#284321 - 10/07/2006 21:31 Button LED kit - LED voltage?
Narkotic
I'm tired of searching...
I need to replace the button LED's on my player (long story). In 3mm size / white I can only find 3volt. I believe it's outputting 5volt at each pad? I'm at the office so I can't meter it.
If they are indeed 5 volt, got any links to where I can get some?
Thanks!
#284322 - 10/07/2006 22:55 Re: Button LED kit - LED voltage? [Re: Narkotic]
maczrool
Loc: Louisiana, USA
I believe the ones in the kit have a forward voltage of around 3.3 volts. If you are using the kit resistors and your LEDs have a lower forward voltage, you may need to adjust the resistor values so as not to overload the drive circuitry in the display board. If they are 3 volts it should be close enough though.
Hope this helps,
Stu
#284323 - 11/07/2006 03:41 Re: Button LED kit - LED voltage? [Re: maczrool]
Narkotic
Rock on, thanks Stu.
