Page 5 of 15 < 1 2 3 4 5 6 7 ... 14 15 >
#292810 - 08/03/2007 18:19 Re: We Have Lights! [Re: maczrool]
Try switching to R51 from R52. EDIT: Yes, we absolutely need this, I think.
Good call there Mark. The illumination kit is happy now over 20 feet of cable!
Great!
..figured it wouldn't matter because the receiving end is still limited to 256K isn't it?
That part is a bit unclear to me from reading the datasheet, but the impression I'm getting from re-reading it now, is that the 256K limit is just for the transmitters, not the receivers.
They give a different measurement for the receiver: 0.15us propagation delay, which means they should be good for at least 2mb/sec or so. EDIT: well, actually, that number mightn't even affect it, other than delaying things.. so the real limitation could be the 50ns receiver skew time. Still good for (a lot) more than 1mb/sec.
Edited by mlord (08/03/2007 18:23)
#292811 - 08/03/2007 21:57 Re: We Have Lights! [Re: maczrool]
Mach
Loc: Texas, USA
Aww yeah! Great work Mark and Stu! Any chance of seeing some pics?
#292812 - 08/03/2007 23:45 Re: We Have Lights! [Re: Mach]
maczrool
Loc: Louisiana, USA
Hope these will do. I never did post the back of the transmitter board, so here it is.
Stu
#292813 - 08/03/2007 23:47 Re: We Have Lights! [Re: maczrool]
maczrool
Loc: Louisiana, USA
The top view.
Stu
#292814 - 08/03/2007 23:48 Re: We Have Lights! [Re: maczrool]
maczrool
Loc: Louisiana, USA
Side view.
Stu
#292815 - 08/03/2007 23:49 Re: We Have Lights! [Re: maczrool]
maczrool
Loc: Louisiana, USA
Front with buttons lit.
Stu
#292816 - 08/03/2007 23:50 Re: We Have Lights! [Re: maczrool]
maczrool
Loc: Louisiana, USA
Angle view with lights.
Stu
#292817 - 08/03/2007 23:53 Re: We Have Lights! [Re: maczrool]
Mach
Loc: Texas, USA
Very nice, when are they shipping?
#292818 - 09/03/2007 00:20 Re: We Have Lights! [Re: maczrool]
Mmmmm... that's just begging for a custom black walnut fascia.
And without a handle in the way, wooden fascias can be a lot less fragile now!
#292819 - 09/03/2007 00:22 Re: We Have Lights! [Re: Mach]
maczrool
Loc: Louisiana, USA
Was thinking about that today. I've yet to find the correct sized rivet to fit the regulator. I've got the diameter down, but they are still too short. I think the third time's the charm. Of course if you don't care about the rivets, they are more or less ready to go.
Stu
#292820 - 09/03/2007 00:46 Re: We Have Lights! [Re: maczrool]
Mach
Loc: Texas, USA
Ermm, as I don't know the import of said rivets, I think I'll wait.
#292821 - 09/03/2007 00:50 Re: We Have Lights! [Re: mlord]
Mach
Loc: Texas, USA
I'm with you on that one. Not having to match the handle opens up a wide range of possibilities. I've got stack of quarter inch acrylic, as well as a 2x4 magnifying glass that has me thinking.
#292822 - 09/03/2007 01:09 Re: We Have Lights! [Re: maczrool]
Isn't it about the same as those from PCATS tuner kits?
There might be part number floating around for those..
#292823 - 09/03/2007 01:37 Re: We Have Lights! [Re: mlord]
maczrool
Loc: Louisiana, USA
Should be exactly the same. I've not come across a part number though. The problem is that the listed size panel for which they are intended is a but misleading. Even after careful measurement they just didn't fit as expected. We're having to buy ones quite a bit narrower and longer than the actual hole dimensions. Anyway I'm fairly certain I have a part number that works through my own trial and error. Once everything is verified I'll post a revised parts list for anyone wanting to tackle this one on their own.
Stu
#292824 - 09/03/2007 02:16 Re: We Have Lights! [Re: maczrool]
Happy Birthday larry818
Why not just use a screw and nyloc nut? 4-40 x 3/8 should fit it.
www.mcmaster.com
91831A005 nyloc nut
91772A108 screw
What I do is to use a 0.093” plated thru hole and drive the 4-40 x ¼ screw into that. Too late here, but maybe next time.
#292825 - 09/03/2007 02:20 Re: We Have Lights! [Re: maczrool]
MarkM
Loc: Seattle, WA USA
Nice! Glad it all worked out. Making a new front facia would be nice since the handle doesn't apply. Walnut - now that would match my Mini.
I had a weird thought this morning. I've worked with the empeg for hundreds of hours and I don't even own one. I don't even own an MP3 player! Go figure...
Now that I think of it, I think Patrick who designed the thing didn't own an empeg player until many years after they were released.
Good job Stu!
#292826 - 09/03/2007 12:31 Re: We Have Lights! [Re: larry818]
maczrool
Loc: Louisiana, USA
Thanks for the suggestion. I thought about that, and still might try it if I can't get the proper rivets. The advantage of the rivets is that they don't require any tools to install and also are nonconductive if they should fall out.
Stu
#292827 - 09/03/2007 12:54 Re: We Have Lights! [Re: maczrool]
There's a fastener shop just a short ski trek (or bicycle ride in summer) away from here, which stocks things like this. I might pay them a visit later today..
#292828 - 09/03/2007 19:14 Re: We Have Lights! [Re: maczrool]
Stu
With the nyloc nut, they won't fall out.
#292829 - 11/03/2007 14:09 Re: We Have Lights! [Re: maczrool]
FireFox31
Loc: East Coast, USA
Yea, good work on the lights Stu and Mark, and also thanks to MarkM, Patrick, and all others for creating this. Remote VFD on a slimline CF empeg could open worlds of possibilities. Great to see this device still having new life after all these years. Let's put those Sirius / XM suction cup mount installs to shame!
FireFox31
#292830 - 11/03/2007 21:08 Re: We Have Lights! [Re: FireFox31]
MarkM
Wow, those adapters are pretty cool. The relatively low cost of memory is amazing. When the empegs first came out I looked into solid state drives and it was about $1000 a GB, so for 30GB it was $30k. Now 2 16GB CF cards would run about $600.
#292831 - 13/03/2007 06:32 Re: We Have Lights! [Re: MarkM]
iank
Is it too late to get in on any sort of list for one of these?
#292832 - 13/03/2007 11:17 Re: We Have Lights! [Re: iank]
maczrool
Loc: Louisiana, USA
I'll add you to the list. I guess you want one? You would be well into the second run, which I'm not even sure will happen but if it does, you are set.
1-MarkM (2)
2-Mach (2)
3-caseyse (2)
4-juenk (1)
5-EtN (1)
6-music (1)
7-jarob10 (1)
8-JimHogan (1)
9-TigerJimmy (1)
10-brabax22 (1)
11-pgrzelak (2?)
12-iank (1?)
#292833 - 13/03/2007 14:24 Re: We Have Lights! [Re: maczrool]
maczrool
Loc: Louisiana, USA
Per request, thirdeyevision has been added to the list.
1-MarkM (2)
2-Mach (2)
3-caseyse (2)
4-juenk (1)
5-EtN (1)
6-music (1)
7-jarob10 (1)
8-JimHogan (1)
9-TigerJimmy (1)
10-brabax22 (1)
11-pgrzelak (2?)
12-iank (1?)
13-thirdeyevision (1?)
We are at 17 sets now. If everyone in the list is definitely buying the number in the list, we only need 3 more sets to MAYBE make a second run. The first run will probably start shipping this week and trickle out as I build them.
Stu
#292834 - 13/03/2007 23:35 Re: We Have Lights! [Re: maczrool]
I put a me too in a while back. Guess it didn't register. Please Please add me too. edit: 1 unit.
Edited by gbeer (13/03/2007 23:36)
#292835 - 14/03/2007 00:30 Re: We Have Lights! [Re: gbeer]
maczrool
Loc: Louisiana, USA
Hi Glenn,
Sorry about that. I've put you in the proper chronological order.
1-MarkM (2)
2-Mach (2)
3-caseyse (2)
4-juenk (1)
5-EtN (1)
6-music (1)
7-jarob10 (1)
8-JimHogan (1)
9-TigerJimmy (1)
10-brabax22 (1)
11-pgrzelak (2?)
12-gbeer (1)
13-iank (1?)
14-thirdeyevision (1?)
That makes 18. Only 2 more.
Stu
#292836 - 14/03/2007 07:35 Re: We Have Lights! [Re: maczrool]
julf
OK, OK, I'll go for one.
#292837 - 14/03/2007 10:14 Re: We Have Lights! [Re: julf]
maczrool
Loc: Louisiana, USA
1-MarkM (2)
2-Mach (2)
3-caseyse (2)
4-juenk (1)
5-EtN (1)
6-music (1)
7-jarob10 (1)
8-JimHogan (1)
9-TigerJimmy (1)
10-brabax22 (1)
11-pgrzelak (2?)
12-gbeer (1)
13-iank (1?)
15-julf (1)
One to go!
Stu
#292838 - 14/03/2007 15:16 Re: We Have Lights! [Re: maczrool]
I'm SOOO tempted. But I don't need one right now, my empeg is just fine in the dash where it belongs. But someday I may own a car where that's not possible. And I don't want to miss out if this is gonna be all there is.
What are the chances of future batches, if my theoretical future need comes to pass?
#292839 - 14/03/2007 15:31 Re: We Have Lights! [Re: tfabris]
maczrool
Loc: Louisiana, USA
I'd say pretty good. If we make a second run of PCBs, it might make sense to order an extra 4 or 5 PCB sets for just in case situations. I might want one some day too afterall.
Maybe you could buy just the PCBs and hold on to it for insurance purposes? Everything else is off-the-shelf parts with the exception of the display cable on one end and the ribbon in between, but it shouldn't be too hard to make or buy either of those.
Stu
