#299464 - 16/06/2007 08:22 Empeg not working, probably IDE problems
shapeless
Loc: Italy
Three days ago I've upgraded my 60GB hd with a new 120GB one, I've formatted the new one, reinstalled alpha11+the last hijack and transferred all the fids from the old HD as shown in the f.a.q.. Everything worked well for three days, the empeg worked at home and in car, everything perfect.
Today I've powered up the empeg and it freezed with the display showing this popup:
0000.3 hda: err: stat_err
First of all I've thought at HD failure so I've replaced the new 120GB disk with the old 60GB one but I've exactly the same problem.
this is the serial log:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v476 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Thu May 17 20:32:18 EDT 2007
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101588) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9a790
Tuner: loopback=0, ID=-1
show_message("Hijack v476 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg usb initialised, PDIUSBD12 id 1010
empeg state support initialised 0089/88c1 (save to d0004f00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xff80
ide_data_test: wrote 0xffff read 0xff80
ide_data_test: wrote 0xaaaa read 0xff80
ide_data_test: wrote 0x5555 read 0x5580
ide_data_test: wrote 0xaaaa read 0xeb80
ide_data_test: wrote 0x0000 read 0xfffd
ide_data_test: wrote 0xffff read 0xfffd
ide_data_test: wrote 0xaaaa read 0xfffd
ide_data_test: wrote 0x5555 read 0x7ffd
hda: TMSHI@A MI1034GAX, ATA DISK drive
hda: TMSHI@A MI1034GAX, 114473MB w/0kB Cache, CHS=14593/255/63
smc chip id/revision 0x0000
smc_init couldn't find card
Partition check:
hda:hda: set_multmode: status=0x58
hda: stat_err: status=0x58
show_message("0000.3 hda: err: stat_err")
hda: drive not ready for command
ide0: unexpected interrupt, status=0x58, count=1
unknown partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
I've just had problems with IDE years ago, because of this Rob repaired my empeg 2 times, the last one he changed the IDE cable with a brand new one and resoldered/glued the board connector. I've triple checked everything, I've reinstalled 2.0, 3a11 and various hijack versions but nothing, I really don't know what to do :/
Thanks for any help or support! :'/
shapeless
MK2a | #010101588 | 2x 120GB SSD  | Hijack v526 | v3.0a11 | > melpomene <
MK2   | #090000581 | 60 & 100GB HD | v2final.mk2 | v2.01 | > backup <
radio | all colors lens | greenlights LBSSK buttons | KCA-R6A + ERC-1A remotes | carry cases | empeg sticker!
#299465 - 17/06/2007 00:42 Re: Empeg not working, probably IDE problems [Re: shapeless]
There's definitely something wrong with the hardware here -- the SMC ethernet chip is not being detected, plus the hard drive data is getting corrupted.
Could be a bad cable, bad header, bad SMC chip, or other possibliities.
#299466 - 17/06/2007 00:48 Re: Empeg not working, probably IDE problems [Re: mlord]
Mmm.. since the D7 line appears to be stuck high, I'm leaning towards a faulty SMC ethernet chip as the culprit now. But it does require some hardware debugging to make sure of that -- soldering and lifting pins and such.
#299467 - 17/06/2007 02:00 Re: Empeg not working, probably IDE problems [Re: mlord]
shapeless
Loc: Italy
Thank you very much for the reply Mark, it's always a pleasure to have someone to talk to in this hard cases.
I've just asked Schofiel for (the third) repair but still no answer, if he doesn't have time, would you please consider to give it a look? I'm quite good with solderings of normal components and chips but i can't do SMD, do you think I can give it a try?
In the end, do you have an idea of the cause of this failure? Does the HD upgrade could be the problem? Thanks.
shapeless
#299468 - 17/06/2007 10:35 Re: Empeg not working, probably IDE problems [Re: mlord]
Mmm.. cancel that thought. Actually, data bit D1 is very clearly stuck low, and I'm not sure about the rest of the bits.
Mmmm..
#299469 - 17/06/2007 10:41 Re: Empeg not working, probably IDE problems [Re: shapeless]
Yes, I can look at it, eventually. It could take a month or two, or just an evening, depending very much upon my up-to-the-minute schedule and how inspired I feel about it on any given day.
Try Rob Schofiel first, and use email to arrange things with me after that.
I don't know what causes things like this to fail. The usual sources of random bit failures in electronics are (1) dirty power (under/over voltage, spikes, noise, etc), and (2) ESD (electro-static discharge) damage from mishandling things. The empeg is darned near tough as nails much of the time, but it's not immune to such problems either.
#299470 - 19/06/2007 05:57 Re: Empeg not working, probably IDE problems [Re: mlord]
shapeless
Loc: Italy
Hi Mark, I've just sent you an email, please let me know when you read it, thanks.
shapeless
