11/04/2006 21:44 Re: Why does JEmplode run so slow??? [Re: bodybag]
Happy Birthday wfaulk
He responded to you just a few posts above in this thread with pretty detailed instructions.
#279011 - 12/04/2006 11:18 Re: Why does JEmplode run so slow??? [Re: wfaulk]
I can always post it again!
Connect with ftp and issue the following commands:
ftp xx.xx.xx.xx <----- player's IP address or DNS hostname
user: (hit enter)
password: (hit enter, unless you have set up a password)
site rw
cd /drive0
put set_empeg_max_fid.v7
site chmod 0755 set_empeg_max_fid.v7
site ro
quit
Connect with hyperterminal and then run:
cd /drive0
./set_empeg_max_fid.v7
Ask back here if you have a specific problem
#279012 - 13/04/2006 17:24 Re: Why does JEmplode run so slow??? [Re: JBjorgen]
bodybag
Loc: Southern California
Ouch... that was a major oversight on my part. Thanks for the instructions.
Bodybag - So Cal
Not a Whiner any more!!!
#279013 - 13/04/2006 17:46 Re: Why does JEmplode run so slow??? [Re: bodybag]
matthew_k
Another thought, do you have a lot of extraneous tags in your mp3s? Most (if not all) fields are stored in the database on the player. If that's enough to make jemplode perform poorly, I'm not sure.
#279014 - 13/04/2006 18:08 Re: Why does JEmplode run so slow??? [Re: matthew_k]
bodybag
FWIW, I reinstalled a fresh copy of Window XP with all the service packs and updates on this "Music Server" yesterday, and JEmplode runs much faster now. However, it's still not fast by any stretch of the imagination, just alot faster than before.
Also, it still drops the connection between JEmplode and the player pretty regularly.
Edited by bodybag (13/04/2006 18:17)
Bodybag - So Cal
#279015 - 14/04/2006 14:12 Re: Why does JEmplode run so slow??? [Re: bodybag]
bodybag
are these instructions the same for fidsift?
Bodybag - So Cal
#279016 - 15/04/2006 00:36 Re: Why does JEmplode run so slow??? [Re: bodybag]
Should be. I've installed neither, but if the scripts are well written (and I'd assume they are, knowing who wrote them), that should be all that's necessary.
Page 2 of 2 < 1 2
