#289914 - 17/11/2006 23:48 lightning strike - no hard disk found
Mr.Plow
I had a lightning strike that killed a bunch of my toys, including my empeg. I am getting a disk error.
I found a similar post in this forum hinting that there is a stuck bit on the IDE bus and that the ethernet chip may be the real problem. The suggestion was to lift the pin on the enthernet chip. I can do this easily at work next week, if I knew which chip was the correct one. Can someone post a picture for me and make any other suggestions?
thanks,
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v339 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Thu Jun 12 12:58:10 EDT 2003
empeg-car player (hardware revision 9, serial number 10102054)
Command line: mem=16m
Memory: 15016k/16M available (976k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=20)
empeg state support initialised 0089/88c1 (save to d0004a00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x0003
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
#289915 - 18/11/2006 00:01 Re: lightning strike - no hard disk found [Re: Mr.Plow]
I don't see anything in that boot log specifically indicating that your player has a "stuck bit on the ethernet chip".
The "No hard disk found" screen can be caused by a whole host of widely varying problems.
There is something wrong with a chip in your player, though:
Fortunately, as is indicated in the FAQ entry, you might be able to work around this issue by installing the latest version of Hijack.
I've gotta say, though, if you got a lightning strike that damaged the player, you got away lucky if the only thing wrong is the CS4231A chip. I'd be careful of other possible failures. For example, its external AC power supply might be fried. Check things out carefully.
#289916 - 18/11/2006 02:59 Re: lightning strike - no hard disk found [Re: Mr.Plow]
Upgrade your Hijack to the latest version, and then capture/post a new boot log from that.
#289917 - 26/11/2006 22:14 Re: lightning strike - no hard disk found [Re: mlord]
Mr.Plow
Okay, upgraded Hijack and have new boot log.
I have inspected ide connector for bad solder joints and tried the drive on the 2nd connector. Additionally, I have tried the drive out of my old laptop just to see if the empeg would recognize it.
I still have the hard drive error. I lost a router, ethernet switch, laptop, and computer all to the same lightning storm. My empeg symtoms sound similar to this post: http://empegbbs.com/ubbthreads/showflat.php/Cat/0/Number/285542/an/0/page/1#Post285542 (at least to my limited empeg knowledge) which is why i was thinking the ethernet controller.
Any help is greatly appreciated.
Thanks,
Mr.Plow
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v464 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Fri Oct 27 01:00:29 EDT 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10102054) 16MB DRAM
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Could not find CS4231A (version=20) --> no visuals for Tuner/AUX.
empeg state support initialised 0089/88c1 (save to d0004f00).
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
ide_data_test: wrote 0xffff read 0xff7f
ide_data_test: wrote 0xaaaa read 0xaa2a
ide_data_test: wrote 0x5555 read 0x5555
#289918 - 26/11/2006 22:36 Re: lightning strike - no hard disk found [Re: Mr.Plow]
The empeg's ethernet chip is fried, and unfortunately it is sticking D7 on the data bus that gets shared with the drive(s) and other devices.
If you don't need the ethernet (tunes uploading??), then you could just take an exacto knife and sever that one pin from the SMC ethernet chip, and the rest would probably work.
Otherwise, major chip-replacement surgery is required on the SMC ethernet chip.
#289919 - 27/11/2006 01:00 Re: lightning strike - no hard disk found [Re: mlord]
Mr.Plow
So which pin needs to be severed?
Any suggestions on where to get a replacement? I can get it installed at work. Anyone out there have a part number and source for a direct replacement?
Thanks again,
Mr.Plow
Edited by Mr.Plow (27/11/2006 01:14)
#289920 - 27/11/2006 01:31 Re: lightning strike - no hard disk found [Re: Mr.Plow]
maczrool
Loc: Louisiana, USA
D7 is pin 63. PM me if you would like a new chip. We have a few.
Hope this helps,
Stu
