#28573 - 25/03/2001 17:25 My Empeg won't boot... (problem solved)
Update
After opening my Empeg up and looking at the drives, I found the problem. The Master/Slave jumper had actually fallen off the slave drive. I had it on there pretty good, or so I thought. I'm going to use a little electrical tape to keep that sucker on. Anyway, if anyone else ever sees this, take a look at your jumpers. Don't know if this is FAQ-worthy or not, but maybe instructing people to tape down the jumper might save some benefit to others.
I'm so relieved that it's not something more serious. Whew!
I put my Empeg in my car today and it hung at the user logo, so when I got home, I plug it in and look at the serial output. I'm going to paste it in here and hope that someone has ideas about what has happened. It should be noted that the failure is disk drive related, and I installed a 2nd drive last week. It was running fine until today, however... Anyway if it doesn't sound like something I can fix, I might be emailing Empeg support and working through it there.. Just wanted to know if anyone else has ever seen this one. My initial guess is some problem with the ATA cable, or possibly the hard drive itself.. Sigh. My warranty is now gone so I sincerely hope this is something I can fix
empeg-car bootstrap v1.00 20000601 ([email protected])
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg41 (tonyc@spaz) (gcc version 2.95.2 19991024 (release)) #106 Tue Mar 20 12:24:51 EST 2001
empeg-car player (hardware revision 7, serial number 80000554)
Command line: mem=12m temp=19
Memory: 10920k/12M available (1048k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
NET4: Unix domain sockets 1.0 for Linux NET4.0.
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Logo type is 10
Scheduling custom logo.
empeg display initialised.
empeg dspaudio driver initialized
empeg infra-red support initialised.
IR old: 44298; IR new: 47380
IR old: 44299; IR new: 47381
IR old: 44355; IR new: 47371
IR old: 44354; IR new: 47370
IR old: 44306; IR new: 47454
IR old: 44314; IR new: 47391
IR old: -1072511612; IR new: -1073725640
IR old: -1072638032; IR new: -1073725652
IR old: -1073725580; IR new: -1072470296
empeg state support initialised 0089/88c1 (save to d0004280).
empeg single channel IDE
Probing primary interface...
hda: IBM-DKSA-238000, ATA DISK drive
hda: IBM-DKSA-238000, 15623MB w/2034kB Cache, CHS=16383/31/63
hda: INVALID GEOMETRY: 31 PHYSICAL HEADS?
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:02:2a
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hda: IBM-DKSA-238000, 15623MB w/2034kB Cache, CHS=16383/31/63hda: INVALID GEOMETRY: 31 PHYSICAL HEADS?
hda: driver not present
VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
-Tony
MkII #554
Edited by yn0t_ on 26/03/01 02:35 AM.
#28574 - 25/03/2001 17:59 Re: My Empeg won't boot... [Re: tonyc]
Just a guess, since I don't know linux error messages, but it sounds like hardware trouble.
First things first. Open the player and check the cabling. Then remove that second disk and see if it boots OK after that.
If so, plug the second drive back in and see if it magically boots (maybe a loose cable?). If not, unplug the first drive and re-format the second drive using Mike's builder upgrade. If that's successful, let it stresstest a while. If that's OK, then perhaps someone here can give advice on how to do a full surface scan of the drive?
#28575 - 26/03/2001 00:04 Re: My Empeg won't boot... (problem solved) [Re: tonyc]
schofiel
If a jumper is loose enough to fall off and needs to be taped in place, then it cannot be making electrical contact. I'd suggest you either crimp it so it grips better (depending on how it's made) or get a new one.
#28576 - 26/03/2001 04:18 Re: My Empeg won't boot... (problem solved) [Re: tonyc]
I don't think we've ever seen this before - it's certainly not a common problem.
#28577 - 26/03/2001 09:41 Re: My Empeg won't boot... (problem solved) [Re: tonyc]
Good catch. Maybe just bending the pins a little bit will help it make contact and stay on better?
#28578 - 26/03/2001 10:03 Re: My Empeg won't boot... (problem solved) [Re: tonyc]
SuperQ
Loc: Berlin, DE
looks to me like the second drive jumper isn't working right.. try disconnecting the second drive, and booting it without it. if that works.. it's the second drive not being a good boy and slaving to the first disk.
12gig red mk2 -- 080000125
80gig red mk2 -- 080000125
