Page 2 of 2 < 1 2
#28276 - 29/08/2001 09:40 Re: Selectable Volume Adjustment [Re: veixl]
Ok as i understand i can use the middle buttons to execute other programs or choose other options if i will change the settings in picker_list file. Any ideas what cool things can be done with them ?
Yes.
On mine, the four choices are:
Volume adjust OFF
Volume adjust ON
Play Tetris
Start Displayserver
You see, I've modified my init so that displayserver doesn't automatically launch at boot-up. So I only activate it when needed, from the front panel.
If you need more than four choices, I'll bet you could daisy-chain scripts.
There is also another selection program (I forgot who wrote it, sorry, anyone have a link?) that allows infinite choices because it does a left-right scroll-to-select. I chose to implement the single-button picker instead because it suited my needs best. But you could easily replace the picker script with this other selecter if you wanted.
#28277 - 29/08/2001 11:41 Re: Selectable Volume Adjustment [Re: tfabris]
veixl
Loc: Tartu, Estonia, Europe
How did you do it? Did you just removed the lines
cd /usr/local/displayserver
./displayserver -noauth
for testinit and added them to pick_list?
Is there any point using displayserver on MK1 without ethernet?
Veiko
[email protected]
MK1 #317 - 20GB green
Veiko [email protected] MK1 #317 - 20GB green
#28278 - 29/08/2001 13:19 Re: Selectable Volume Adjustment [Re: veixl]
That's correct, that's how I did it.
And you are also correct in that there's no point in using Displayserver on a Mk1, since it only runs via ethernet.
#28279 - 29/08/2001 19:10 Re: Selectable Volume Adjustment [Re: tfabris]
veixl
This font used in the picker menu looks quite ugly. Is it possible to use the same font that is used for empeg menu and info screens?
Veiko
[email protected]
#28280 - 30/08/2001 09:44 Re: Selectable Volume Adjustment [Re: veixl]
The font is hard-coded into the picker executable.
However, the source code is included in my "for dummies" distribution, and you are welcome to edit the font and re-compile it.
The file you want to change is called "font8x8.c"
#28281 - 31/08/2001 15:38 Re: Selectable Volume Adjustment [Re: veixl]
rexkp
Agreed, it isn't pretty but it was one I had kicking around from way back.
If you have a better fixed pitch font (that can be distributed freely) I would gladly incorporate it.
BTW, my web server is unaccessible thanks to AT&T's port 80 blocking. If they keep it up I'll move it.
Rex.
#28282 - 31/08/2001 17:01 Re: Selectable Volume Adjustment [Re: rexkp]
Whoa, REX!
Where ya been, buddy? I tried to get a hold of you when I first put together that file, and couldn't.
Thanks for publishing Picker for us to use, as you can see we've been having a field day with it.
#28283 - 01/09/2001 11:09 Re: Selectable Volume Adjustment [Re: tfabris]
Ah, I see. You DID reply to me back then, it was just during a period when my ISP was screwed up and the mail message bounced. (The old Open Relay problem.). Thanks.
#28284 - 04/01/2006 19:13 Re: Selectable Volume Adjustment [Re: tfabris]
edsmiata
Loc: New Jersey
Tony, Forgive me for digging up such an old post, but i recently installed Hijack and as i scroll through the menu the VolAdj option is made available.
Now what i want to know is do i have to go through the entire routine that you have so graciously provided, or am i in fact all ready to go...or how can i tell?
thanks,
Ed
#28285 - 04/01/2006 19:19 Re: Selectable Volume Adjustment [Re: edsmiata]
These old posts are from a long time ago before voladj was built in to hijack. Please ignore the entire routine above and merely use the menu that is built in to Hijack. Nothing in this thread applies any more.
#28286 - 04/01/2006 19:32 Re: Selectable Volume Adjustment [Re: tfabris]
edsmiata
Loc: New Jersey
Tony,
Thanks and good thing i asked!
Sooooo...now that that is settled what in fact do i do from the menu to get this option to work (please forgive my ignorance)
oh..and btw...i had our friends at eutronics take a look at my player and in fact found that one of the internal ground wires had a bad crimp!....i guess that was the problem with my install all along!
Ed
#28287 - 04/01/2006 19:39 Re: Selectable Volume Adjustment [Re: edsmiata]
Oh good, so no more ground loops in the Miata? Cool.
What you with voladj is select the amount of dynamic range compression you want: Off, Low, Medium, or High. That's all.
#28288 - 04/01/2006 19:41 Re: Selectable Volume Adjustment [Re: tfabris]
edsmiata
Loc: New Jersey
great..ill give it a try tonight!
Ed
#28289 - 04/01/2006 20:01 Re: Selectable Volume Adjustment [Re: edsmiata]
It also explains why it was intermittent, and why we were never able to reproduce it. I know you tried one of my players, and I tried yours in my sled at one point. I hate intermittent errors...
#28290 - 05/01/2006 11:22 Re: Selectable Volume Adjustment [Re: pgrzelak]
edsmiata
Loc: New Jersey
A pox on them and their families!
#28291 - 06/01/2006 16:23 Re: Selectable Volume Adjustment [Re: edsmiata]
edsmiata
Loc: New Jersey
sooooo, now i think that i am with it now that i have hijack and all...but today i got another surprise...i started the car up and a message stating "Happy Birthday Tony" pops up and stays there for 15 seconds or so....
anybody answer to this well wishing message....hmmmmm????
#28292 - 06/01/2006 18:34 Re: Selectable Volume Adjustment [Re: edsmiata]
Nothing ominious about it. Mark at certain points in the year makes the kernel print out messages based on the date as the empeg boots. If your clock in the empeg isn't set correctly then the message might not be correct.
#28293 - 09/01/2006 11:33 Re: Selectable Volume Adjustment [Re: tman]
edsmiata
Loc: New Jersey
ya...but my point is who programs in these messages!!!??!?!?
#28294 - 09/01/2006 12:13 Re: Selectable Volume Adjustment [Re: edsmiata]
errr - as trevor said, it is Mark
the guy who wrote the hijack kernel
#28295 - 09/01/2006 12:28 Re: Selectable Volume Adjustment [Re: frog51]
edsmiata
Loc: New Jersey
yes...of course!...also i had the date set to 4/8/2033!!!
#28296 - 09/01/2006 15:23 Re: Selectable Volume Adjustment [Re: edsmiata]
It must be a comfort to Tony to know he'll still be around then.
Page 2 of 2 < 1 2
