#298430 - 15/05/2007 18:42 Karma powers up fine, but won't play music
Bagpuss
Hi All,
Just wondering if someone can help me.
I was lucky enough to acquire a Karma through the raffle at last years Empeg meet. It has worked fine, up until a few days ago.
It's got about 18GB of music on it, and still boots up just fine. I can navigate through playlists, select tracks and even rebuild the music database. There are also no bad tracks listed.
However, when I select a track it just refuses to play. The timecode indicator remains on 0:00. I can move forwards and backwards through the track listings, but cannot fast forward or rewind with a track.
Has anyone seen this before? Is there a solution?
Thanks,
Andy.
#298431 - 16/05/2007 13:48 Re: Karma powers up fine, but won't play music [Re: Bagpuss]
I had something like this once, I think the only way I got it to work again was to delete all the music and reload
#298432 - 28/05/2007 09:02 Re: Karma powers up fine, but won't play music [Re: Bagpuss]
Try upgrading from recovery mode (hold menu then power on). ISTR there's an "erase everything" tickbox in the upgrader?
That should probably fix it - it sounds like something in a state file has got borked. You'll lose the content from there unless you copy it off first (obviously)
