#283254 - 15/06/2006 21:01 No hard disk found
bumpi
Hello,
I have tried to upgrade the hard disks of my riocar Mark2 to a bigger hard disk, but the more I tried the bigger the trouble was. And now it's not possible to run the empeg even if I put back my old disk.
I have tried several disks from 10, 20, 40 to 80 GB but there is always no hard disk found. I also tried to change the IDE Cable of my old Mark 1 Player to the Mark 2 Player, but it helps nothing. The hard disk in my old player works fine and I could run the diskbuilderimage and the developerimage and everything is fine.
Could anybody see in my log what the problem is?
I'm trying now since Monday to reanimate my empeg!!!
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315
(release)) #20 Tue Jul 6 15:36:06 BST 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 10101748)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005400).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC35O030ATEA14-0! ! ! ! ! ! ! ! ! ! ! !, ATA DISK drive
hda: IC35O030ATEA14-0! ! ! ! ! ! ! ! ! ! ! !, 8063MB w/1934kB Cache, CHS=16383/1
6/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:d
4
Partition check:
hda: unknown partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
Thank you
Helli
#283255 - 15/06/2006 21:06 Re: No hard disk found [Re: bumpi]
Something is wrong with the hard disk cable. Quite possibly you may have pulled one of the connectors away from the ribbon cable, so that some of the wires are no longer making contact -- cable likely needs to be recrimped/replaced, or maybe just pushed more firmly into place at both ends.
#283256 - 15/06/2006 21:08 Re: No hard disk found [Re: mlord]
Or, if it's not the cable, then the IDE header (the 44-pin thingie) on the Empeg main board is damaged. This is a common failure, quite repairable in the right hands.
#283257 - 15/06/2006 21:23 Re: No hard disk found [Re: mlord]
bumpi
I think I've checked the cable because I took the one of my old Mark1, and I think they are compatible with the only difference that the Mark 1 has only one connector. Is that right?.
I've looked also at the IDE header but I can't see any damage on that as discribed in the FAQ at Riocar.org
Maybe I have to take look at this by a professional!
Thank you for quick response
Helli
#283258 - 15/06/2006 21:37 Re: No hard disk found [Re: bumpi]
If you were to flash it with the latest Hijack kernel, then we'd see more information about the failure..
#283259 - 15/06/2006 21:52 Re: No hard disk found [Re: mlord]
bumpi
Now I've flashed it with the following Kernel
"empeg-voladj.v200b3.mk2.zImage"
I hope this is right, and here is the code
javascript: x()
Code
e000 v1.04
Copying kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg49 (eparrl@mcpc34) (gcc version 2.95.2 19991
024 (release)) #20 Thu Oct 18 08:26:05 EST 2001
empeg state support initialised 0089/88c1 (save to d0005500).
6/63
4
Partition check:
Press Ctrl-A to enter pump...03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Helli
#283260 - 15/06/2006 22:14 Re: No hard disk found [Re: bumpi]
No, that's not a Hijack kernel.
Click on the Hijack link at the top of this page to visit the Hijack site, and pull down/install the v461.hijack.mk2.zImage file.
#283261 - 16/06/2006 01:42 Re: No hard disk found [Re: mlord]
bumpi
again with the right hijack kernel...
javascript: x()
Code
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v461 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Thu Jun 8 15:00:28 EDT 2006
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101748) 16MB DRAM
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Tuner: loopback=0, ID=-1
empeg state support initialised 0089/88c1 (save to d0005600).
ide_data_test: wrote 0x0000 read 0x0180
ide_data_test: wrote 0xffff read 0x0180
ide_data_test: wrote 0xaaaa read 0x0180
ide_data_test: wrote 0x5555 read 0x0180
ide_data_test: wrote 0x0000 read 0x0100
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xabaa
ide_data_test: wrote 0x5555 read 0x5555
6/63
4
Partition check:
Greetings Helli
#283262 - 16/06/2006 07:45 Re: No hard disk found [Re: bumpi]
Ewww... It looks like one of your data lines is tied high - either from cable damage or header damage...
Note that the last bit of the second byte is always a 1...
Inspect your cable very carefully, along with the header pins connecting to the main board. Also look for any damage on the cable or bent pins on the drive.
#283263 - 16/06/2006 09:49 Re: No hard disk found [Re: pgrzelak]
Yes. That's pin-6. For reference, pin-1 is the the dark stripe on one edge of the IDE cable.
#283264 - 16/06/2006 15:54 Re: No hard disk found [Re: mlord]
bumpi
Thank you for your posts,
but I can't find any loose pins on the IDE Conector even under magnification.
I have built the HD with the diskbuilder image on my Mark 1 and installed the consumer image and everything is fine.
Afterwards I took the HD with the same IDE Cable from my Mark 1 to my Mark2 and the following things appear on the log.
I hope the cable is compatible and the partition of the HD is also compatible between Mark 1 and Mark 2 ?
Maybe I should take the Motherboard out of the empeg and look under the back side if something is loose or would it help using Contact spray? Or could I take a gauge to measure the pins?
I have no other ideas.
Helli
#283265 - 16/06/2006 19:05 Re: No hard disk found [Re: bumpi]
There's that stuck data line again. Definitely hardware trouble with that unit.
Time to seek professional help, I think.
#283266 - 16/06/2006 19:15 Re: No hard disk found [Re: mlord]
More specifically, click on the word REPAIRS at the top of this page.
#283267 - 16/06/2006 20:55 Re: No hard disk found [Re: tfabris]
bumpi
OK
I've contacted empegrepair.com
Thank you for all your help!
There will be sunshine after rain.....
Helli
