#285524 - 16/08/2006 01:14 Question to Tony re: logoedit
accept
Loc: Queensland, Australia
Hi Tony,
Question about logoedit, can you change the com port to com5 or other number?
In "Select com port" choices are 1-4. and of course mine is on Com5.
Don't seem to be able to change my com port number allocation, and probably don't wanna (everything working fine now) took a while to get new computer config right and had to install a serial pci card also, and just upgraded to 100GB !!!
Thanks for any help
#285525 - 16/08/2006 10:45 Re: Question to Tony re: logoedit [Re: accept]
Just run LogoEdit, and select COM4, then *try* to send a logo (it will fail).
Next, close the program, and edit the LogoEdit.ini file it created, using notepad or wordpad.
Find the line "MyCOMPort=4", and change the 4 to a 5, and save the modified file.
Finally, run LogoEdit again. It should now be using COM5.
Edited by mlord (16/08/2006 10:45)
#285526 - 16/08/2006 11:46 Re: Question to Tony re: logoedit [Re: mlord]
Surely having Mark give advice on how to use a Windows app is one of the signs of the apocalypse
#285527 - 16/08/2006 17:12 Re: Question to Tony re: logoedit [Re: andy]
sn00p
Loc: South London
I wondered what those 4 horsemen were doing outside.....
#285528 - 16/08/2006 17:56 Re: Question to Tony re: logoedit [Re: mlord]
You sly devil, Mark. I didn't know that would even work. :-)
Anyway. Another way to get the same job done is to run UPLOAD.EXE by hand. Please look in the README.TXT file for instructions on how to do it. Flash memory addresses for kernels and logos are listed in the FAQ.
#285529 - 16/08/2006 18:18 Re: Question to Tony re: logoedit [Re: tfabris]
accept
thanks for the replies guys, will try as soon as possible.
thank you again !
#285530 - 16/08/2006 19:04 Re: Question to Tony re: logoedit [Re: accept]
accept
tried mark's idea but got the following error:-
Error: Incorrect parameters passed to upload.
-ERROR: Couldn't open com port. -
Press the Enter key to continue.
So no luck with that .
have yet to work out how to do Tony's method
#285531 - 16/08/2006 19:09 Re: Question to Tony re: logoedit [Re: accept]
Heh.. I thought the ice looked a little thin down there.
Edit - Fixed link. Links must contain http:// or they link to currentURL/url.tld
--_l0ser
Edited by l0ser (16/08/2006 23:52)
#285532 - 16/08/2006 19:21 Re: Question to Tony re: logoedit [Re: accept]
Yeah, OK, upload.exe is hard coded to accept the parameters 1-4 only.
If you've got a C compiler, you're welcome to fidget with it. Source code attached.
286126-upload.c (231 downloads)
#285533 - 18/08/2006 18:03 Re: Question to Tony re: logoedit [Re: tfabris]
accept
ok , so no other ideas?
trying to upload hijack that's all
don't have ethernet connection, only usb and serial on com5
#285534 - 18/08/2006 18:09 Re: Question to Tony re: logoedit [Re: accept]
Can you use [url=http://www.riocar.org/modules.php?op=modload&name=FAQ&file=index&myfaq=yes&id_cat=7&faqent=82#82hyperterminal to access the empeg's console[/url]? Just making sure that the serial port is working properly.
#285535 - 18/08/2006 18:20 Re: Question to Tony re: logoedit [Re: accept]
dr_dos
Loc: Bendorf, Germany
Why don't you just change the port # to something between 1 and 4? Device Manager -> Ports -> Properties -> Advanced -> COM Port Number
#285536 - 18/08/2006 18:38 Re: Question to Tony re: logoedit [Re: dr_dos]
Yeah, I'm with him. If you're not using both a modem and a serial mouse at the same time, then you should be able to safely set the com port to whatever you want.
Odds are, you don't even have a modem, and your mouse is USB.
#285537 - 19/08/2006 05:08 Re: Question to Tony re: logoedit [Re: tfabris]
If you can attach the source code in a form that's not mangled, it'd be easier to fidget with. Try a ZIP file.
#285538 - 19/08/2006 15:16 Re: Question to Tony re: logoedit [Re: Roger]
It doesn't look mangled to me. I clicked the attachment, and told firefox to save to disk. Opened in vim just fine. Unless, of course, you're calling Tony's coding standards mangled... in which case using a zip file isn't going to help much.
#285539 - 19/08/2006 16:08 Re: Question to Tony re: logoedit [Re: canuckInOR]
Well, keep in mind I only added a few lines to Hugo's prior code, so talk to him about standards.
#285540 - 19/08/2006 16:45 Re: Question to Tony re: logoedit [Re: canuckInOR]
I did the same in IE, and it comes out with no line endings in it, at all.
#285541 - 19/08/2006 18:23 Re: Question to Tony re: logoedit [Re: Roger]
Most likely it just has standard "newline" characters in it ('\n'). This is how just about every O/S in the world stores text files. Except for Microsoft OSs, which want a newline *and* a carriage-return (yes, the typewriter thing).
Try a cross-platform text editor (vim, gvim, emacs.. ) and see if that helps.
EDIT: Mmm.. looking at the file here, it seems to have both the newline and carriage-return characters in it. So perhaps your web-browser is being stupid.
Edited by mlord (19/08/2006 18:25)
#285542 - 19/08/2006 18:28 Re: Question to Tony re: logoedit [Re: mlord]
Just just now tried right-click-save-target-as with IE6 under WinXP, and the file is perfectly readable afterwards with Notepad and Wordpad.
#285543 - 20/08/2006 18:48 Re: Question to Tony re: logoedit [Re: tfabris]
Happy Birthday RobotCaleb
I'm pretty much a noob, but it compiled. In theory it may work. I didn't test it.
286276-upload-w5.zip (46 downloads)
#285544 - 20/08/2006 18:49 Re: Question to Tony re: logoedit [Re: RobotCaleb]
And the source. I only made a few changes. The first ones that jumped out at me, so I could be completely wrong.
286277-upload.c (143 downloads)
