Page 2 of 2 < 1 2
#279282 - 26/04/2006 11:44 Re: Hijack v454: Doh! might even work for SaveAux/RestoreSrc & waking [Re: jarob10]
You are right it is ambiguous, so I checked my CK-7W with an avo. The mute line is normally floating, then switches to ground when a call is made.
I had to use a pull-up resistor (hacked into the CK-7W harness) to get the empeg to recognise an incoming call.
Cool. But note that my CK-7W is working great without this mod. The 'Sense' section of the config.ini on my player contains this:
[sense]
muteaction=0
mute=-1
I presume this is the magic that makes it work.
#279283 - 26/04/2006 12:57 Re: Hijack v454: Doh! might even work for SaveAux/RestoreSrc & waking [Re: jarob10]
From what I saw while debugging this, it makes perfect sense (needing the pull-up, or pull-down as the case might be).
#279284 - 27/04/2006 07:13 Re: Hijack v454: Doh! might even work for SaveAux/RestoreSrc & waking [Re: mlord]
schofiel
The installation instructions for my Nokia CARK-9 kit recommended the use of a pull up.
Page 2 of 2 < 1 2
