#291088 - 03/12/2006 22:37 Document Indexer - Any ideas?
Mach
Loc: Texas, USA
I've got a 100 (or so) 50 page MS word documents. They're actually project proposals for software implementations. I'd like to index them in some smart way so that when our sales guys have to respond to a future proposal request they can easily search for how someone else has responded in a previous proposal without knowing in which document the response is in.
The challenge is that the documents are not the same in structure, questions, or actual response. They are similar so that you could say that page 2 paragraph 3 in document 1 is similar in intent to page 32 paragraph 5 and 6 of document 5.
First, is there a technology/name for what I'm trying to describe? Short of tagging each paragraph with key words, is there a way to do this, either manually or automatically? I'd really like to find a search tool that could be trained to say questions of type of A are connected to responses like type B.
I've done some googling but not exactly sure what to call what I'm looking for. Any ideas?
#291089 - 04/12/2006 00:10 Re: Document Indexer - Any ideas? [Re: Mach]
My first thought is to convert them all to PDF and then create a PDF catalog.
#291090 - 04/12/2006 01:19 Re: Document Indexer - Any ideas? [Re: wfaulk]
Mach
Loc: Texas, USA
Thanks Bitt! I need to upgrade my version of Acrobat but that should get me close.
#291091 - 04/12/2006 01:30 Re: Document Indexer - Any ideas? [Re: Mach]
cushman
Loc: Erie, CO
Indexing Word documents for plain search or natural language search is fairly easy, there are many packages commercial and open that will do this. I think what you are asking for is a way to identify concepts and relationships between segments of a document, say paragraphs that have 50+ words. I have only personally seen one software package that will do this, IBM's Content Discovery Server, formally iPhrase. The idea is that you can try to define "buckets" of concepts, and this software can sort incoming segments of text into those buckets. The downside is that it won't readily identify concepts outside of your defined set.
IBM also has donated an open source method for indexing concepts also, hosted at the Apache UIMA site. I haven't looked at this too closely, but it probably wouldn't be easy or fast to set up in a production system and have something useful.
Your best bet is probably a search engine that will index Word documents and perform some basic natural language search techniques, like word variants, spell checking and stemming. When your sales guys want other documents to look at, search through the previous ones with the same keywords and present snippets of the documents in the results so they can quickly find what they are looking for. Generally a commercial natural language search engine will perform better than any free one.
Mark Cushman
#291092 - 04/12/2006 02:10 Re: Document Indexer - Any ideas? [Re: Mach]
Even without a recent acrobat, ISTR you can do multi-file searches on a folder of PDFs for words/phrases using the free reader. Use the search button and you can select "all pdf documents in folder x".
You then get hyperlinked search results that open the right file to the right spot.
#291093 - 04/12/2006 02:11 Re: Document Indexer - Any ideas? [Re: cushman]
Mach
Loc: Texas, USA
Thanks Mark. I'll corner our web team tomorrow and see what's possible.
#291094 - 04/12/2006 02:13 Re: Document Indexer - Any ideas? [Re: Mach]
MarkH
This also sounds like something that would be used by other professional firms, especially lawyers. Maybe try searching for "legal document indexing archive" or some such ?
Regards
Mark
#291095 - 04/12/2006 07:26 Re: Document Indexer - Any ideas? [Re: Mach]
Anonymous
Unregistered
The correct course of action is to write up a project proposal in MS Word format describing a new software implementation that will categorize and index all previous project proposals. Once this project is given the greenlight, then you'll be able to easily find relevant project proposals in a timely manner. Oh, and go ahead and get those TPS reports on my desk by this afternoon. Thanks.
#291096 - 04/12/2006 13:08 Re: Document Indexer - Any ideas? [Re: cushman]
formally: following established rule
formerly: in the past
#291097 - 04/12/2006 14:11 Re: Document Indexer - Any ideas? [Re: wfaulk]
cushman
Loc: Erie, CO
I did mean formerly, and I am usually good about using the correct word. Whoops.
Their quiet good about indexing data, to.
Mark Cushman
#291098 - 04/12/2006 23:20 Re: Document Indexer - Any ideas? [Re: cushman]
Anonymous
Unregistered
too: also, in addition to, or indicating excessiveness
to: all other situations
quiet: little or no sound
quite: to a great extent
You did that on purpose, didn't you?
#291099 - 04/12/2006 23:30 Re: Document Indexer - Any ideas? [Re: ]
Did you miss their/they're on purpose?
#291100 - 04/12/2006 23:32 Re: Document Indexer - Any ideas? [Re: wfaulk]
Anonymous
Unregistered
LOL, no.
