#291076 - 03/12/2006 12:48 RMM keeps crashing
Never had it before but every time I try to upload a playlist it errors, no text in the error box, just a yellow and black exclamation mark. Next time it starts up it rescans, try to upload, same result...
I'm on Win2k with RMM 2.96
Any ideas?
#291077 - 03/12/2006 14:54 Re: RMM keeps crashing [Re: tahir]
rubennyc
Might be a corrupt database. Try deleting/renaming your database file and letting RMM rebuild from scratch. The file is called source0.db and should be in your "%userprofile%\Local Settings\Application Data\Rio\Rio Music Manager" folder.
#291078 - 03/12/2006 19:59 Re: RMM keeps crashing [Re: tahir]
I think this same problem was reported in another thread a long time ago. Can anyone with good search-fu supply a link?
#291079 - 04/12/2006 08:27 Re: RMM keeps crashing [Re: tfabris]
I'll try rebuilding the DB.
#291080 - 04/12/2006 08:34 Re: RMM keeps crashing [Re: tahir]
Just been looking through my playlists, the first playlist that comes up in RMM seems to have issues, if I go in to edit it I can't save changes, says it's in use by another application. I've deleted and recreated it and will try again
#291081 - 04/12/2006 08:46 Re: RMM keeps crashing [Re: tahir]
Deleted the DB, deleted the playlist, saved the new playlist to a different name (was 1 radio.m3u, now 1-radio.m3u) and still the same result.
Will search for the previous post
291511-1-radio.m3u (762 downloads)
#291082 - 04/12/2006 09:11 Re: RMM keeps crashing [Re: tahir]
The only even remotely odd thing about that playlist is that some of the files are listed as ".MP3" rather than ".mp3". Does it work if you change the extensions to lower-case?
#291083 - 04/12/2006 09:14 Re: RMM keeps crashing [Re: peter]
Will do, I've also stripped all the tags. I'm going to reboot too, just in case.
#291084 - 04/12/2006 11:09 Re: RMM keeps crashing [Re: tahir]
Must have been something to do with the files, unusually for me there were some files downloaded from the BBC in there, they had all sorts of tags including long comments, copyright and images. Stripped everything, redid the playlist, rebooted. All OK now.
#291085 - 04/12/2006 16:13 Re: RMM keeps crashing [Re: tahir]
So, based on this and the other thread that got popped-to-top recently, we now have two different known-causes for RMM crashing?
- Corrupted M3U playlists.
- MP3 files with huge garbage like pictures and stuff embedded in the tags.
Sound about right?
#291086 - 04/12/2006 16:21 Re: RMM keeps crashing [Re: tfabris]
Sound about right?
The bug in that other thread is fixed in 2.96.
#291087 - 04/12/2006 20:08 Re: RMM keeps crashing [Re: peter]
*nod* Thanks.
