#303030 - 13/10/2007 07:44 HD and Ethernet woes
My main player has been getting the 'No Harddisc' error more and more recently. I initally suspected the HD as it's been in since I first had the player and has had it's fair share of knocks and bumps. So I just bought a new 100GB drive and tried installing that. Now, it's been literally 'years' since I looked at the boot log or added any music to it. Upon connecting I found it had the following in the boot log:
ide_data_test: wrote 0x0000 read 0x8080
ide_data_test: wrote 0xffff read 0x8080
ide_data_test: wrote 0xaaaa read 0x8080
(I actually stole this from someone else's post so the numbers aren't the same)
I also connected the ethernet up for the first time in a long time and found that inop too. A further inspection of the boot log revealed:
smc chip id/revision 0x0249
smc_init couldn't find card
So it looks like it can't find the network chip. Could this arise from a dry joint or damaged pin on the IDE header? If so, does anyone have a part number for a suitable replacement header? I can get it replaced at work.
#303031 - 13/10/2007 10:45 Re: HD and Ethernet woes [Re: andym]
1. When things fail, the exact numbers in the IDE data test boot log *matter*.
2. The header never needs replacing. But it often does need to be soldered down properly.
#303032 - 13/10/2007 13:20 Re: HD and Ethernet woes [Re: mlord]
In which case:
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xd0d0
ide_data_test: wrote 0xffff read 0xd0d0
ide_data_test: wrote 0xaaaa read 0xd0d0
ide_data_test: wrote 0x5555 read 0xd0d0
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
hda: FUJITSU MHV2100AH, ATA DISK drive
hda: FUJITSU MHV2100AH, 95396MB w/8192kB Cache, CHS=12161/255/63
#303033 - 13/10/2007 18:54 Re: HD and Ethernet woes [Re: andym]
In which case:
Okay, IDE bus is fine. Maybe post the entire boot log now,
and we'll see about the other devices from that.
#303034 - 14/10/2007 09:35 Re: HD and Ethernet woes [Re: mlord]
Here we go.....
On DC power, quick boot
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v479 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Tue Sep 4 09:18:20 EDT 2007
Checking for extra DRAM:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 10101731) 32MB DRAM
Command line: mem=16m noinitrd
Memory: 31232k/32M available (988k code, 20k reserved, 524k data, 4k init)
Dentry hash table entries: 4096 (order 3, 32k)
Buffer cache hash table entries: 32768 (order 5, 128k)
Page cache hash table entries: 8192 (order 3, 32k)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 32768 bhash 32768)
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x99778
Tuner: loopback=1, ID=-1
Forced AC/Home mode
show_message("Hijack v479 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005480).
empeg RDS driver initialised
smc chip id/revision 0x3349
Partition check:
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 4k init
Timezone: Atlantic/South_Georgia
empeg init 0.8
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Com Starting player
Using non-standard cache size 324 (bonus 16Mb, adjustment 0)
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4153a000
#303035 - 14/10/2007 14:29 Re: HD and Ethernet woes [Re: andym]
Here we go.....
Okay, it mostly all looks normal except for that bit about the smc ethernet chip.
In your first posting, you wrote a different value for the "smc chip id/revision" line.
Was that correct?
Does it now always give 0x3349 for you?
Here's the "normal" output from one of my Mk2a players:
hda: FUJITSU MHT2080AT, 76319MB w/8192kB Cache, CHS=9729/255/63
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:ea
The detection/initialization code (in linux/drivers/net/smc9194_tifon.c)
is rather difficult for me to follow, so I'm not sure exactly why it first sees the chip
(0x3349) and then later decides that there's no chip present (?).
But one could instrument that code (add a bunch of printk() lines to see
exactly where it bops out) to get a better idea of what the trouble might be.
There's nothing definitive there yet.
Edited by mlord (14/10/2007 14:32)
#303036 - 15/10/2007 19:09 Re: HD and Ethernet woes [Re: mlord]
Yes, it always returns 0x3349 now. Must've been a typo, had to copy that bit over by hand.
Well, i've just got my empeg dev environment together and I've just sucessfully rolled and installed a new kernel (my version prints a swear word in the boot log). So I'll have a look at the code tomorrow and stick a load of printk()'s in.
#303037 - 17/10/2007 16:48 Re: HD and Ethernet woes [Re: andym]
I'm wondering wether there is a fault with the IDE header.... This is what happens when I put the good disk on the other connector of the drive cable....
e000 v1.04
Copying kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v479 (root@empeg-builder) (gcc version 2.95.3 20010315 (release)) #4 Mon Oct 15 05:04:35 PDT 2007
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
Tuner: loopback=0, ID=-1
empeg state support initialised 0089/88c1 (save to d0004100).
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xfeff
ide_data_test: wrote 0x5555 read 0xff7f
ide_data_test: wrote 0x0000 read 0xff7f
ide_data_test: wrote 0x5555 read 0xffff
smc chip id/revision 0x3249
RAMDISK: Couldn't find valid RAM disk image starting at 0.
VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
#303038 - 17/10/2007 16:56 Re: HD and Ethernet woes [Re: andym]
....and this with 2 disks....
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
empeg state support initialised 0089/88c1 (save to d0004180).
hdb: FUJITSU MHV2100AH, ATA DISK drive
ide_data_test: wrote 0xaaaa read 0xffff
ide0: unexpected interrupt, status=0xff, count=1
hdb: FUJITSU MHV2100AH, 95396MB w/8192kB Cache, CHS=12161/255/63
Partition check:
