#284134 - 07/07/2006 16:38
Problem with new Disk installation
Loc: Reading UK
Hi I have searched.
I am attempting a brand new disk install. I am at the step in the FAQ guide where the Disk Builder image is run. I get an error that says "error couldn't find pump".
The disk is in IDE0. I have recrimped the IDE0 and also tried the IDE1 location.
I tried installing V2.00 Developer, that went OK then followed with the Disk Builder, but the Disk Imager won't run still so I can't begin putting music onto the new disk.
Empeg V2 60GB running v3 (alpha 11) and the autoupdated hijack from jemplode.
#284135 - 07/07/2006 16:42
Re: Problem with new Disk installation
[Re: estocks]
Usual drill - serial log capture, post it here, blah blah
#284136 - 07/07/2006 16:42
[Re: estocks]
Is the disk more than 60 gig or so? If so, you'll need to manually format and partition it instead of using the disk builder image that is referenced in the drive upgrade guide. Roger's got some instructions somewhere.
EDIT: They're linked from the guide. Read the section entitled "Special note for large drives:".
Edited by JBjorgen (07/07/2006 16:45)
#284137 - 07/07/2006 17:10
[Re: JBjorgen]
Loc: Reading UK
It is s 60GB. @scofeil I connect to the player with HT after the fail and record empeg-car bootstrap v1.02 20001106 ( [email protected]) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace... empeg-car bootstrap v1.02 20001106 ( [email protected]) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace... empeg-car bootstrap v1.02 20001106 ( [email protected]) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it s empeg-car bootstrap v1.02 20001106 (hugo@empeg .com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace... empeg-car bootstrap v1.02 20001106 ( [email protected]) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...
#284138 - 07/07/2006 17:17
[Re: estocks]
Okay. Brand new drive. 60GB. Try this...
- Unplug the player. - Install disk builder, leaving the empeg OFF until the uploader says that it is trying to find the empeg. Once that happens, plug the empeg in. - Upload the disk builder software - As soon as the upgrade completes, and the empeg is rebooting, pull the plug on the empeg - Set up to capture a hyperterminal session - Plug the empeg in, capturing the session - Hit "enter" if you are asked to on console - When you see the disk stress test running, stop the capture and post it here. Leave the stress test running.
The intent of this is to a) load the builder software while b) capturing the output of the build to make sure it worked.
One the stress test has been running for a while, and if the output from the hyperterm session and build looks good, you will then load the developer software version of the player using the first three steps above.
#284139 - 07/07/2006 17:32
[Re: pgrzelak]
Loc: Reading UK
Riiight. The reboot (I.E: display relighting with the boot logos) was not happening before. Not realising that, I whipped the power just as the Kernel began flashing and recorded the If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace... message. I went through the upload again expecting to whip the power/click cancel just as the disk pump search began. This time the player lit up and found the disks all on its own, it is now pumping happily. I HTH the next person. Speaking too soon; thanks all is fine now ![](/ubbthreads/images/graemlins/laugh.gif)
#284140 - 07/07/2006 19:46
[Re: estocks]
Loc: Reading UK
Gah! Spoke too soon.
Emplode would not read the music database afer installing Developer V3.
The player does not reboot after the kernel is flashed with the Disk Builder.
Help!
Edited by estocks (07/07/2006 19:47)
#284141 - 07/07/2006 20:27
[Re: estocks]
Quote: Developer V3.
If you're having problems at all, don't use V3. V3 is alpha software and has bugs. Use V2 final.
#284142 - 07/07/2006 20:49
Loc: Reading UK
Overwrote v3 with V2.01 final but Emplode doesn't read the Media database. The player then reboots.
@pgrzelak Because the player does not reboot after the Disk Builder kernel is loaded I cannot get a log. It remains in the download state after the DC is removed and reinserted also.
Edited by estocks (07/07/2006 21:54)
#284143 - 07/07/2006 22:58
[Re: estocks]
It's possible that installing version 3 messed up the databases, since it uses a different database format. Also, make sure that your emplode is version 2.0 exactly, not any other version. If that doesn't work, then see if rebuilding the databases manually fixes the problem.
#284144 - 08/07/2006 00:05
[Re: estocks]
Help!
That's normal. After the disk builder has finished the "building" parts, it just loops doing tests until you shut it up. Install the normal car2-upgrade image now.
#284145 - 08/07/2006 07:30
Loc: Reading UK
@tfabris this is my log with V2.01 installed. I guess something is wrong with the file system Quote: empeg:/empeg/bin# rwm mount: /drive0 not mounted already, or bad option empeg:/empeg/bin# rm/drive0/var/database bash: rm/drive0/var/database: No such file or directory empeg:/empeg/bin# rm/drive0/var/database3 bash: rm/drive0/var/database3: No such file or directory empeg:/empeg/bin# rm/drive0/var/tags bash: rm/drive0/var/tags: No such file or directory empeg:/empeg/bin# dd if=/dev/zero of=/dev/hdc bs=1024 count=1024 dd: /dev/hdc: Device not configured empeg:/empeg/bin# fdisk -l /dev/hdc empeg:/empeg/bin# fdisk -l /dev/hdc empeg:/empeg/bin#
@mlord the disk doesn't reboot to pump the disks, and does not get to the testing stage.
#284146 - 08/07/2006 08:04
[Re: estocks]
Quote: @tfabris this is my log with V2.01 installed.
Copy-and-paste the commands from the FAQ. You're missing a whole heap of spaces in those commands.
But, also, your second disk doesn't seem to be being recognised (/dev/hdc: Device not configured), so you should attach a complete boot log. Instructions for that are in the FAQ, too.
#284147 - 08/07/2006 10:09
[Re: Roger]
Loc: Reading UK
@Roger, This is my boot log (I have one brand new 60GB WD disk in IDE0) Quote: empeg-car bootstrap v1.02 20001106 ([email protected]) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #20 Tue Jul 6 15:36:06 BST 2004 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read 9afffff0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101510) Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005e80). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: WDC WD600VE-75HDT1, 57231MB w/8192kB Cache, CHS=7296/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e6 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 VFS: Can't find an ext2 filesystem on dev ide0(3,4). Tried to mount /dev/hda4 as ext2 but got error 22 Error mounting partitions (possibly already mounted) Remounting first music partition read-only No primary hard disk Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To ComplůStarting player player.cpp : 385:empeg-car 2.01 2004/07/06. ! tags.cpp : 61:Failed to open tags (0xc0041002). Prolux 4 empeg car - 2.1434 Jul 5 2004 Vcb: 0x4086d000
I am fairly sure there is a problem with the Disk Builder Image section. It does not work like the FAQ says it will. It does not reboot the player before pumping the disk, like a player image does, and there is no way for me to get a Disk Builder log becasue of that.
Edited by estocks (08/07/2006 10:46)
#284148 - 08/07/2006 11:22
[Re: estocks]
That particular boot log is from a normal developer image, NOT from a builder image.
What are you trying to do, and what are you trying to show here?
#284149 - 08/07/2006 12:10
[Re: estocks]
Quote: VFS: Can't find an ext2 filesystem on dev ide0(3,4). Tried to mount /dev/hda4 as ext2 but got error 22 Error mounting partitions (possibly already mounted)
The disk builder didn't successfully format your music partition. This is a fairly common occurrence with larger disks. You should first retry the disk builder, which sometimes succeeds.
If that doesn't work, you'll have to format the partition yourself. Install a developer release, get to a shell prompt, and then follow the instructions on this page.
#284150 - 08/07/2006 12:35
[Re: Roger]
Loc: Reading UK
@mlord I have a single 60GB brand new disk I want to partition, format, and add a player image to. I cannot complete the Disk Builder image as it does not reboot the player at the Pump Hard Disk stage of the flashing. Unfortunatly a log is not possible as the player remains in the download state. It flashed once I thinght and so added a player image. It was V3, and Emplode V2.10 would not recognise the player database. I put on V2.01 Final and Emplode 2.0 and again it would not read the player database. @roger these are my logs from attempting a partiton followed by a format followed by a partition. They do not seem to be responding as the FAQ suggests. Quote: empeg:/empeg/bin# dd if=/dev/zero of=/dev/hdc bs=1024 count=1024 dd: /dev/hdc: Device not configured
Quote: empeg:/empeg/bin# mke2fs -m 0 -s 1 -i 131072 /dev/hdc4 mke2fs 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determining whether /dev/ hdc4 is mounted. mke2fs: Device not configured while trying to determine filesystem size
Quote: empeg:/empeg/bin# dd if=/dev/zero of=/dev/hdc bs=1024 count=1024 dd: /dev/hdc: Device not configured empeg:/empeg/bin#
#284151 - 08/07/2006 12:54
[Re: estocks]
Quote: I cannot complete the Disk Builder image as it does not reboot the player at the Pump Hard Disk stage of the flashing. Unfortunatly a log is not possible as the player remains in the download state.
That's because you're supposed to do it by having the player unplugged initially, and then by reapplying the power.
Also, my instructions assume that you're formatting a second disk, so if you want to format a single disk manually, you'll need to replace every instance of /dev/hdc with /dev/hda in those instructions.
#284152 - 08/07/2006 13:49
[Re: Roger]
Loc: Reading UK
I do start with the palyer unplugged and insert the power when instructed I am certain.Quote: Also, my instructions assume that you're formatting a second disk, so if you want to format a single disk manually, you'll need to replace every instance of /dev/hdc with /dev/hda in those instructions.
Here are the logs I captured.Quote: Starting bash. empeg:/empeg/bin# dd if=/dev/zero of=/dev/hda bs=1024 count=1024 1024+0 records in 1024+0 records out empeg:/empeg/bin# fdisk -l /dev/hda
Disk /dev/hda: 255 heads, 63 sectors, 7296 cylinders Units = cylinders of 16065 * 512 bytes
Disk /dev/hda doesn't contain a valid partition table empeg:/empeg/bin# fdisk /dev/hda Device contains neither a valid DOS partition table, nor Sun or SGI disklabel Building a new DOS disklabel. Changes will remain in memory only, until you decide to write them. After that, of course, the previous content won't be recoverable.
The number of cylinders for this disk is set to 7296. There is nothing wrong with that, but this is larger than 1024, and could in certain setups cause problems with: 1) software that runs at boot time (e.g., LILO) 2) booting and partitioning software from other OSs (e.g., DOS FDISK, OS/2 FDISK)
Command (m for help): n Command action e extended p primary partition (1-4) e Partition number (1-4): 1 First cylinder (1-7296, default 1): 1 Last cylinder or +size or +sizeM or +sizeK (1-7296, default 7296): +32M
Command (m for help): n Command action l logical (5 or over) p primary partition (1-4) p Partition number (1-4): 2 First cylinder (6-7296, default 6): Using default value 6 Last cylinder or +size or +sizeM or +sizeK (6-7296, default 7296): +32M
Command (m for help): n Command action l logical (5 or over) p primary partition (1-4) p Partition number (1-4): 3 First cylinder (11-7296, default 11): Using default value 11 Last cylinder or +size or +sizeM or +sizeK (11-7296, default 7296): +16M
Command (m for help): t Partition number (1-5): 3 Hex code (type L to list codes): 10 Changed system type of partition 3 to 10 (OPUS)
Command (m for help): n Command action l logical (5 or over) p primary partition (1-4) p Partition number (1-4): 4 First cylinder (14-7296, default 14): Using default value 14 Last cylinder or +size or +sizeM or +sizeK (14-7296, default 7296): Using default value 7296
Command (m for help): n First cylinder (1-5, default 1): Using default value 1 Last cylinder or +size or +sizeM or +sizeK (1-5, default 5): +16M
Command (m for help): n First cylinder (4-5, default 4): Using default value 4 Last cylinder or +size or +sizeM or +sizeK (4-5, default 5): Using default value 5
Command (m for help): t Partition number (1-6): 6 Hex code (type L to list codes): 82 Changed system type of partition 6 to 82 (Linux swap)
Command (m for help): p
Device Boot Start End Blocks Id System /dev/hda1 1 5 40131 5 Extended /dev/hda2 6 10 40162+ 83 Linux /dev/hda3 11 13 24097+ 10 OPUS /dev/hda4 14 7296 58500697+ 83 Linux /dev/hda5 1 3 24034+ 83 Linux /dev/hda6 4 5 16033+ 82 Linux swap
Command (m for help): w The partition table has been altered!
Calling ioctl() to re-read partition table. Re-read table failed with error 16: Device or resource busy. Reboot your system to ensure the partition table is updated.
WARNING: If you have created or modified any DOS 6.x partitions, please see the fdisk manual page for additional information. Syncing disks. empeg:/empeg/bin#
Then a reboot.Quote:
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #20 Tue Jul 6 15:36:06 BST 2004 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read 9afffff0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101510) Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004300). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: WDC WD600VE-75HDT1, 57231MB w/8192kB Cache, CHS=7296/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e 6 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:05
Display says No hard disk found contact support And I cant get to the command shell to format the disk.
#284153 - 08/07/2006 14:36
[Re: estocks]
Well, since the builder is already giving you troubles, could you please try this custom builder I have prepared for big disks, and see what it does (or doesn't do). Thanks.
#284154 - 08/07/2006 15:08
Loc: Reading UK
Quote: Well, since the builder is already giving you troubles, could you please try this custom builder I have prepared for big disks, and see what it does (or doesn't do).
Thanks.
The Disk Builder downloaded, rebooted and began pumping the disk first time thanks. It rebooted and ran the builder image for the first time.
Making /dev/hda4 filesystem Mounting... ** Some workds and a table flys by ** Spinning Down Spinning Up **Screen goes blank. Disk whirs on and off**
The Player V2.01 image is in and the database is being read with Emplode. Thanks guys.
#284155 - 08/07/2006 15:59
[Re: estocks]
Super. Happy Trails, then!
#284156 - 09/07/2006 22:19
[Re: estocks]
Wow.
I'm glad Mark's custom builder image worked for you, but I'm stymied as to why the factory builder image didn't behave as expected, unless you somehow got a corrupted file.
#284157 - 23/07/2006 21:29
I encountered the same problem, and this builder fixed the issue. The drive i'm using is a Fujitsu MHV2040AH (40GB 5400RPM). Thank you all for your help, the FAQ and this board have made everything go smoothly for me.
#284158 - 26/07/2006 15:39
[Re: Gize]
Same here, though with an IBM disk. Did the Disk Builder image get damaged during the restore of the site, perhaps?
#284159 - 26/07/2006 20:35
[Re: gbsallery]
Quote: Did the Disk Builder image get damaged during the restore of the site, perhaps?
No, the copy on the site is just fine. It just doesn't always work reliably with drives >= 40GB or so.
#284160 - 13/10/2006 15:12
Loc: Cincinnati, OH
I'm having the same problem with the stock builder. Mark's custom builder works fine, but I only have 20GB and 30GB drives. Will using Mark's builder be a problem with these smaller drives? Has anyone actually gotten the stock builder to work lately?
Jeff
Edited by JeffreyB (13/10/2006 15:34)
#284161 - 13/10/2006 15:37
[Re: JeffreyB]
Loc: Cincinnati, OH
Edited by JeffreyB (13/10/2006 16:00)
#284162 - 13/10/2006 17:01
[Re: JeffreyB]
Mark's builder should work fine, but I'm more worried about why you're the third person to report a problem with the stock builder.
Does the empeg support web site have a corrupted file by any chance?
#284163 - 15/10/2006 03:13
I was able to manually build a 120 GB drive and then I used the Big Disk Builder program for 5 other drives ( I have 3 Mk2s with 2 each 120 GB drives in them).
I have had success with both Hitachi and Toshiba drives. I have not mixed vendor drives in a Rio.
The builder works very well, good work.
