#293977 - 19/02/2007 01:45 Pump error, voltage issue?
jasonc
I'm trying to install a new hard drive into my trusty ol' empeg. It's a Toshiba MK6025GAS . I read somewhere someone else was having the exact same issue with a similar model drive, but no resolution was posted.
As it stands, I've verified it's not the cable. I can plug my old drive in and it starts right up, but the new drive i get some odd behaviour. I've tried all the vaious builder.upgrade images.
1. No matter what i do the drive is recognized as hdb. even forcing the master jumper, it still comes up hdb.
2. IRQ error:
hdb: TOSHIBA MK6025GAS, ATA DISK drive0x5411mp v0
empeg single channel IDE
ide0: unexpected interrupt, status=0xff, count=1
hdb: TOSHIBA MK6025GAS, 57231MB w/0kB Cache, CHS=7296/255/63
which prolly leads to
3. final failure:
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
I noticed that the voltage on the new drive is dc+5v 0.7a and the old one is dc+5v .55a
is that the issue? am i better off selling this drive, and getting a new one that has been proven to work?
I've long since replaced the original wallwart with new ones that were recommended from this board a few years ago...
#293978 - 19/02/2007 02:28 Re: Pump error, voltage issue? [Re: jasonc]
Nothing there to worry about. Something different must be the matter.
#293979 - 19/02/2007 02:31 Re: Pump error, voltage issue? [Re: jasonc]
2. IRQ error:
Is this the only drive connected?
If so, then:
(1) the jumper is wrong (despite your efforts). Usually, no jumper is installed/required for a master (hda) drive.
Or (2) the cable/connectors are defective, resulting in the master/slave bit not being seen by the empeg. Highly unlikely here.
Or (3) Toshiba drives are weird. (dunno)
Edited by mlord (19/02/2007 02:32)
#293980 - 19/02/2007 03:58 Re: Pump error, voltage issue? [Re: mlord]
jasonc
If so, then:
Yep, its the only drive. i've tried with and without jumpers, same thing. Which pin is the master/slave bit? I did have to resolder a few of the pins where the ide connector attaches to the board. I didn't assume this to be a possibilty due the the fact the old drive works fine. I guess I'll see if i can't swap drives with someone.
