Page 2 of 2 < 1 2
#294740 - 09/03/2007 21:49 Re: Need Help - Problem with used Empeg [Re: maczrool]
It would still leave him with a system with no tunes or playlists.
Right, but since he recently bought it off eBay I am assuming he has not yet gotten any tunes or playlists on it.
Stu
Right, which would mean that he has a system with no tunes or playlists, thus the possible issue with Emplode.
#294741 - 09/03/2007 22:12 Re: Need Help - Problem with used Empeg [Re: brax]
Looks like when I type in player -i it ups the volume.
Ah. I'll bet you didn't install the developer 2.0 version of the player firmware. You installed the consumer version, so pressing Ctrl-C didn't drop you back to a bash prompt. Sorry, we should have told you that.
Install the developer 2.0 version of the player firmware, Search the FAQ for "Hyperterminal" and use the instructions therein to get us a full boot log. The one you posted above wasn't complete.
Mark, I don't believe his problem has anything to do with zero tunes or zero playlists. Emplode should work fine in that state.
#294742 - 09/03/2007 23:22 Re: Need Help - Problem with used Empeg [Re: brax]
AndrewT
Loc: Oxford, UK
I had similar problems recently while trying to install a single 80GB drive. My head is bunged up with Man Flu at the moment, nevertheless, I'll try and suggest something worthwhile for you to check....
Using Hyperterminal etc. get to a Bash prompt and run 'fdisk'. Type p<return> and copy/paste the output in here. You should see something like: Code:
Disk /dev/hdc: 16 heads, 63 sectors, 23392 cylinders
Units = cylinders of 1008 * 512 bytes
Device Boot Start End Blocks Id System
/dev/hdc1 1 66 33232+ 5 Extended
/dev/hdc2 67 132 33264 83 Linux
/dev/hdc3 133 165 16632 10 OPUS
/dev/hdc4 166 23392 11706408 83 Linux
/dev/hdc5 1 33 16569 83 Linux
/dev/hdc6 34 66 16600+ 82 Linux swap
... except that, and ISTR, yours should read "hda" instead of "hdc". The numbers will also be different but the overall partition structure should be the same.
#294743 - 09/03/2007 23:34 Re: Need Help - Problem with used Empeg [Re: tfabris]
brax
Loc: Birmingham, AL
Sorry guys had to wait till the kids went to bed before I could play with the empeg.
Anyway, well as a quick try I tried JEmplode. I am only able to see it through ethernet. It doesn't crash on me but doesn't let me do anything either. I was able to create a play list but when I sync it's not there. When I try to import a tune fails to import it and says that it is because of insufficientspace.
The guy that I bought it from said that he used Linux to transfer songs over. Would this make any difference?
Well I am know putting the developer software on to get a full bootlog.
#294744 - 10/03/2007 00:57 Re: Need Help - Problem with used Empeg [Re: tfabris]
brax
Loc: Birmingham, AL
Ok I installed developer v2.01 and here was the complete boot log from the hyperterminal.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315
(release)) #20 Tue Jul 6 15:36:06 BST 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 30102880)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005a00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:4
0
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
player.cpp : 385:empeg-car 2.01 2004/07/06.
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4086d000
#294745 - 10/03/2007 01:34 Re: Need Help - Problem with used Empeg [Re: AndrewT]
brax
Loc: Birmingham, AL
Ok here is what I get when I run the following fdisk. I was unable to get anything with a 'p' to work. More then likely I was typing it wrong. Sorry not a code guru.
empeg:/empeg/bin# fdisk /dev/hda
The number of cylinders for this disk is set to 58140.
There is nothing wrong with that, but this is larger than 1024,
and could in certain setups cause problems with:
1) software that runs at boot time (e.g., LILO)
2) booting and partitioning software from other OSs
(e.g., DOS FDISK, OS/2 FDISK)
#294746 - 10/03/2007 01:57 Re: Need Help - Problem with used Empeg [Re: brax]
Ah. Much better, thanks.
Now, two more commands to dump out for us:
cat /proc/partitions
..and..
ls -lR /
Edited by mlord (10/03/2007 01:58)
#294747 - 10/03/2007 02:06 Re: Need Help - Problem with used Empeg [Re: mlord]
brax
Loc: Birmingham, AL
..and..
ls -lR /
empeg:/empeg/bin# cat /proc/partitions
major minor #blocks name
3 0 29302560 hda
3 1 1 hda1
3 2 33264 hda2
3 3 16632 hda3
3 4 29219400 hda4
3 5 16569 hda5
3 6 16600 hda6
ls -lR / goes beyond the hyperterminal limit as I can not scoll back up to the get all of it.
But I get this from just ls -lR incase it is useful
empeg:/empeg/bin# ls -lR
total 1330
-rwxr-xr-x 1 0 0 1171 Jul 6 2004 d
-rwxr-xr-x 1 0 0 117 Jul 6 2004 g
-rwxr-xr-x 1 0 0 1351356 Jul 6 2004 player
Edited by brax (10/03/2007 02:14)
#294748 - 10/03/2007 02:28 Re: Need Help - Problem with used Empeg [Re: brax]
Either find a better program, then, or figure out how to log a session in hyperterm.
You 'll find it very useful to solve this issue, later on.
I solve it by not using MS Windows at all.
total 1330
Not useful.
But, perhaps this subset could be:
ls -lR /drive0
Edited by mlord (10/03/2007 02:28)
#294749 - 10/03/2007 02:43 Re: Need Help - Problem with used Empeg [Re: mlord]
brax
Loc: Birmingham, AL
total 1330
Not useful.
ls -lR /drive0
Ok sorry didn't know if you needed it all or just a certain part of it. Anyway I left out the "/" and had gotten the other info which didn't look like much to me.
Here is the full dump from ls -lR /drive0
ls -lR /drive0
/drive0:
total 40
drwxr-xr-x 9 0 0 4096 Oct 12 2002 Blues
drwxr-xr-x 12 0 0 4096 Oct 11 2002 Classical
drwxr-xr-x 10 0 0 4096 Oct 12 2002 Italian
drwxr-xr-x 13 0 0 4096 Oct 11 2002 Jazz
drwxr-xr-x 13 0 0 4096 Oct 12 2002 Rock
drwxr-xr-x 2 0 0 16384 May 12 2001 lost+found
drwxr-xr-x 2 0 0 4096 Mar 9 23:58 var
/drive0/Blues:
total 28
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Johnny A
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Keb Mo
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Luck Of The Draw
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Norah Jones
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Shuggie Otis
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Susan Tedeschi
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Wander This World
/drive0/Blues/Johnny A:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Sometime Tuesday Morning
/drive0/Blues/Johnny A/Sometime Tuesday Morning:
total 67704
-rw-r--r-- 1 0 0 6354320 Oct 11 2002 Johnny A-01-Sometime Tuesday Morning.mp3
-rw-r--r-- 1 0 0 6121098 Oct 11 2002 Johnny A-02-Oh Yeah.mp3
-rw-r--r-- 1 0 0 5795717 Oct 11 2002 Johnny A-03-Wichita Lineman.mp3
-rw-r--r-- 1 0 0 7457732 Oct 11 2002 Johnny A-04-Two Wheel Horse.mp3
-rw-r--r-- 1 0 0 6687224 Oct 11 2002 Johnny A-05-In The Wind.mp3
-rw-r--r-- 1 0 0 4747476 Oct 11 2002 Johnny A-06-Yes It Is.mp3
-rw-r--r-- 1 0 0 5133670 Oct 11 2002 Johnny A-07-You Don't Love Me.mp3
-rw-r--r-- 1 0 0 4674124 Oct 11 2002 Johnny A-08-Up In The Attic.mp3
-rw-r--r-- 1 0 0 4206427 Oct 11 2002 Johnny A-09-Walk Don't Run.mp3
-rw-r--r-- 1 0 0 3769451 Oct 11 2002 Johnny A-10-Tex Critter.mp3
-rw-r--r-- 1 0 0 7822610 Oct 11 2002 Johnny A-11-Lullabye For Nicole.mp3
-rw-r--r-- 1 0 0 6403848 Oct 11 2002 Johnny A-12-Walkin' West Ave..mp3
/drive0/Blues/Keb Mo:
total 62056
-rw-r--r-- 1 0 0 4338085 Oct 11 2002 Keb' Mo' - Keb Mo 01 Every Morning.mp3
-rw-r--r-- 1 0 0 4560648 Oct 11 2002 Keb' Mo' - Keb Mo 02 Tell Everybody I Know.mp3
-rw-r--r-- 1 0 0 4373193 Oct 11 2002 Keb' Mo' - Keb Mo 03 Love Blues.mp3
-rw-r--r-- 1 0 0 4834620 Oct 11 2002 Keb' Mo' - Keb Mo 04 Victims Of Comfort.mp3
-rw-r--r-- 1 0 0 5451528 Oct 11 2002 Keb' Mo' - Keb Mo 05 Angelina.mp3
-rw-r--r-- 1 0 0 4235267 Oct 11 2002 Keb' Mo' - Keb Mo 06 Anybody Seen My Girl.mp3
-rw-r--r-- 1 0 0 5024583 Oct 11 2002 Keb' Mo' - Keb Mo 07 She Just Wants To Dance.mp3
-rw-r--r-- 1 0 0 3359433 Oct 11 2002 Keb' Mo' - Keb Mo 08 Am I Wrong.mp3
-rw-r--r-- 1 0 0 5991322 Oct 11 2002 Keb' Mo' - Keb Mo 09 Come On In My Kitchen.mp3
-rw-r--r-- 1 0 0 4523658 Oct 11 2002 Keb' Mo' - Keb Mo 10 Dirty Low Down And Bad.mp3
-rw-r--r-- 1 0 0 5734904 Oct 11 2002 Keb' Mo' - Keb Mo 11 Don't Try To Explain.mp3
-rw-r--r-- 1 0 0 5035240 Oct 11 2002 Keb' Mo' - Keb Mo 12 Kindhearted Woman Blues.mp3
-rw-r--r-- 1 0 0 5910447 Oct 11 2002 Keb' Mo' - Keb Mo 13 City Boy.mp3
/drive0/Blues/Luck Of The Draw:
total 75724
-rw-r--r-- 1 0 0 5460932 Oct 11 2002 Bonnie Raitt-01-Something To Talk About.mp3
-rw-r--r-- 1 0 0 5107965 Oct 11 2002 Bonnie Raitt-02-Good Man, Good Woman.mp3
-rw-r--r-- 1 0 0 7978718 Oct 11 2002 Bonnie Raitt-03-I Can't Make You Love Me.mp3
-rw-r--r-- 1 0 0 7027025 Oct 11 2002 Bonnie Raitt-04-Tangled And Dark.mp3
-rw-r--r-- 1 0 0 6251502 Oct 11 2002 Bonnie Raitt-05-Come To Me.mp3
-rw-r--r-- 1 0 0 6354320 Oct 11 2002 Bonnie Raitt-06-No Business.mp3
-rw-r--r-- 1 0 0 7346137 Oct 11 2002 Bonnie Raitt-07-One Part Be My Lover.mp3
-rw-r--r-- 1 0 0 7296609 Oct 11 2002 Bonnie Raitt-08-Not The Only One.mp3
-rw-r--r-- 1 0 0 3922424 Oct 11 2002 Bonnie Raitt-09-Papa Come Quick (Jody and Chico).mp3
-rw-r--r-- 1 0 0 5746189 Oct 11 2002 Bonnie Raitt-10-Slow Ride.mp3
-rw-r--r-- 1 0 0 7615720 Oct 11 2002 Bonnie Raitt-11-Luck Of The Draw.mp3
-rw-r--r-- 1 0 0 7269650 Oct 11 2002 Bonnie Raitt-12-All At Once.mp3
/drive0/Blues/Norah Jones:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Come Away with Me
/drive0/Blues/Norah Jones/Come Away with Me:
total 106088
-rw-r--r-- 1 0 0 7450209 Oct 11 2002 Norah Jones-01-Don't Know Why.mp3
-rw-r--r-- 1 0 0 5813898 Oct 11 2002 Norah Jones-02-Seven Years.mp3
-rw-r--r-- 1 0 0 8747972 Oct 11 2002 Norah Jones-03-Cold Cold Heart.mp3
-rw-r--r-- 1 0 0 7099123 Oct 11 2002 Norah Jones-04-Feelin' The Same Way.mp3
-rw-r--r-- 1 0 0 7932952 Oct 11 2002 Norah Jones-05-Come Away With Me.mp3
-rw-r--r-- 1 0 0 9477311 Oct 11 2002 Norah Jones-06-Shoot The Moon.mp3
-rw-r--r-- 1 0 0 6195286 Oct 11 2002 Norah Jones-07-Turn Me On.mp3
-rw-r--r-- 1 0 0 7447074 Oct 11 2002 Norah Jones-08-Lonestart.mp3
-rw-r--r-- 1 0 0 10136641 Oct 11 2002 Norah Jones-09-I've Got To See You Again.mp3
-rw-r--r-- 1 0 0 6485768 Oct 11 2002 Norah Jones-10-Painter Song.mp3
-rw-r--r-- 1 0 0 7433490 Oct 11 2002 Norah Jones-11-One Flight Down.mp3
-rw-r--r-- 1 0 0 10091711 Oct 11 2002 Norah Jones-12-Nightingale.mp3
-rw-r--r-- 1 0 0 6595482 Oct 11 2002 Norah Jones-13-The Long Day Is Over.mp3
-rw-r--r-- 1 0 0 7513947 Oct 11 2002 Norah Jones-14-The Nearness Of You.mp3
/drive0/Blues/Shuggie Otis:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Inspiration Information
/drive0/Blues/Shuggie Otis/Inspiration Information:
total 65448
-rw-r--r-- 1 0 0 5046943 Oct 11 2002 01_Inspiration Information.mp3
-rw-r--r-- 1 0 0 5628429 Oct 11 2002 02_Island Letter.mp3
-rw-r--r-- 1 0 0 7160249 Oct 11 2002 03_Sparkle City.mp3
-rw-r--r-- 1 0 0 5122176 Oct 11 2002 04_Aht Uh Mi Hed.mp3
-rw-r--r-- 1 0 0 1530862 Oct 11 2002 05_Happy House.mp3
-rw-r--r-- 1 0 0 3249196 Oct 11 2002 06_Rainy Day.mp3
-rw-r--r-- 1 0 0 2574192 Oct 11 2002 07_XL-30.mp3
-rw-r--r-- 1 0 0 5370862 Oct 11 2002 08_Pling!.mp3
-rw-r--r-- 1 0 0 3020886 Oct 11 2002 09_Not Available.mp3
-rw-r--r-- 1 0 0 4778405 Oct 11 2002 10_Strawberry Letter 23.mp3
-rw-r--r-- 1 0 0 4855727 Oct 11 2002 11_Sweet Thang.mp3
-rw-r--r-- 1 0 0 3004168 Oct 11 2002 12_Ice Cold Daydream.mp3
-rw-r--r-- 1 0 0 15518388 Oct 11 2002 13_Freedom Flight.mp3
/drive0/Blues/Susan Tedeschi:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Wait For Me
/drive0/Blues/Susan Tedeschi/Wait For Me:
total 64348
-rw-r--r-- 1 0 0 6287237 Oct 11 2002 Susan Tedeschi - Wait For Me 01 Alone.mp3
-rw-r--r-- 1 0 0 6338019 Oct 11 2002 Susan Tedeschi - Wait For Me 02 Gonna Move.mp3
-rw-r--r-- 1 0 0 4417079 Oct 11 2002 Susan Tedeschi - Wait For Me 03 Wrapped In The Arms Of Another.mp3
-rw-r--r-- 1 0 0 5099188 Oct 11 2002 Susan Tedeschi - Wait For Me 04 'Til I Found You.mp3
-rw-r--r-- 1 0 0 6902891 Oct 11 2002 Susan Tedeschi - Wait For Me 05 Wait For Me.mp3
-rw-r--r-- 1 0 0 10458888 Oct 11 2002 Susan Tedeschi - Wait For Me 06 Feeling Music Brings.mp3
-rw-r--r-- 1 0 0 5411404 Oct 11 2002 Susan Tedeschi - Wait For Me 07 In The Garden.mp3
-rw-r--r-- 1 0 0 4584472 Oct 11 2002 Susan Tedeschi - Wait For Me 08 Hampmotized.mp3
-rw-r--r-- 1 0 0 6810104 Oct 11 2002 Susan Tedeschi - Wait For Me 09 Don't Think Twice.mp3
-rw-r--r-- 1 0 0 5031479 Oct 11 2002 Susan Tedeschi - Wait For Me 10 I Fell In Love.mp3
-rw-r--r-- 1 0 0 4387613 Oct 11 2002 Susan Tedeschi - Wait For Me 11 Blues On A Holiday.mp3
/drive0/Blues/Wander This World:
total 74572
-rw-r--r-- 1 0 0 6517951 Oct 11 2002 Angel of Mercy.mp3
-rw-r--r-- 1 0 0 5628325 Oct 11 2002 Before You Hit The Ground.mp3
-rw-r--r-- 1 0 0 6538640 Oct 11 2002 Breakin' Me.mp3
-rw-r--r-- 1 0 0 5065334 Oct 11 2002 Cherry Red Wine.mp3
-rw-r--r-- 1 0 0 7324821 Oct 11 2002 I Am.mp3
-rw-r--r-- 1 0 0 6605722 Oct 11 2002 Leaving to Stay.mp3
-rw-r--r-- 1 0 0 5652148 Oct 11 2002 Right Back.mp3
-rw-r--r-- 1 0 0 7448328 Oct 11 2002 Second Guessing.mp3
-rw-r--r-- 1 0 0 6955554 Oct 11 2002 Still Rainin'.mp3
-rw-r--r-- 1 0 0 5350591 Oct 11 2002 The Levee.mp3
-rw-r--r-- 1 0 0 6117964 Oct 11 2002 Walking Away.mp3
-rw-r--r-- 1 0 0 6980632 Oct 11 2002 Wander This World.mp3
/drive0/Classical:
total 40
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Baroque Music For Trumpets
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Brandenburgische Konzerte (Disc 2)
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Brandenburgische Konzerte (Disc 1)
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Dvorak Cello Concerto Op. 104
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Favorite Arias by the World's Favorite Tenors
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Fireworks Music, Water Music
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Ivan Moravec plays Debussy
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Liszt - Thibaudet
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Mozart- The Piano Quartets
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Pianos Concertos - Gaspard de la Nuit
/drive0/Classical/Baroque Music For Trumpets:
total 66648
-rw-r--r-- 1 0 0 8581206 Oct 11 2002 M. Haydn- Concerto for Trumpet & Orchestra, 1. Adagio.mp3
-rw-r--r-- 1 0 0 4240282 Oct 11 2002 M. Haydn- Concerto for Trumpet & Orchestra, 2. Allegro.mp3
-rw-r--r-- 1 0 0 9359237 Oct 11 2002 Pachelbel- Canon for 3 Trumpets & Strings.mp3
-rw-r--r-- 1 0 0 5969379 Oct 11 2002 Telemann- Concerto for 3 Trumpets & Orchestra (B-flat), 1. Moderato.mp3
-rw-r--r-- 1 0 0 3586385 Oct 11 2002 Telemann- Concerto for 3 Trumpets & Orchestra (B-flat), 2. Largo.mp3
-rw-r--r-- 1 0 0 4881014 Oct 11 2002 Telemann- Concerto for 3 Trumpets & Orchestra (B-flat), 3. Allegro.mp3
-rw-r--r-- 1 0 0 2605226 Oct 11 2002 Telemann- Concerto for 3 Trumpets & Orchestra (D), 1. Largo.mp3
-rw-r--r-- 1 0 0 3305516 Oct 11 2002 Telemann- Concerto for 3 Trumpets & Orchestra (D), 2. Adagio.mp3
-rw-r--r-- 1 0 0 2583283 Oct 11 2002 Telemann- Concerto for 3 Trumpets & Orchestra (D), 3. Presto.mp3
-rw-r--r-- 1 0 0 4136210 Oct 11 2002 Telemann- Concerto for 3 Trumpets & Orchestra (D), Allegro moderato.mp3
-rw-r--r-- 1 0 0 4528047 Oct 11 2002 Vivaldi- Concerto for 2 Trumpets & Strings, 1. Allegro.mp3
-rw-r--r-- 1 0 0 1400249 Oct 11 2002 Vivaldi- Concerto for 2 Trumpets & Strings, 2. Largo.mp3
-rw-r--r-- 1 0 0 4885402 Oct 11 2002 Vivaldi- Concerto for 2 Trumpets & Strings, 3. Allegro.mp3
-rw-r--r-- 1 0 0 8033262 Oct 11 2002 Von Biber- Sonata for 8 Trumpets & Orchestra.mp3
/drive0/Classical/Brandenburgische Konzerte (Disc 2):
total 76680
-rw-r--r-- 1 0 0 6045866 Oct 11 2002 - Adagio ma non tanto.mp3
-rw-r--r-- 1 0 0 7352406 Oct 11 2002 - Adagio, ma non tanto, e dolce.mp3
-rw-r--r-- 1 0 0 8314130 Oct 11 2002 - Affettuoso.mp3
-rw-r--r-- 1 0 0 9723489 Oct 11 2002 - Alla breve.mp3
-rw-r--r-- 1 0 0 7222630 Oct 11 2002 - Allegro(2).mp3
-rw-r--r-- 1 0 0 7446447 Oct 11 2002 - Allegro.mp3
-rw-r--r-- 1 0 0 14068801 Oct 11 2002 Concerto 5 BWV 1050 in D major - Allegro.mp3
-rw-r--r-- 1 0 0 6369993 Oct 11 2002 Concerto 6 BWV 1051 in B flat major.mp3
-rw-r--r-- 1 0 0 11833138 Oct 11 2002 Triple Concerto BWV 1044 in A minor - Allegro.mp3
/drive0/Classical/Brandenburgische Konzerte (Disc 1):
total 73276
-rw-r--r-- 1 0 0 4553125 Oct 11 2002 - Adagio.mp3
-rw-r--r-- 1 0 0 3927440 Oct 11 2002 - Allegro assai.mp3
-rw-r--r-- 1 0 0 5640236 Oct 11 2002 - Allegro(2).mp3
-rw-r--r-- 1 0 0 5812645 Oct 11 2002 - Allegro.mp3
-rw-r--r-- 1 0 0 4778823 Oct 11 2002 - Andante(2).mp3
-rw-r--r-- 1 0 0 4837755 Oct 11 2002 - Andante.mp3
-rw-r--r-- 1 0 0 11056987 Oct 11 2002 - Menuetto - Trio I - Polacca - Trio II.mp3
-rw-r--r-- 1 0 0 6154326 Oct 11 2002 - Presto.mp3
-rw-r--r-- 1 0 0 5228965 Oct 11 2002 Concerto 1 BWV 1046 in F major - Allegro moderato.mp3
-rw-r--r-- 1 0 0 6598199 Oct 11 2002 Concerto 2 BWV 1047 in F major - Allegro moderato.mp3
-rw-r--r-- 1 0 0 7361183 Oct 11 2002 Concerto 3 BWV 1048 in G major - Allegro moderato.mp3
-rw-r--r-- 1 0 0 8909095 Oct 11 2002 Concerto 4 BWV 1049 in G major - Allegro.mp3
/drive0/Classical/Dvorak Cello Concerto Op. 104:
total 80828
-rw-r--r-- 1 0 0 18472419 Oct 11 2002 Adagio ma non troppo.mp3
-rw-r--r-- 1 0 0 23319283 Oct 11 2002 Allegro.mp3
-rw-r--r-- 1 0 0 19341356 Oct 11 2002 Finale- Allegro moderato.mp3
-rw-r--r-- 1 0 0 11744739 Oct 11 2002 Rondo for Cello and Orchestra, Op. 94.mp3
-rw-r--r-- 1 0 0 9766120 Oct 11 2002 Silent Woods, Op. 68, No. 5.mp3
/drive0/Classical/Favorite Arias by the World's Favorite Tenors:
total 89256
-rw-r--r-- 1 0 0 2812116 Oct 11 2002 Cilea- L'Anima Ho Stanca (Domingo).mp3
-rw-r--r-- 1 0 0 9205010 Oct 11 2002 Donizetti- Fra Poco A Me Ricovero (Pavarotti).mp3
-rw-r--r-- 1 0 0 6598199 Oct 11 2002 Donizetti- Una Furtiva Lagrima (Domingo).mp3
-rw-r--r-- 1 0 0 2753810 Oct 11 2002 Giordano- Amor Ti Vieta (Pavarotti).mp3
-rw-r--r-- 1 0 0 4749983 Oct 11 2002 Giordano- Come Un Bel Di Di Maggio (Carreras).mp3
-rw-r--r-- 1 0 0 6487231 Oct 11 2002 Girodano- Un Di All' Azzurro Spazio (Carreras).mp3
-rw-r--r-- 1 0 0 4213324 Oct 11 2002 Leoncavallo- Vesti La Giubra (Pavarotti).mp3
-rw-r--r-- 1 0 0 3405827 Oct 11 2002 Mascagni- Apri La Tua Finestra! (Domingo).mp3
-rw-r--r-- 1 0 0 5138058 Oct 11 2002 Massenet- O Souverain, O Juge, O Pere (Domingo).mp3
-rw-r--r-- 1 0 0 2998316 Oct 11 2002 Puccini- Addio, Fiorito Asil (Domingo).mp3
-rw-r--r-- 1 0 0 5973768 Oct 11 2002 Puccini- Che Gelida Manina (Pavarotti).mp3
-rw-r--r-- 1 0 0 4899195 Oct 11 2002 Puccini- E Lucevan Le Stelle (Carreras).mp3
-rw-r--r-- 1 0 0 3219626 Oct 11 2002 Puccini- Firenze E Come Un Albero Fiorito (Domingo).mp3
-rw-r--r-- 1 0 0 3758793 Oct 11 2002 Puccini- Nessun Dorma (Pavarotti).mp3
-rw-r--r-- 1 0 0 3534976 Oct 11 2002 Puccini- Non Piangere, Liu! (Carreras).mp3
-rw-r--r-- 1 0 0 3363822 Oct 11 2002 R. Strauss- Di Rigori Armato Il Seno (Domingo).mp3
-rw-r--r-- 1 0 0 4998878 Oct 11 2002 Verdi- De' Miei Bollenti Spiriti (Domingo).mp3
-rw-r--r-- 1 0 0 3175740 Oct 11 2002 Verdi- La Donna E Mobile (Pavarotti).mp3
-rw-r--r-- 1 0 0 7274666 Oct 11 2002 Verdi- Quando Le Sere Al Placido (Pavarotti).mp3
-rw-r--r-- 1 0 0 2626542 Oct 11 2002 Verdi- Questa O Quella (Pavarotti).mp3
/drive0/Classical/Fireworks Music, Water Music:
total 90804
-rw-r--r-- 1 0 0 9104073 Oct 11 2002 (10).mp3
-rw-r--r-- 1 0 0 4427737 Oct 11 2002 (11).mp3
-rw-r--r-- 1 0 0 2830297 Oct 11 2002 (12).mp3
-rw-r--r-- 1 0 0 2789546 Oct 11 2002 (13).mp3
-rw-r--r-- 1 0 0 1531280 Oct 11 2002 (14).mp3
-rw-r--r-- 1 0 0 1736289 Oct 11 2002 (15).mp3
-rw-r--r-- 1 0 0 5872204 Oct 11 2002 (16).mp3
-rw-r--r-- 1 0 0 3333102 Oct 11 2002 (17).mp3
-rw-r--r-- 1 0 0 4231505 Oct 11 2002 (18).mp3
-rw-r--r-- 1 0 0 3241569 Oct 11 2002 (19).mp3
-rw-r--r-- 1 0 0 11737843 Oct 11 2002 (2).mp3
-rw-r--r-- 1 0 0 2449745 Oct 11 2002 (20).mp3
-rw-r--r-- 1 0 0 2353823 Oct 11 2002 (21).mp3
-rw-r--r-- 1 0 0 1731273 Oct 11 2002 (22).mp3
-rw-r--r-- 1 0 0 1415296 Oct 11 2002 (23).mp3
-rw-r--r-- 1 0 0 1994587 Oct 11 2002 (24).mp3
-rw-r--r-- 1 0 0 1162640 Oct 11 2002 (25).mp3
-rw-r--r-- 1 0 0 1311851 Oct 11 2002 (26).mp3
-rw-r--r-- 1 0 0 1823433 Oct 11 2002 (27).mp3
-rw-r--r-- 1 0 0 2835312 Oct 11 2002 (3).mp3
-rw-r--r-- 1 0 0 5306705 Oct 11 2002 (4).mp3
-rw-r--r-- 1 0 0 5038375 Oct 11 2002 (5).mp3
-rw-r--r-- 1 0 0 1111858 Oct 11 2002 (6).mp3
-rw-r--r-- 1 0 0 3524318 Oct 11 2002 (7).mp3
-rw-r--r-- 1 0 0 5486009 Oct 11 2002 (8).mp3
-rw-r--r-- 1 0 0 4370685 Oct 11 2002 (9).mp3
/drive0/Classical/Ivan Moravec plays Debussy:
total 68092
-rw-r--r-- 1 0 0 6379397 Oct 11 2002 Cloches a travers les feuilles.mp3
-rw-r--r-- 1 0 0 6271564 Oct 11 2002 Despas sur la neige.mp3
-rw-r--r-- 1 0 0 8123541 Oct 11 2002 Et la lune descend sur le temple qui fut.mp3
-rw-r--r-- 1 0 0 9799975 Oct 11 2002 Hommage a Rameau.mp3
-rw-r--r-- 1 0 0 5277866 Oct 11 2002 Jardins sous la pluie.mp3
-rw-r--r-- 1 0 0 4889164 Oct 11 2002 Mouvement.mp3
-rw-r--r-- 1 0 0 8371182 Oct 11 2002 Pagodes.mp3
-rw-r--r-- 1 0 0 5276612 Oct 11 2002 Poissons d'or.mp3
-rw-r--r-- 1 0 0 7517291 Oct 11 2002 Reflets dans L'eau.mp3
-rw-r--r-- 1 0 0 7668383 Oct 11 2002 Soiree dans Grenade.mp3
/drive0/Classical/Liszt - Thibaudet:
total 96564
-rw-r--r-- 1 0 0 5922359 Oct 11 2002 Allegretto vivace.mp3
-rw-r--r-- 1 0 0 2685474 Oct 11 2002 Allegro animato.mp3
-rw-r--r-- 1 0 0 10012507 Oct 11 2002 Allegro deciso - Marziale un poco menu allegro.mp3
-rw-r--r-- 1 0 0 6065928 Oct 11 2002 Allegro marziale animato.mp3
-rw-r--r-- 1 0 0 7301624 Oct 11 2002 Allegro moderato.mp3
-rw-r--r-- 1 0 0 20457307 Oct 11 2002 Hungarian Fantasy.mp3
-rw-r--r-- 1 0 0 7338614 Oct 11 2002 Piano Concerto No. 1 in E flat major - Alegro maestoso.mp3
-rw-r--r-- 1 0 0 10174258 Oct 11 2002 Piano Concerto No. 2 in A major - Adagio Sostenuto assai - Allegro agitato assai.mp3
-rw-r--r-- 1 0 0 6622023 Oct 11 2002 Quasi adagio.mp3
-rw-r--r-- 1 0 0 22138757 Oct 11 2002 Totentanz.mp3
/drive0/Classical/Mozart- The Piano Quartets:
total 78328
-rw-r--r-- 1 0 0 10036958 Oct 11 2002 II. Andante.mp3
-rw-r--r-- 1 0 0 14368478 Oct 11 2002 II. Larghetto.mp3
-rw-r--r-- 1 0 0 12853167 Oct 11 2002 III. Allegretto.mp3
-rw-r--r-- 1 0 0 11097112 Oct 11 2002 III. Rondo. Allegro moderato.mp3
-rw-r--r-- 1 0 0 16397252 Oct 11 2002 Quartet K 478; I. Allegro.mp3
-rw-r--r-- 1 0 0 15329575 Oct 11 2002 Quartet K 493; I. Allegro.mp3
/drive0/Classical/Pianos Concertos - Gaspard de la Nuit:
total 85792
-rw-r--r-- 1 0 0 11121562 Oct 11 2002 01 Piano Concerto in G major - I - Allegramente.mp3
-rw-r--r-- 1 0 0 12454434 Oct 11 2002 02 Piano Concerto in G major - II - Adagio assai.mp3
-rw-r--r-- 1 0 0 5820168 Oct 11 2002 03 Piano Concerto in G major - III - Presto.mp3
-rw-r--r-- 1 0 0 26571841 Oct 11 2002 04 Piano Concerto for the left hand.mp3
-rw-r--r-- 1 0 0 10356697 Oct 11 2002 05 Gaspard de la Nuit - Ondine.mp3
-rw-r--r-- 1 0 0 7546757 Oct 11 2002 06 Gaspard de la Nuit - Le Gibet.mp3
-rw-r--r-- 1 0 0 13836834 Oct 11 2002 07 Gaspard de la Nuit - Scarbo.mp3
/drive0/Italian:
total 32
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Andrea Bocelli
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Franco Battiato
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Manu Chao
drwxr-xr-x 4 0 0 4096 Oct 11 2002 Pino Daniele
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Raf
drwxr-xr-x 3 0 0 4096 Oct 12 2002 Rosana
drwxr-xr-x 4 0 0 4096 Oct 11 2002 Vasco Rossi
drwxr-xr-x 4 0 0 4096 Oct 11 2002 Zucchero Sugar Fornaciari
/drive0/Italian/Andrea Bocelli:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Sacred Arias
/drive0/Italian/Andrea Bocelli/Sacred Arias:
total 117388
-rw-r--r-- 1 0 0 7366617 Oct 11 2002 01 Ave Maria.mp3
-rw-r--r-- 1 0 0 6962033 Oct 11 2002 02 Sancta Maria.mp3
-rw-r--r-- 1 0 0 5827692 Oct 11 2002 03 Ave Maria.mp3
-rw-r--r-- 1 0 0 4864714 Oct 11 2002 04 Ave Maria.mp3
-rw-r--r-- 1 0 0 6817419 Oct 11 2002 05 Panis Angelicus.mp3
-rw-r--r-- 1 0 0 10692737 Oct 11 2002 06 Cuius Animam.mp3
-rw-r--r-- 1 0 0 8008603 Oct 11 2002 07 Ingemisco.mp3
-rw-r--r-- 1 0 0 5958095 Oct 11 2002 08 Ave Verum.mp3
-rw-r--r-- 1 0 0 5930510 Oct 11 2002 09 Der Engel.mp3
-rw-r--r-- 1 0 0 7559715 Oct 11 2002 10 Frondi Tenere- Ombra Mai Fu.mp3
-rw-r--r-- 1 0 0 13415323 Oct 11 2002 11 Pieta, Signor.mp3
-rw-r--r-- 1 0 0 8876286 Oct 11 2002 12 Domine Deus.mp3
-rw-r--r-- 1 0 0 7545504 Oct 11 2002 13 Mille Cherubini in Chor.mp3
-rw-r--r-- 1 0 0 6093514 Oct 11 2002 14 Silent Night.mp3
-rw-r--r-- 1 0 0 5627071 Oct 11 2002 15 Adeste Fideles.mp3
-rw-r--r-- 1 0 0 8416531 Oct 11 2002 16 Gloria a Te, Christo Gesu.mp3
/drive0/Italian/Franco Battiato:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Fleurs
/drive0/Italian/Franco Battiato/Fleurs:
total 78788
-rw-r--r-- 1 0 0 6594229 Oct 11 2002 01 La canzone dell'amore perduto.mp3
-rw-r--r-- 1 0 0 6916893 Oct 11 2002 02 Ruby tuesday.mp3
-rw-r--r-- 1 0 0 6068436 Oct 11 2002 03 J'entends siffler le train.mp3
-rw-r--r-- 1 0 0 5534284 Oct 11 2002 04 Aria di neve.mp3
-rw-r--r-- 1 0 0 5593635 Oct 11 2002 05 Ed io tra voi.mp3
-rw-r--r-- 1 0 0 5886206 Oct 11 2002 06 Te lo leggo negli occhi.mp3
-rw-r--r-- 1 0 0 0 8563653 Oct 11 2002 07 Lettera Dal Cuore.mp3
-rw-r--r-- 1 0 0 8443280 Oct 11 2002 08 Acqua Passata.mp3
-rw-r--r-- 1 0 0 10020658 Oct 11 2002 09 Galby.mp3
-rw-r--r-- 1 0 0 9571770 Oct 11 2002 10 Gente Di Frontiera.mp3
-rw-r--r-- 1 0 0 6983767 Oct 11 2002 11 Lacrima Di Sale.mp3
-rw-r--r-- 1 0 0 11359800 Oct 11 2002 12 Africa A Africa E.mp3
/drive0/Italian/Pino Daniele/The Best Of, Yes I Know My Way:
total 117104
-rw-r--r-- 1 0 0 6841661 Oct 11 2002 01 Quando.mp3
-rw-r--r-- 1 0 0 6903519 Oct 11 2002 02 Io Per Lei.mp3
-rw-r--r-- 1 0 0 7967643 Oct 11 2002 03 Che Male C'e'.mp3
-rw-r--r-- 1 0 0 8324580 Oct 11 2002 04 Amore Senza Fine.mp3
-rw-r--r-- 1 0 0 9769047 Oct 11 2002 05 Senza Peccato.mp3
-rw-r--r-- 1 0 0 8155724 Oct 11 2002 06 Dubbi Non Ho.mp3
-rw-r--r-- 1 0 0 5428959 Oct 11 2002 07 Resta Resta Cu'Mme.mp3
-rw-r--r-- 1 0 0 9539169 Oct 11 2002 08 Anna Verra'.mp3
-rw-r--r-- 1 0 0 6208871 Oct 11 2002 09 Che Soddisfazione.mp3
-rw-r--r-- 1 0 0 8382258 Oct 11 2002 10 Quanno Chiove.mp3
-rw-r--r-- 1 0 0 7224511 Oct 11 2002 11 Napulee'.mp3
-rw-r--r-- 1 0 0 7344884 Oct 11 2002 12 A Testa In Giu'.mp3
-rw-r--r-- 1 0 0 7148443 Oct 11 2002 13 Je So Pazzo.mp3
-rw-r--r-- 1 0 0 6031656 Oct 11 2002 14 A Me Me Piace 'o Blues.mp3
-rw-r--r-- 1 0 0 8325416 Oct 11 2002 15 Che Dio Ti Benedica.mp3
-rw-r--r-- 1 0 0 6077631 Oct 11 2002 16 Per Te.mp3
/drive0/Italian/Raf:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Iperbole
/drive0/Italian/Raf/Iperbole:
total 80696
-rw-r--r-- 1 0 0 9514928 Oct 11 2002 01 Infinito.mp3
-rw-r--r-- 1 0 0 8996658 Oct 11 2002 02 R4.mp3
-rw-r--r-- 1 0 0 7921667 Oct 11 2002 03 Via.mp3
-rw-r--r-- 1 0 0 6245651 Oct 11 2002 04 Nei Silenzi.mp3
-rw-r--r-- 1 0 0 8839506 Oct 11 2002 05 Oasi.mp3
-rw-r--r-- 1 0 0 5756639 Oct 11 2002 06 Assolti.mp3
-rw-r--r-- 1 0 0 7318970 Oct 11 2002 07 Troppo Sensibile.mp3
-rw-r--r-- 1 0 0 9193099 Oct 11 2002 08 Allegro Tormentone.mp3
-rw-r--r-- 1 0 0 9700502 Oct 11 2002 09 Iperbole.mp3
-rw-r--r-- 1 0 0 8978268 Oct 11 2002 10 Infinito (Remix).mp3
/drive0/Italian/Rosana:
total 4
drwxr-xr-x 2 0 0 4096 Oct 12 2002 Lunas Rotas
/drive0/Italian/Rosana/Lunas Rotas:
total 90984
-rw-r--r-- 1 0 0 5872836 Oct 12 2002 01 Furia De Color.mp3
-rw-r--r-- 1 0 0 7049806 Oct 12 2002 02 El Talisman.mp3
-rw-r--r-- 1 0 0 7051480 Oct 12 2002 03 A Fuego Lento.mp3
-rw-r--r-- 1 0 0 9052668 Oct 12 2002 04 No Se Manana.mp3
-rw-r--r-- 1 0 0 8809415 Oct 12 2002 05 Lunas Rotas.mp3
-rw-r--r-- 1 0 0 8127308 Oct 12 2002 06 Si Tu No Estas.mp3
-rw-r--r-- 1 0 0 8244334 Oct 12 2002 07 Bebes De Mi.mp3
-rw-r--r-- 1 0 0 6559120 Oct 12 2002 08 Sin Miedo.mp3
-rw-r--r-- 1 0 0 8852040 Oct 12 2002 09 Deray.mp3
-rw-r--r-- 1 0 0 7619910 Oct 12 2002 10 Asi Son Las Cosas.mp3
-rw-r--r-- 1 0 0 5668037 Oct 12 2002 11 Descubriendote.mp3
-rw-r--r-- 1 0 0 10071657 Oct 12 2002 12 Nadie Mas Que Yo.mp3
/drive0/Italian/Vasco Rossi:
total 8
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Rewind 1
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Rewind 2
/drive0/Italian/Vasco Rossi/Rewind 1:
total 112532
-rw-r--r-- 1 0 0 9332906 Oct 11 2002 01-Quanti Anni Hai.mp3
-rw-r--r-- 1 0 0 7644351 Oct 11 2002 02-Sballi Ravvicinati del Terzo Tipo.mp3
-rw-r--r-- 1 0 0 8492808 Oct 11 2002 03-Valium.mp3
-rw-r--r-- 1 0 0 7626796 Oct 11 2002 04-Rewind.mp3
-rw-r--r-- 1 0 0 7340912 Oct 11 2002 05-Nessub Pericolo Per Te.mp3
-rw-r--r-- 1 0 0 9319531 Oct 11 2002 06-Blasco.mp3
-rw-r--r-- 1 0 0 5990904 Oct 11 2002 07-Ormai E Tardi.mp3
-rw-r--r-- 1 0 0 13563489 Oct 11 2002 08-Stupendo.mp3
-rw-r--r-- 1 0 0 9467489 Oct 11 2002 09-Medley Acustico.mp3
-rw-r--r-- 1 0 0 6718989 Oct 11 2002 10-Jenny E Pazza.mp3
-rw-r--r-- 1 0 0 9347116 Oct 11 2002 11-Sally.mp3
-rw-r--r-- 1 0 0 8155097 Oct 11 2002 12-L' Una Per Te.mp3
-rw-r--r-- 1 0 0 12006173 Oct 11 2002 13-Senza Parole.mp3
/drive0/Italian/Vasco Rossi/Rewind 2:
total 121044
-rw-r--r-- 1 0 0 11304837 Oct 11 2002 01-Vivere.mp3
-rw-r--r-- 1 0 0 16174898 Oct 11 2002 02-Siamo Solo Noi.mp3
-rw-r--r-- 1 0 0 9382225 Oct 11 2002 03-Mi Si Escludeva.mp3
-rw-r--r-- 1 0 0 7134440 Oct 11 2002 04-Gli Spari Sopra.mp3
-rw-r--r-- 1 0 0 7717912 Oct 11 2002 05-Delusa.mp3
-rw-r--r-- 1 0 0 14657706 Oct 11 2002 06-Io No.mp3
-rw-r--r-- 1 0 0 8908259 Oct 11 2002 07-Ce Chi Dice No.mp3
-rw-r--r-- 1 0 0 11902519 Oct 11 2002 08-Bollicine.mp3
-rw-r--r-- 1 0 0 15269598 Oct 11 2002 09-Vita Spericolata.mp3
-rw-r--r-- 1 0 0 13536739 Oct 11 2002 10-Albachiara.mp3
-rw-r--r-- 1 0 0 7764723 Oct 11 2002 11-Rewind Radio Edit.mp3
/drive0/Italian/Zucchero Sugar Fornaciari:
total 8
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Spirito DiVino [Polygram International]
drwxr-xr-x 2 0 0 4096 Oct 11 2002 The Best of Zucchero Sugar Fornaciaris Greatest Hits
/drive0/Italian/Zucchero Sugar Fornaciari/Spirito DiVino [Polygram International]:
total 84016
-rw-r--r-- 1 0 0 7939890 Oct 11 2002 01-Voodoo Voodoo.mp3
-rw-r--r-- 1 0 0 7877196 Oct 11 2002 02-Datem Una Pompa.mp3
-rw-r--r-- 1 0 0 6675145 Oct 11 2002 03-O.L.S.M.M..mp3
-rw-r--r-- 1 0 0 9997921 Oct 11 2002 04-Pane E Sale.mp3
-rw-r--r-- 1 0 0 7658185 Oct 11 2002 05-Alleluja.mp3
-rw-r--r-- 1 0 0 10597274 Oct 11 2002 06-X Colpa Di Chi-.mp3
-rw-r--r-- 1 0 0 8841846 Oct 11 2002 07-Cosi Celeste.mp3
-rw-r--r-- 1 0 0 7707504 Oct 11 2002 08-Senza Rimorso.mp3
-rw-r--r-- 1 0 0 9457081 Oct 11 2002 09-Papa Perche.mp3
-rw-r--r-- 1 0 0 9118535 Oct 11 2002 10-Il Volo.mp3
/drive0/Italian/Zucchero Sugar Fornaciari/The Best of Zucchero Sugar Fornaciaris Greatest Hits:
total 139720
-rw-r--r-- 1 0 0 8564780 Oct 11 2002 01-Senza Una Donna.mp3
-rw-r--r-- 1 0 0 11187056 Oct 11 2002 02-Diamante.mp3
-rw-r--r-- 1 0 0 8807197 Oct 11 2002 03-Wonderful World.mp3
-rw-r--r-- 1 0 0 8328216 Oct 11 2002 04-My Love.mp3
-rw-r--r-- 1 0 0 7493133 Oct 11 2002 05-She's My Baby.mp3
-rw-r--r-- 1 0 0 9333825 Oct 11 2002 06-Nothing to Lose.mp3
-rw-r--r-- 1 0 0 10325224 Oct 11 2002 07-I Won't Be Lonely Tonight.mp3
-rw-r--r-- 1 0 0 9073855 Oct 11 2002 08-I Don't Know.mp3
-rw-r--r-- 1 0 0 10373708 Oct 11 2002 09-Overdose (D'Amore).mp3
-rw-r--r-- 1 0 0 10057731 Oct 11 2002 10-Feels Like a Woman.mp3
-rw-r--r-- 1 0 0 10851017 Oct 11 2002 11-Dunes of Mercy.mp3
-rw-r--r-- 1 0 0 10552594 Oct 11 2002 12-The Promise.mp3
-rw-r--r-- 1 0 0 9043762 Oct 11 2002 13-Con le Mani.mp3
-rw-r--r-- 1 0 0 14006609 Oct 11 2002 14-Mama (Madre Dolcissima).mp3
-rw-r--r-- 1 0 0 4803148 Oct 11 2002 15-You've Chosen Me.mp3
/drive0/Jazz:
total 44
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Ballads
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Bing, Bing, Bing!
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Compact Jazz
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Genius of Modern Music, Volume I
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Giant Steps
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Introducing Brad Mehldau
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Joshua Redman
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Kind Of Blue
drwxr-xr-x 2 0 0 4096 Oct 11 2002 New Moon Daughter
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Portrait In Jazz
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Uberjam
/drive0/Jazz/Ballads:
total 45512
-rw-r--r-- 1 0 0 5256550 Oct 11 2002 All Or Nothing At All.mp3
-rw-r--r-- 1 0 0 7062134 Oct 11 2002 I Wish I Knew.mp3
-rw-r--r-- 1 0 0 4059724 Oct 11 2002 It's Easy to Remember.mp3
-rw-r--r-- 1 0 0 4580710 Oct 11 2002 Nancy (With the Laughing Face).mp3
-rw-r--r-- 1 0 0 6198839 Oct 11 2002 Say It (Over and Over Again).mp3
-rw-r--r-- 1 0 0 6318584 Oct 11 2002 Too Young To Go Steady.mp3
-rw-r--r-- 1 0 0 5453409 Oct 11 2002 What's New.mp3
-rw-r--r-- 1 0 0 7564312 Oct 11 2002 You Don't Know What Love Is.mp3
/drive0/Jazz/Bing, Bing, Bing!:
total 79764
-rw-r--r-- 1 0 0 7124200 Oct 11 2002 Charlie Hunter Trio - Bing, Bing, Bing! 01 Greasy Granny.mp3
-rw-r--r-- 1 0 0 5766251 Oct 11 2002 Charlie Hunter Trio - Bing, Bing, Bing! 02 Wornell's Yorkies.mp3
-rw-r--r-- 1 0 0 9764240 Oct 11 2002 Charlie Hunter Trio - Bing, Bing, Bing! 03 Fistful Of Haggis.mp3
-rw-r--r-- 1 0 0 8899064 Oct 11 2002 Charlie Hunter Trio - Bing, Bing, Bing! 04 Come As You Are.mp3
-rw-r--r-- 1 0 0 6944269 Oct 11 2002 Charlie Hunter Trio - Bing, Bing, Bing! 05 Scrabbling For Purchase.mp3
-rw-r--r-- 1 0 0 8008184 Oct 11 2002 Charlie Hunter Trio - Bing, Bing, Bing! 06 Bullethead.mp3
-rw-r--r-- 1 0 0 11463244 Oct 11 2002 Charlie Hunter Trio - Bing, Bing, Bing! 07 Bing, Bing, Bing, Bing.mp3
-rw-r--r-- 1 0 0 5921732 Oct 11 2002 Charlie Hunter Trio - Bing, Bing, Bing! 08 Squiddlesticks.mp3
-rw-r--r-- 1 0 0 9019436 Oct 11 2002 Charlie Hunter Trio - Bing, Bing, Bing! 09 Lazy Susan (with a client now).mp3
-rw-r--r-- 1 0 0 8603776 Oct 11 2002 Charlie Hunter Trio - Bing, Bing, Bing! 10 Elbo Room.mp3
/drive0/Jazz/Compact Jazz:
total 76636
-rw-r--r-- 1 0 0 3409588 Oct 11 2002 Agua De Beber.mp3
-rw-r--r-- 1 0 0 5102323 Oct 11 2002 Aguas De Marco (Waters Of March).mp3
-rw-r--r-- 1 0 0 6242098 Oct 11 2002 Chega De Saudade (No More Blues).mp3
-rw-r--r-- 1 0 0 4634000 Oct 11 2002 Chovendo Na Roseira (Double Rainbow).mp3
-rw-r--r-- 1 0 0 5642117 Oct 11 2002 Corcovado (Quiet Nights).mp3
-rw-r--r-- 1 0 0 4009569 Oct 11 2002 Desafinado.mp3
-rw-r--r-- 1 0 0 3938098 Oct 11 2002 Dindi.mp3
-rw-r--r-- 1 0 0 4849667 Oct 11 2002 Favela (O Morro Nao Tem Vez).mp3
-rw-r--r-- 1 0 0 4874117 Oct 11 2002 Insensatez (How Insensitive).mp3
-rw-r--r-- 1 0 0 3721804 Oct 11 2002 Luiza.mp3
-rw-r--r-- 1 0 0 7897843 Oct 11 2002 O Grande Amor.mp3
-rw-r--r-- 1 0 0 5233980 Oct 11 2002 Once I Loved (Amor En Paz).mp3
-rw-r--r-- 1 0 0 3313667 Oct 11 2002 Samba De Uma Nota So (One Note Samba).mp3
-rw-r--r-- 1 0 0 7778098 Oct 11 2002 The Girl From Ipanema.mp3
-rw-r--r-- 1 0 0 3866000 Oct 11 2002 Triste.mp3
-rw-r--r-- 1 0 0 3793902 Oct 11 2002 Vivo Sohando (Dreamer).mp3
/drive0/Jazz/Genius of Modern Music, Volume I:
total 89216
-rw-r--r-- 1 0 0 4605787 Oct 11 2002 'Round Mindnight.mp3
-rw-r--r-- 1 0 0 3898600 Oct 11 2002 April in Paris (alternate take).mp3
-rw-r--r-- 1 0 0 4813931 Oct 11 2002 April in Paris.mp3
-rw-r--r-- 1 0 0 4388867 Oct 11 2002 Evonce (alternate take).mp3
-rw-r--r-- 1 0 0 4440276 Oct 11 2002 Evonce.mp3
-rw-r--r-- 1 0 0 4200158 Oct 11 2002 Humph.mp3
-rw-r--r-- 1 0 0 4242790 Oct 11 2002 In Walked Bud.mp3
-rw-r--r-- 1 0 0 4623969 Oct 11 2002 Introspection.mp3
-rw-r--r-- 1 0 0 4514881 Oct 11 2002 Monk's Mood.mp3
-rw-r--r-- 1 0 0 4400778 Oct 11 2002 Nice Work If You Can Get It (alternate take).mp3
-rw-r--r-- 1 0 0 4408929 Oct 11 2002 Nice Work If You Can Take It.mp3
-rw-r--r-- 1 0 0 4361281 Oct 11 2002 Off Minor.mp3
-rw-r--r-- 1 0 0 4469115 Oct 11 2002 Ruby My Dear (alternate take).mp3
-rw-r--r-- 1 0 0 4516135 Oct 11 2002 Ruby My Dear.mp3
-rw-r--r-- 1 0 0 4274764 Oct 11 2002 Suburban Eyes (alternate take).mp3
-rw-r--r-- 1 0 0 4349996 Oct 11 2002 Suburban Eyes.mp3
-rw-r--r-- 1 0 0 4365043 Oct 11 2002 Thelonious.mp3
-rw-r--r-- 1 0 0 4207054 Oct 11 2002 Well You Needn't (alternate take).mp3
-rw-r--r-- 1 0 0 4269748 Oct 11 2002 Well You Needn't.mp3
-rw-r--r-- 1 0 0 3847192 Oct 11 2002 Who Knows (alternate take).mp3
-rw-r--r-- 1 0 0 3901735 Oct 11 2002 Who Knows.mp3
/drive0/Jazz/Giant Steps:
total 34164
-rw-r--r-- 1 0 0 11458564 Oct 11 2002 Coltrane - Giant Steps.MP3
-rw-r--r-- 1 0 0 6720578 Oct 11 2002 Coltrane - Mr PC.MP3
-rw-r--r-- 1 0 0 4207808 Oct 11 2002 Coltrane - Naima.MP3
-rw-r--r-- 1 0 0 5750495 Oct 11 2002 Coltrane - Spiral.MP3
-rw-r--r-- 1 0 0 6780765 Oct 11 2002 Coltrane - Syeeda's Song Flute.MP3
/drive0/Jazz/Introducing Brad Mehldau:
total 91360
-rw-r--r-- 1 0 0 8921762 Oct 11 2002 Angst.mp3
-rw-r--r-- 1 0 0 6047248 Oct 11 2002 Countdown.mp3
-rw-r--r-- 1 0 0 9462183 Oct 11 2002 From This Moment On.mp3
-rw-r--r-- 1 0 0 11182080 Oct 11 2002 It Might As Well Be Spring.mp3
-rw-r--r-- 1 0 0 10131754 Oct 11 2002 London Blues.mp3
-rw-r--r-- 1 0 0 9246516 Oct 11 2002 My Romance.mp3
-rw-r--r-- 1 0 0 14415000 Oct 11 2002 Prelude To A Kiss.mp3
-rw-r--r-- 1 0 0 13562363 Oct 11 2002 Say Goodbye.mp3
-rw-r--r-- 1 0 0 10411368 Oct 11 2002 Young Werther.mp3
/drive0/Jazz/Joshua Redman:
total 84752
-rw-r--r-- 1 0 0 6973108 Oct 11 2002 Body & Soul.mp3
-rw-r--r-- 1 0 0 9170529 Oct 11 2002 Echoes.mp3
-rw-r--r-- 1 0 0 8437010 Oct 11 2002 Groove X.mp3
-rw-r--r-- 1 0 0 6711048 Oct 11 2002 I Got You (I Feel Good).mp3
-rw-r--r-- 1 0 0 8018842 Oct 11 2002 On the Sunny Side of the Street.mp3
-rw-r--r-- 1 0 0 4661585 Oct 11 2002 Salt Peanuts.mp3
-rw-r--r-- 1 0 0 12828089 Oct 11 2002 Sublimation.mp3
-rw-r--r-- 1 0 0 8770542 Oct 11 2002 Tribalism.mp3
-rw-r--r-- 1 0 0 10192439 Oct 11 2002 Trinkle Tinkle.mp3
-rw-r--r-- 1 0 0 10854486 Oct 11 2002 Wish.mp3
/drive0/Jazz/Kind Of Blue:
total 31808
-rw-r--r-- 1 0 0 8326188 Oct 11 2002 Kind Of Blue - Miles Davis - All Blues.mp3
-rw-r--r-- 1 0 0 3945767 Oct 11 2002 Kind Of Blue - Miles Davis - Blue In Green.mp3
-rw-r--r-- 1 0 0 6776709 Oct 11 2002 Kind Of Blue - Miles Davis - Flamenco Sketches.mp3
-rw-r--r-- 1 0 0 6910560 Oct 11 2002 Kind Of Blue - Miles Davis - Freddie Freeloader.mp3
-rw-r--r-- 1 0 0 6549443 Oct 11 2002 Kind Of Blue - Miles Davis - So What.mp3
/drive0/Jazz/New Moon Daughter:
total 87352
-rw-r--r-- 1 0 0 8057712 Oct 11 2002 Cassandra Wilson - New Moon Daughter 01 Strange Fruit.mp3
-rw-r--r-- 1 0 0 7038937 Oct 11 2002 Cassandra Wilson - New Moon Daughter 02 Love is Blindness.mp3
-rw-r--r-- 1 0 0 8552367 Oct 11 2002 Cassandra Wilson - New Moon Daughter 03 Solomon Sang.mp3
-rw-r--r-- 1 0 0 6099156 Oct 11 2002 Cassandra Wilson - New Moon Daughter 04 Death Letter.mp3
-rw-r--r-- 1 0 0 5971260 Oct 11 2002 Cassandra Wilson - New Moon Daughter 05 Skylark.mp3
-rw-r--r-- 1 0 0 6719198 Oct 11 2002 Cassandra Wilson - New Moon Daughter 06 Find Him.mp3
-rw-r--r-- 1 0 0 6998186 Oct 11 2002 Cassandra Wilson - New Moon Daughter 07 I'm So Lonesome I Could Cry.mp3
-rw-r--r-- 1 0 0 7606943 Oct 11 2002 Cassandra Wilson - New Moon Daughter 08 Last Train to Clarksville.mp3
-rw-r--r-- 1 0 0 9371776 Oct 11 2002 Cassandra Wilson - New Moon Daughter 09 Until.mp3
-rw-r--r-- 1 0 0 8285918 Oct 11 2002 Cassandra Wilson - New Moon Daughter 10 Little Warm Death.mp3
-rw-r--r-- 1 0 0 7334852 Oct 11 2002 Cassandra Wilson - New Moon Daughter 11 Memphis.mp3
-rw-r--r-- 1 0 0 7232034 Oct 11 2002 Cassandra Wilson - New Moon Daughter 12 Harvest Moon.mp3
/drive0/Jazz/Portrait In Jazz:
total 73320
-rw-r--r-- 1 0 0 7776844 Oct 11 2002 Autumn Leaves (mono).mp3
-rw-r--r-- 1 0 0 8616942 Oct 11 2002 Autumn Leaves.mp3
-rw-r--r-- 1 0 0 6440210 Oct 11 2002 Blue In Green (take 2).mp3
-rw-r--r-- 1 0 0 7822610 Oct 11 2002 Blue In Green (take 3).mp3
-rw-r--r-- 1 0 0 4823335 Oct 11 2002 Come Rain Or Come Shine.mp3
-rw-r--r-- 1 0 0 4681647 Oct 11 2002 Peri's Scope.mp3
-rw-r--r-- 1 0 0 7081569 Oct 11 2002 Someday My Prince Will Come.mp3
-rw-r--r-- 1 0 0 7369334 Oct 11 2002 Spring Is Here.mp3
-rw-r--r-- 1 0 0 6625784 Oct 11 2002 What Is This Thing Called Love.mp3
-rw-r--r-- 1 0 0 7081569 Oct 11 2002 When I Fall In Love.mp3
-rw-r--r-- 1 0 0 6603214 Oct 11 2002 Witchcraft.mp3
/drive0/Jazz/Uberjam:
total 82840
-rw-r--r-- 1 0 0 9435097 Oct 11 2002 John Scofield-01-Acidhead.mp3
-rw-r--r-- 1 0 0 6811985 Oct 11 2002 John Scofield-02-Ideofunk.mp3
-rw-r--r-- 1 0 0 8130437 Oct 11 2002 John Scofield-03-Jungle Fiction.mp3
-rw-r--r-- 1 0 0 5829572 Oct 11 2002 John Scofield-04-I Brake 4 Monster Booty.mp3
-rw-r--r-- 1 0 0 8116645 Oct 11 2002 John Scofield-05-Animal Farm.mp3
-rw-r--r-- 1 0 0 9315352 Oct 11 2002 John Scofield-06-Offspring.mp3
-rw-r--r-- 1 0 0 5756220 Oct 11 2002 John Scofield-07-Tomorrow Land.mp3
-rw-r--r-- 1 0 0 9913451 Oct 11 2002 John Scofield-08-?berjam.mp3
-rw-r--r-- 1 0 0 7907247 Oct 11 2002 John Scofield-09-Polo Towers.mp3
-rw-r--r-- 1 0 0 8734806 Oct 11 2002 John Scofield-10-Snap, Crackle, Pop.mp3
-rw-r--r-- 1 0 0 4698574 Oct 11 2002 John Scofield-11-Lucky For Her.mp3
/drive0/Rock:
total 44
drwxr-xr-x 3 0 0 4096 Oct 12 2002 Dave Matthews Band
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Dire Straits
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Eurythmics
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Pink Floyd
drwxr-xr-x 3 0 0 4096 Oct 11 2002 REM
drwxr-xr-x 3 0 0 4096 Oct 11 2002 Santana
drwxr-xr-x 4 0 0 4096 Oct 12 2002 The Cranberries
drwxr-xr-x 3 0 0 4096 Oct 11 2002 The Eagles
drwxr-xr-x 3 0 0 4096 Oct 11 2002 The Police
drwxr-xr-x 4 0 0 4096 Oct 11 2002 The Rolling Stones
drwxr-xr-x 3 0 0 4096 Oct 11 2002 U2
/drive0/Rock/Dave Matthews Band:
total 4
drwxr-xr-x 2 0 0 4096 Oct 12 2002 Before These Crowded Streets
/drive0/Rock/Dave Matthews Band/Before These Crowded Streets:
total 132160
-rw-r--r-- 1 0 0 1312896 Oct 12 2002 01 Pantala Naga Pampa.mp3
-rw-r--r-- 1 0 0 11533671 Oct 12 2002 02 Rapunzel.mp3
-rw-r--r-- 1 0 0 13373527 Oct 12 2002 03 The Last Stop.mp3
-rw-r--r-- 1 0 0 13490556 Oct 12 2002 04 Don't Drink the Water.mp3
-rw-r--r-- 1 0 0 10731189 Oct 12 2002 05 Stay (Wasting Time).mp3
-rw-r--r-- 1 0 0 9858490 Oct 12 2002 06 Halloween.mp3
-rw-r--r-- 1 0 0 14363254 Oct 12 2002 07 The Stone.mp3
-rw-r--r-- 1 0 0 15663108 Oct 12 2002 08 Crush.mp3
-rw-r--r-- 1 0 0 16904446 Oct 12 2002 09 The Dreaming Tree.mp3
-rw-r--r-- 1 0 0 13369347 Oct 12 2002 10 Pig.mp3
-rw-r--r-- 1 0 0 14507868 Oct 12 2002 11 Spoon.mp3
/drive0/Rock/Dire Straits:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Dire Straits
/drive0/Rock/Dire Straits/Dire Straits:
total 78504
-rw-r--r-- 1 0 0 7678168 Oct 11 2002 01 - Down to the Waterline.mp3
-rw-r--r-- 1 0 0 10431675 Oct 11 2002 02 - Water of Love.mp3
-rw-r--r-- 1 0 0 6369948 Oct 11 2002 03 - Setting Me Up.mp3
-rw-r--r-- 1 0 0 8086926 Oct 11 2002 04 - Six Blade Knife.mp3
-rw-r--r-- 1 0 0 5763910 Oct 11 2002 05 - Southbound Again.mp3
-rw-r--r-- 1 0 0 11158927 Oct 11 2002 06 - Sultans of Swing.mp3
-rw-r--r-- 1 0 0 12050014 Oct 11 2002 07 - In the Gallery.mp3
-rw-r--r-- 1 0 0 9010614 Oct 11 2002 08 - Wild West End.mp3
-rw-r--r-- 1 0 0 9688535 Oct 11 2002 09 - Lions.mp3
/drive0/Rock/Eurythmics:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Peace
/drive0/Rock/Eurythmics/Peace:
total 92212
-rw-r--r-- 1 0 0 9455605 Oct 11 2002 01 Seventeen Again.mp3
-rw-r--r-- 1 0 0 9395426 Oct 11 2002 02 I Saved The World Today.mp3
-rw-r--r-- 1 0 0 6341811 Oct 11 2002 03 Power To The Meek.mp3
-rw-r--r-- 1 0 0 6651934 Oct 11 2002 04 Beautiful Child.mp3
-rw-r--r-- 1 0 0 9755703 Oct 11 2002 05 Anything But Strong.mp3
-rw-r--r-- 1 0 0 11242803 Oct 11 2002 06 Peace Is Just A Word.mp3
-rw-r--r-- 1 0 0 8237677 Oct 11 2002 07 I've Tried Everything.mp3
-rw-r--r-- 1 0 0 6798218 Oct 11 2002 08 I Want It All.mp3
-rw-r--r-- 1 0 0 9131265 Oct 11 2002 09 My True Love.mp3
-rw-r--r-- 1 0 0 7962647 Oct 11 2002 10 Forever.mp3
-rw-r--r-- 1 0 0 9265843 Oct 11 2002 11 Lifted.mp3
/drive0/Rock/Pink Floyd:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Meddle
/drive0/Rock/Pink Floyd/Meddle:
total 87788
-rw-r--r-- 1 0 0 11464055 Oct 11 2002 01. One Of These Days.mp3
-rw-r--r-- 1 0 0 9961074 Oct 11 2002 02. A Pillow Of Winds.mp3
-rw-r--r-- 1 0 0 11784203 Oct 11 2002 03. Fearless.mp3
-rw-r--r-- 1 0 0 7148202 Oct 11 2002 04. San Tropez.mp3
-rw-r--r-- 1 0 0 4327809 Oct 11 2002 05. Seamus.mp3
-rw-r--r-- 1 0 0 45076322 Oct 11 2002 06. Echoes.mp3
/drive0/Rock/REM:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Reveal
/drive0/Rock/REM/Reveal:
total 100984
-rw-r--r-- 1 0 0 8939813 Oct 11 2002 01 The Lifting.mp3
-rw-r--r-- 1 0 0 6617635 Oct 11 2002 02 I've Been High.mp3
-rw-r--r-- 1 0 0 9091122 Oct 11 2002 03 All The Way To Reno.mp3
-rw-r--r-- 1 0 0 10316580 Oct 11 2002 04 She Just Wants To Be.mp3
-rw-r--r-- 1 0 0 8028660 Oct 11 2002 05 Disappear.mp3
-rw-r--r-- 1 0 0 9438858 Oct 11 2002 06 Saturn Return.mp3
-rw-r--r-- 1 0 0 8342131 Oct 11 2002 07 Beat A Drum.mp3
-rw-r--r-- 1 0 0 7576436 Oct 11 2002 08 Imitation Of Life.mp3
-rw-r--r-- 1 0 0 6786496 Oct 11 2002 09 Summer Turns To High.mp3
-rw-r--r-- 1 0 0 8692390 Oct 11 2002 10 Chorus And The Ring.mp3
-rw-r--r-- 1 0 0 11251135 Oct 11 2002 11 I'll Take The Rain.mp3
-rw-r--r-- 1 0 0 8131479 Oct 11 2002 12 Beachball.mp3
/drive0/Rock/Santana:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Supernatural
/drive0/Rock/Santana/Supernatural:
total 140916
-rw-r--r-- 1 0 0 11319682 Oct 11 2002 01 (Da Le) Yaleo.mp3
-rw-r--r-- 1 0 0 11134946 Oct 11 2002 02 Love Of My Life.mp3
-rw-r--r-- 1 0 0 9129580 Oct 11 2002 03 Put Your Lights On.mp3
-rw-r--r-- 1 0 0 9045147 Oct 11 2002 04 Africa Bamba.mp3
-rw-r--r-- 1 0 0 9542512 Oct 11 2002 05 Smooth.mp3
-rw-r--r-- 1 0 0 11358140 Oct 11 2002 06 Do You Like The Way.mp3
-rw-r--r-- 1 0 0 8410684 Oct 11 2002 07 Maria Maria.mp3
-rw-r--r-- 1 0 0 10525551 Oct 11 2002 08 Migra.mp3
-rw-r--r-- 1 0 0 8841187 Oct 11 2002 09 Corazon Espinado.mp3
-rw-r--r-- 1 0 0 9371994 Oct 11 2002 10 Wishing It Was.mp3
-rw-r--r-- 1 0 0 9314309 Oct 11 2002 11 El Farol.mp3
-rw-r--r-- 1 0 0 12123832 Oct 11 2002 12 Primavera.mp3
-rw-r--r-- 1 0 0 23935361 Oct 11 2002 13 The Calling.mp3
/drive0/Rock/The Cranberries:
total 8
drwxr-xr-x 2 0 0 4096 Oct 12 2002 Bury the Hatchet
drwxr-xr-x 2 0 0 4096 Oct 12 2002 To The Faithful Departed
/drive0/Rock/The Cranberries/Bury the Hatchet:
total 95896
-rw-r--r-- 1 0 0 6761328 Oct 12 2002 01 - Animal Instinct.mp3
-rw-r--r-- 1 0 0 5288440 Oct 12 2002 02 - Loud and Clear.mp3
-rw-r--r-- 1 0 0 10489524 Oct 12 2002 03 - Promises.mp3
-rw-r--r-- 1 0 0 6904270 Oct 12 2002 04 - You and Me.mp3
-rw-r--r-- 1 0 0 7089008 Oct 12 2002 05 - Just My Imagination.mp3
-rw-r--r-- 1 0 0 7118265 Oct 12 2002 06 - Shattered.mp3
-rw-r--r-- 1 0 0 7189319 Oct 12 2002 07 - Desperate Andy.mp3
-rw-r--r-- 1 0 0 6025720 Oct 12 2002 08 - Saving Grace.mp3
-rw-r--r-- 1 0 0 5567637 Oct 12 2002 09 - Copycat.mp3
-rw-r--r-- 1 0 0 6172006 Oct 12 2002 10 - What's on My Mind.mp3
-rw-r--r-- 1 0 0 6799781 Oct 12 2002 11 - Delilah.mp3
-rw-r--r-- 1 0 0 9195523 Oct 12 2002 12 - Fee Fi Fo.mp3
-rw-r--r-- 1 0 0 6802288 Oct 12 2002 13 - Dying in the Sun.mp3
-rw-r--r-- 1 0 0 6582442 Oct 12 2002 14 - Sorry Son.mp3
/drive0/Rock/The Cranberries/To The Faithful Departed:
total 109264
-rw-r--r-- 1 0 0 9836756 Oct 12 2002 01 Hollywood.mp3
-rw-r--r-- 1 0 0 4612266 Oct 12 2002 02 Salvation.mp3
-rw-r--r-- 1 0 0 9499881 Oct 12 2002 03 When You're Gone.mp3
-rw-r--r-- 1 0 0 8487584 Oct 12 2002 04 Free To Decide.mp3
-rw-r--r-- 1 0 0 7370797 Oct 12 2002 05 War Child.mp3
-rw-r--r-- 1 0 0 7995228 Oct 12 2002 06 Forever Yellow Skies.mp3
-rw-r--r-- 1 0 0 6415342 Oct 12 2002 07 The Rebels.mp3
-rw-r--r-- 1 0 0 3956070 Oct 12 2002 08 Intermission.mp3
-rw-r--r-- 1 0 0 5175675 Oct 12 2002 09 I Just Shot John Lennon.mp3
-rw-r--r-- 1 0 0 9318487 Oct 12 2002 10 Electric Blue.mp3
-rw-r--r-- 1 0 0 9257465 Oct 12 2002 11 I'm Still Remembering.mp3
-rw-r--r-- 1 0 0 5417256 Oct 12 2002 12 Will You Remember.mp3
-rw-r--r-- 1 0 0 6468005 Oct 12 2002 13 Joe.mp3
-rw-r--r-- 1 0 0 7029742 Oct 12 2002 14 Cordell.mp3
-rw-r--r-- 1 0 0 10808929 Oct 12 2002 15 Bosnia.mp3
/drive0/Rock/The Eagles:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 The Eagles Greatest Hits, Vol. 2
/drive0/Rock/The Eagles/The Eagles Greatest Hits, Vol. 2:
total 87636
-rw-r--r-- 1 0 0 12473075 Oct 11 2002 01 - Hotel California.mp3
-rw-r--r-- 1 0 0 8455651 Oct 11 2002 02 - Heartache Tonight.mp3
-rw-r--r-- 1 0 0 5698792 Oct 11 2002 03 - Seven Bridges Road.mp3
-rw-r--r-- 1 0 0 7987537 Oct 11 2002 04 - Victim of Love.mp3
-rw-r--r-- 1 0 0 10620680 Oct 11 2002 05 - The Sad Cafe.mp3
-rw-r--r-- 1 0 0 9122714 Oct 11 2002 06 - Life in the Fast Lane.mp3
-rw-r--r-- 1 0 0 9407762 Oct 11 2002 07 - I Can't Tell You Why.mp3
-rw-r--r-- 1 0 0 9724575 Oct 11 2002 08 - New Kid in Town.mp3
-rw-r--r-- 1 0 0 7089761 Oct 11 2002 09 - The Long Run.mp3
-rw-r--r-- 1 0 0 8985624 Oct 11 2002 10 - After the Thrill Is Gone.mp3
/drive0/Rock/The Police:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Every Breath You Take
/drive0/Rock/The Police/Every Breath You Take:
total 94460
-rw-r--r-- 1 0 0 6157660 Oct 11 2002 01. Roxanne.mp3
-rw-r--r-- 1 0 0 5407856 Oct 11 2002 02. Can't Stand Losing You.mp3
-rw-r--r-- 1 0 0 9273140 Oct 11 2002 03. Message In A Bottle.mp3
-rw-r--r-- 1 0 0 9666022 Oct 11 2002 04. Walking On The Moon.mp3
-rw-r--r-- 1 0 0 9252253 Oct 11 2002 05. Don't Stand So Close To Me '86.mp3
-rw-r--r-- 1 0 0 7905583 Oct 11 2002 06. De Do Do Do, De Da Da Da.mp3
-rw-r--r-- 1 0 0 8320210 Oct 11 2002 07. Every Little Thing She Does Is Magic.mp3
-rw-r--r-- 1 0 0 7173307 Oct 11 2002 08. Invisible Sun.mp3
-rw-r--r-- 1 0 0 5719661 Oct 11 2002 09. Spirits In The Material World.mp3
-rw-r--r-- 1 0 0 8089483 Oct 11 2002 10. Every Breath You Take.mp3
-rw-r--r-- 1 0 0 9524745 Oct 11 2002 11. King Of Pain.mp3
-rw-r--r-- 1 0 0 10043865 Oct 11 2002 12. Wrapped Around Your Finger.mp3
/drive0/Rock/The Rolling Stones:
total 8
drwxr-xr-x 2 0 0 4096 Oct 11 2002 It's Only Rock and Roll
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Some Girls
/drive0/Rock/The Rolling Stones/It's Only Rock and Roll:
total 91152
-rw-r--r-- 1 0 0 7275251 Oct 11 2002 01 - If You Can't Rock Me.mp3
-rw-r--r-- 1 0 0 6777044 Oct 11 2002 02 - Ain't Too Proud to Beg.mp3
-rw-r--r-- 1 0 0 9844028 Oct 11 2002 03 - It's Only Rock & Roll (But I Like It).mp3
-rw-r--r-- 1 0 0 8873527 Oct 11 2002 04 - Till the Next Goodbye.mp3
-rw-r--r-- 1 0 0 12759711 Oct 11 2002 05 - Time Waits for No One.mp3
-rw-r--r-- 1 0 0 9651767 Oct 11 2002 06 - Luxury.mp3
-rw-r--r-- 1 0 0 8050983 Oct 11 2002 07 - Dance Little Sister.mp3
-rw-r--r-- 1 0 0 12075094 Oct 11 2002 08 - If You Really Want to Be My Friend.mp3
-rw-r--r-- 1 0 0 5253164 Oct 11 2002 09 - Short and Curlies.mp3
-rw-r--r-- 1 0 0 12601723 Oct 11 2002 10 - Fingerprint File.mp3
/drive0/Rock/The Rolling Stones/Some Girls:
total 76800
-rw-r--r-- 1 0 0 9256670 Oct 11 2002 01-Miss You.mp3
-rw-r--r-- 1 0 0 8385643 Oct 11 2002 02-When the Whip Comes Down.mp3
-rw-r--r-- 1 0 0 8914779 Oct 11 2002 03-Imagination.mp3
-rw-r--r-- 1 0 0 8893046 Oct 11 2002 04-Some Girls.mp3
-rw-r--r-- 1 0 0 6143710 Oct 11 2002 05-Lies.mp3
-rw-r--r-- 1 0 0 8456696 Oct 11 2002 06-Far Away Eyes.mp3
-rw-r--r-- 1 0 0 6035877 Oct 11 2002 07-Respectable.mp3
-rw-r--r-- 1 0 0 6586747 Oct 11 2002 08-Before They Make Me Run.mp3
-rw-r--r-- 1 0 0 8498492 Oct 11 2002 09-Beast of Burden.mp3
-rw-r--r-- 1 0 0 7307308 Oct 11 2002 10-Shattered.mp3
/drive0/Rock/U2:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Best of 1980-1990
/drive0/Rock/U2/Best of 1980-1990:
total 123296
-rw-r--r-- 1 0 0 7360222 Oct 11 2002 01-Pride (In the Name of Love).mp3
-rw-r--r-- 1 0 0 8293107 Oct 11 2002 02-New Year's Day.mp3
-rw-r--r-- 1 0 0 9564539 Oct 11 2002 03-With or Without You.mp3
-rw-r--r-- 1 0 0 9000294 Oct 11 2002 04-I Still Haven't Found What I'm Looking For.mp3
-rw-r--r-- 1 0 0 9030387 Oct 11 2002 05-Sunday Bloody Sunday.mp3
-rw-r--r-- 1 0 0 11248914 Oct 11 2002 06-Bad.mp3
-rw-r--r-- 1 0 0 8863203 Oct 11 2002 07-Where the Streets Have No Name.mp3
-rw-r--r-- 1 0 0 6974028 Oct 11 2002 08-I Will Follow.mp3
-rw-r--r-- 1 0 0 9466736 Oct 11 2002 09-The Unforgettable Fire.mp3
-rw-r--r-- 1 0 0 5870616 Oct 11 2002 10-Sweetest Thing [The Single Mix].mp3
-rw-r--r-- 1 0 0 5761946 Oct 11 2002 11-Desire.mp3
-rw-r--r-- 1 0 0 8268865 Oct 11 2002 12-When Love Comes to Town.mp3
-rw-r--r-- 1 0 0 7371089 Oct 11 2002 13-Angel of Harlem.mp3
-rw-r--r-- 1 0 0 18947722 Oct 11 2002 14-All I Want Is You.mp3
/drive0/lost+found:
total 0
/drive0/var:
total 16
-rw-r--r-- 1 0 0 692 Mar 9 23:58 config.ini
-rw-r--r-- 1 0 0 25 Mar 9 23:58 database
-rw-r--r-- 1 0 0 26 Jul 23 2003 database3
-rw-r--r-- 1 0 0 0 Mar 9 23:58 playlists
-rw-r--r-- 1 0 0 259 Mar 9 23:58 tags
empeg:/empeg/bin#
#294750 - 10/03/2007 02:45 Re: Need Help - Problem with used Empeg [Re: mlord]
brax
Loc: Birmingham, AL
..and..
ls -lR /
empeg:/empeg/bin# ls -lR /
total 26
drwxr-xr-x 2 0 0 1024 Jul 6 2004 bin
drwxr-xr-x 2 0 0 1024 Jul 4 2000 dev
drwxr-xr-x 9 0 0 4096 Oct 11 2002 drive0
drwxr-xr-x 2 0 0 1024 Jun 2 1999 drive1
drwxr-xr-x 4 0 0 1024 Jul 6 2004 empeg
drwxr-xr-x 3 0 0 1024 Sep 15 1999 etc
drwxr-xr-x 2 0 0 1024 Feb 9 2000 lib
drwx------ 2 0 0 12288 Jul 6 2004 lost+found
drwxr-xr-x 2 0 0 1024 Jun 2 1999 mnt
dr-xr-xr-x 18 0 0 0 Mar 10 01:34 proc
lrwxrwxrwx 1 0 0 3 Jul 6 2004 sbin -> bin
lrwxrwxrwx 1 0 0 10 Jul 6 2004 swapfile -> ./dev/hda6
drwxr-xr-x 2 0 0 1024 Apr 13 1999 tmp
drwxr-xr-x 4 0 0 1024 Feb 6 2000 usr
drwxr-xr-x 3 0 0 1024 Aug 28 1999 var
/bin:
total 2881
-rwx--x--x 1 0 0 10684 Nov 6 1999 badblocks
-rwxr-xr-x 1 0 0 502132 Feb 8 2000 bash
-rwxr-xr-x 1 0 0 10144 Feb 6 2000 cat
-rwxr-xr-x 1 0 0 13552 Feb 6 2000 chmod
-rwxr-xr-x 1 0 0 10024 Feb 6 2000 cmp
-rwxr-xr-x 1 0 0 34844 Feb 6 2000 cp
-rwxr-xr-x 1 0 0 32544 Feb 6 2000 dd
-rwxr-xr-x 1 0 0 28536 Feb 6 2000 df
-rwxr-xr-x 1 0 0 67772 Feb 6 2000 diff
-rwxr-xr-x 1 0 0 7136 Feb 6 2000 echo
-rwxr-xr-x 1 0 0 96444 Feb 6 2000 fdisk
-rwxr-xr-x 1 0 0 66301 Jul 6 2004 fsck
-rwx--x--x 1 0 0 120680 Jul 6 2004 fsck.ext2
-rwxr-xr-x 1 0 0 83292 Feb 6 2000 grep
lrwxrwxrwx 1 0 220 4 Jul 6 2004 gunzip -> gzip
-rwxr-xr-x 1 0 0 54892 Feb 6 2000 gzip
-rwxr-xr-x 1 0 0 7444 Feb 6 2000 halt
-rwx------ 1 0 0 151168 Sep 30 1999 hdstress
-rwxr-xr-x 1 0 0 232092 Jul 6 2004 init
-rwxr-xr-x 1 0 0 66700 Feb 6 2000 insmod
-rwxr-xr-x 1 0 0 20104 Feb 6 2000 ln
-rwxr-xr-x 1 0 0 47532 Feb 6 2000 ls
-rwxr-xr-x 1 0 0 14412 Feb 6 2000 mkdir
-rwxr-xr-x 1 0 0 63036 Jul 6 2004 mke2fs
-rwxr-xr-x 1 0 0 9568 Feb 6 2000 mkfifo
-rwxr-xr-x 1 0 0 12688 Feb 6 2000 mknod
-rwxr-xr-x 1 0 0 9560 Feb 6 2000 mkswap
-rwxr-xr-x 1 0 0 27260 Feb 6 2000 more
-rwsr-xr-x 1 0 0 66060 Feb 6 2000 mount
-rwxr-xr-x 1 0 0 44672 Feb 6 2000 mv
-rwxr-xr-x 1 0 0 7636 Feb 6 2000 nice
-rwxr-xr-x 1 0 0 26800 Feb 6 2000 od
-rwxr-xr-x 1 0 0 64700 Feb 6 2000 ps
-rwxr-xr-x 1 0 0 7444 Feb 6 2000 reboot
-rwxr-xr-x 1 0 0 22732 Feb 6 2000 rm
-rwxr-xr-x 1 0 0 7004 Feb 6 2000 rmdir
-rwxr-xr-x 1 0 0 121 Jul 4 2000 ro
-rwxr-xr-x 1 0 0 97 Jul 4 2000 rom
-rwxr-xr-x 1 0 0 35 Sep 30 1999 rw
-rwxr-xr-x 1 0 0 97 Jul 4 2000 rwm
-rwxr-xr-x 1 0 0 64668 Feb 6 2000 rz
-rwxr-xr-x 1 0 0 47280 Feb 6 2000 sed
lrwxrwxrwx 1 0 220 4 Jul 6 2004 sh -> bash
-rwxr-xr-x 1 0 0 14552 Feb 6 2000 shutdown
-rwxr-xr-x 1 0 0 29072 Feb 6 2000 stty
lrwxrwxrwx 1 0 220 6 Jul 6 2004 swapoff -> swapon
-rwxr-xr-x 1 0 0 6412 Feb 6 2000 swapon
-rwxr-xr-x 1 0 0 5616 Feb 6 2000 sync
-rwxr-xr-x 1 0 0 70588 Feb 6 2000 sz
-rwxr-xr-x 1 0 0 147068 Feb 6 2000 tar
-rwx------ 1 0 0 34380 Nov 6 1999 tune2fs
-rwsr-xr-x 1 0 0 37404 Feb 6 2000 umount
-rwxr-xr-x 1 0 0 376776 Feb 28 2001 userver
-rw-r--r-- 1 0 0 10 Feb 6 2000 x
/dev:
total 0
crw-r--r-- 1 0 0 245, 4 Jun 1 1999 audio
crw-r--r-- 1 0 0 249, 0 Jun 28 2000 audioin
lrwxrwxrwx 1 0 220 5 Jul 6 2004 console -> ttyS1
crw-r--r-- 1 0 0 244, 0 Apr 19 1999 display
crw-r--r-- 1 0 0 245, 3 Jun 1 1999 dsp
crw-r--r-- 1 0 0 250, 0 Jun 28 2000 empeg_power
crw-r--r-- 1 0 0 246, 0 Apr 18 1999 empeg_state
brw------- 1 0 0 3, 0 Apr 18 1999 hda
brw------- 1 0 0 3, 1 Apr 18 1999 hda1
brw------- 1 0 0 3, 2 Apr 18 1999 hda2
brw------- 1 0 0 3, 3 Apr 18 1999 hda3
brw------- 1 0 0 3, 4 Apr 18 1999 hda4
brw------- 1 0 0 3, 5 Apr 18 1999 hda5
brw------- 1 0 0 3, 6 Apr 18 1999 hda6
brw------- 1 0 0 3, 7 Apr 18 1999 hda7
brw------- 1 0 0 3, 8 Apr 18 1999 hda8
brw------- 1 0 0 3, 9 Apr 18 1999 hda9
brw------- 1 0 0 3, 64 Nov 26 1999 hdc
brw------- 1 0 0 3, 65 Nov 26 1999 hdc1
brw------- 1 0 0 3, 66 Nov 26 1999 hdc2
brw------- 1 0 0 3, 67 Nov 26 1999 hdc3
brw------- 1 0 0 3, 68 Nov 26 1999 hdc4
brw------- 1 0 0 3, 69 Nov 26 1999 hdc5
brw------- 1 0 0 3, 70 Nov 26 1999 hdc6
brw------- 1 0 0 3, 71 Nov 26 1999 hdc7
brw------- 1 0 0 3, 72 Nov 26 1999 hdc8
brw------- 1 0 0 3, 73 Nov 26 1999 hdc9
crw-r--r-- 1 0 0 242, 0 Jun 1 1999 ir
crw-r--r-- 1 0 0 1, 2 Apr 18 1999 kmem
crw-r--r-- 1 0 0 1, 1 Apr 18 1999 mem
crw-r--r-- 1 0 0 245, 0 Jun 1 1999 mixer
crw-r--r-- 1 0 0 1, 3 Apr 18 1999 null
lrwxrwxrwx 1 0 220 6 Jul 6 2004 radio -> radio0
crw-r--r-- 1 0 0 81, 64 Jun 1 1999 radio0
brw-r--r-- 1 0 0 1, 0 Apr 18 1999 ram0
brw-r--r-- 1 0 0 1, 1 Apr 18 1999 ram1
brw-r--r-- 1 0 0 1, 2 Apr 18 1999 ram2
brw-r--r-- 1 0 0 1, 3 Apr 18 1999 ram3
crw-r--r-- 1 0 0 1, 8 Jun 2 1999 random
crw------- 1 0 0 248, 0 Aug 25 1999 rds0
crw-r--r-- 1 0 0 5, 0 Apr 18 1999 tty
crw-r--r-- 1 0 0 4, 0 Apr 18 1999 tty0
crw-r--r-- 1 0 0 4, 1 Apr 18 1999 tty1
crw-r--r-- 1 0 0 4, 2 Apr 18 1999 tty2
crw-r--r-- 1 0 0 4, 64 Mar 10 01:34 ttyS0
crw-r--r-- 1 0 0 4, 65 Mar 10 01:39 ttyS1
crw-r--r-- 1 0 0 4, 66 Apr 18 1999 ttyS2
crw-r--r-- 1 0 0 1, 9 Jun 2 1999 urandom
lrwxrwxrwx 1 0 220 4 Jul 6 2004 usb -> usb0
crw-r--r-- 1 0 0 243, 0 May 22 1999 usb0
crw-r--r-- 1 0 0 1, 5 Apr 18 1999 zero
/drive0:
total 40
/drive0/Blues:
total 28
total 4
total 67704
total 62056
total 75724
total 4
total 106088
total 4
total 65448
total 4
total 64348
total 74572
/drive0/Classical:
total 40
total 66648
total 76680
total 73276
total 80828
total 89256
total 90804
total 68092
total 96564
total 78328
total 85792
/drive0/Italian:
total 32
total 4
total 117388
total 4
total 78788
-rw-r--r-- 1 0 0 6569151 Oct 11 2002 07 La canzone dei vecchi amanti.mp3
-rw-r--r-- 1 0 0 6620142 Oct 11 2002 08 Era de Maggio.mp3
-rw-r--r-- 1 0 0 6656087 Oct 11 2002 09 Che cosa resta.mp3
-rw-r--r-- 1 0 0 4730131 Oct 11 2002 10 Amore che vieni, amore che vai.mp3
-rw-r--r-- 1 0 0 5036913 Oct 11 2002 11 Medievale.mp3
-rw-r--r-- 1 0 0 14291365 Oct 11 2002 12 Invito al viaggio.mp3
/drive0/Italian/Manu Chao:
total 4
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Clandestino_ Esperando
/drive0/Italian/Manu Chao/Clandestino_ Esperando:
total 86204
-rw-r--r-- 1 0 0 4751881 Oct 11 2002 01 Clandestino.mp3
-rw-r--r-- 1 0 0 7274683 Oct 11 2002 02 Desaparecido.mp3
-rw-r--r-- 1 0 0 5072872 Oct 11 2002 03 Bongo Bong.mp3
-rw-r--r-- 1 0 0 3932687 Oct 11 2002 04 Je Ne T'Aime Plus.mp3
-rw-r--r-- 1 0 0 8867939 Oct 11 2002 05 Mentira.mp3
-rw-r--r-- 1 0 0 5687277 Oct 11 2002 06 Lagrimas de Oro.mp3
-rw-r--r-- 1 0 0 4522837 Oct 11 2002 07 Mama Call.mp3
-rw-r--r-- 1 0 0 5999070 Oct 11 2002 08 Luna y Sol.mp3
-rw-r--r-- 1 0 0 4528692 Oct 11 2002 09 Por el Suelo.mp3
-rw-r--r-- 1 0 0 7815530 Oct 11 2002 10 Welcome to Tijuana.mp3
-rw-r--r-- 1 0 0 2888629 Oct 11 2002 11 Dia Luna- Dia Pena.mp3
-rw-r--r-- 1 0 0 5610367 Oct 11 2002 12 Malegria.mp3
-rw-r--r-- 1 0 0 5785072 Oct 11 2002 13 La Vie.mp3
-rw-r--r-- 1 0 0 4539559 Oct 11 2002 14 Minha Galera.mp3
-rw-r--r-- 1 0 0 6076813 Oct 11 2002 15 La Despedida.mp3
-rw-r--r-- 1 0 0 4693365 Oct 11 2002 16 El Viento.mp3
/drive0/Italian/Pino Daniele:
total 8
drwxr-xr-x 2 0 0 4096 Oct 11 2002 Medina
drwxr-xr-x 2 0 0 4096 Oct 11 2002 The Best Of, Yes I Know My Way
/drive0/Italian/Pino Daniele/Medina:
total 102176
-rw-r--r-- 1 0 0 9052665 Oct 11 2002 01 Via Medina.mp3
-rw-r--r-- 1 0 0 7425968 Oct 11 2002 02 Evviva 'o Rre'.mp3
-rw-r--r-- 1 0 0 8328760 Oct 11 2002 03 Tempo Di Cambiare.mp3
-rw-r--r-- 1 0 0 8628854 Oct 11 2002 04 Sara.mp3
-rw-r--r-- 1 0 0 7736093 Oct 11 2002 05 Senza 'e Te.mp3
-rw-r--r-- 1 0 0 8311205 Oct 11 2002 06 Mareluna.mp3
-rw-r--r-- 1 0 0 8563653 Oct 11 2002 07 Lettera Dal Cuore.mp3
total 117104
total 4
total 80696
total 4
total 90984
total 8
total 112532
total 121044
total 8
total 84016
total 139720
/drive0/Jazz:
total 44
total 45512
total 79764
total 76636
total 89216
total 34164
total 91360
total 84752
total 31808
total 87352
total 73320
total 82840
/drive0/Rock:
total 44
total 4
total 132160
total 4
total 78504
total 4
total 92212
total 4
total 87788
/drive0/Rock/REM:
total 4
total 100984
total 4
total 140916
-rw-r-
#294751 - 10/03/2007 03:58 Re: Need Help - Problem with used Empeg [Re: brax]
What the hell?
Are those songs that you tried to upload? I'm guessing not.
We'll come back to this, but it looks like the main problem is a lack of a "fids" directory.
Run "rwm". Then run "mkdir /drive0/fids". Then "rom". Then "player". Then try to use emplode.
#294752 - 10/03/2007 04:09 Re: Need Help - Problem with used Empeg [Re: wfaulk]
Yeah, I'm with Bitt. What the hell?
Brax, you should NOT BE ABLE TO SEE SONG FILES. The empeg does not store its files that way.
Whoever had the player before you COMPLETELY SCREWED IT UP or at least did nonstandard things to it.
Start the whole thing over from scratch. Go to riocar.org. Go to the DISK UPGRADE GUIDE there on riocar.org. Find the parts about downloading the BUILDER IMAGES and the section about FORMATTING A NEW DISK.
Follow those.
#294753 - 10/03/2007 04:19 Re: Need Help - Problem with used Empeg [Re: wfaulk]
brax
Loc: Birmingham, AL
What the hell?
Nope not my songs. I think the guy that had it just wiped it clean (or tried to). Anyway I was able to sync without any warnings and able to add a play list and a song to emplode with out it crashing!!!!
So not saying that it is fixed but it does at least let me get started.
So what about all those songs that showed up? They don't show up on the player. Are they really there or is it just a list of everything that was on the player?
#294754 - 10/03/2007 04:25 Re: Need Help - Problem with used Empeg [Re: brax]
Right because they are not supposed to be there. The empeg doesn't store its songs as loosely named MP3 files like that. It stores them in a completely different way. Someone who had the player before you filled up its hard drive with loose songs that you'll never be able to play.
They either didn't know what they were doing, or they were doing something nonstandard like running some other kind of player software. Either way, you're not going to be able to use those hard disk(s) in that state. You must wipe the drives from scratch, by partitioning and formatting them with the builder images mentioned in the Disk Upgrade Guide at riocar.org.
#294755 - 10/03/2007 04:28 Re: Need Help - Problem with used Empeg [Re: tfabris]
brax
Loc: Birmingham, AL
Well I guess that will be tomorrow's task, getting late for me and kids will be up in about 5hrs or sooner.
Anyway I was at least able to get a song loaded on the player and looks like I can sync without any warnings or errors.
I am just glad that I have a working unit, espically since my tuner kit should be in soon.
Thanks to all those that helped!!!! I'll post my results on what all I do incase anyone is interested.
Also one last thing that I was curious about and may have just missed it when I have been reading up on the player. The LED in the upper right corner, is it suppose to blink when the player has power to it but is not on? I am assuming that this means that it is in a "standby" type mode?
Edited by brax (10/03/2007 04:29)
#294756 - 10/03/2007 06:13 Re: Need Help - Problem with used Empeg [Re: brax]
Welcome to the world of Empeg. Glad your player is working now.
When you get a chance, have a browse through the FAQ. You can even search for things like... blinking led.
#294757 - 10/03/2007 06:41 Re: Need Help - Problem with used Empeg [Re: brax]
TigerJimmy
Here is a post I made for new owners. You might find something useful there.
Jim
#294758 - 10/03/2007 10:45 Re: Need Help - Problem with used Empeg [Re: TigerJimmy]
Hey brax, its always good to see new Empeg users. A while back I tagged some useful Empeg webpages on my del.icio.us account, I guess they would be useful to a new owner too: link. Have fun with it
#294759 - 10/03/2007 12:24 Re: Need Help - Problem with used Empeg [Re: brax]
You can rerun the disk builder if you want, or you can just delete those extraneous mp3s.
Log back in with the serial cable. Type "rwm". Type "cd /drive0". Type "rm -rf Blues Classical Italian Jazz Rock". (This will probably take a couple of minutes.) Then, when you get a prompt back, type "cd /" and then "rom".
Those commands will delete all of those files. Honestly, they're not harming anything being there now, just wasting disk space.
Or. again, you can run the disk builder. I think my way is easier, especially since we know that it's working properly now.
#294760 - 10/03/2007 15:25 Re: Need Help - Problem with used Empeg [Re: wfaulk]
You should probably also help him fix up the config.ini file -- I'm betting it's also got something screwed up about it. Maybe just delete it, and let emplode recreate it properly.
#294761 - 10/03/2007 15:27 Re: Need Help - Problem with used Empeg [Re: brax]
Hey brax: great job getting the info we needed to diagnose this. You're already way ahead of many other folks here on that front!
#294762 - 10/03/2007 18:07 Re: Need Help - Problem with used Empeg [Re: mlord]
brax
Loc: Birmingham, AL
Thanks! About the closest I have come to Linx is Unix. I have used Unix before at a previous job but it has been years. Also, as far as doing any real Unix coding it was very limited. Mainly only used it for storing tests programs which were in C/C++ and then I moved up to things that used Excel with VB code behind it.
#294763 - 10/03/2007 18:59 Re: Need Help - Problem with used Empeg [Re: tfabris]
brax
Loc: Birmingham, AL
Well I am unable to run the disk builder, I get
Error "Couldn't find pump" occured during stage 0x20
In reading some on riocar.org it sounds like I might have a bad drive maybe?
I am able to put the developer v2.01 back on though.
Edited by brax (10/03/2007 19:12)
#294764 - 10/03/2007 19:49 Re: Need Help - Problem with used Empeg [Re: brax]
Naw, the drive is fine.
Just use 2.01, then, and nuke all of those unwanted files -- See wfaulk's postings for instructions there.
#294765 - 10/03/2007 20:49 Re: Need Help - Problem with used Empeg [Re: wfaulk]
brax
Loc: Birmingham, AL
I ran this and it looks like it has wipped all those files out. It shows that I have 28gig of free space which is about right since it's a 30gig model.
Thanks again to everyone!!!!!!!!!!!!!!!!!!!!!!!!!
Fedex tried to deliever my tuner but we were not here so I guess I get to start building it next week. Now soldering I am more comfortable with as I build proto-type PCB's for work.
Page 2 of 2 < 1 2
