#310530 - 27/05/2008 20:51 dead temp sensor
Boelle
Loc: Denmark, Odense
sorry for asking, but how do i most easy fix a temp sensor that is showing 0 degress ccentigrade even that it's 20 degrees ?
can i get around it without the soldering iron?
#310532 - 27/05/2008 21:43 Re: dead temp sensor [Re: Boelle]
Easiest is to send it to Stu or somebody else to fix.
You need to be able to solder to fix it.
#310537 - 27/05/2008 23:14 Re: dead temp sensor [Re: tman]
Yeah, attempting self-repair is fine for those with electronics experience, but rather risky for others.
Here's the relevant thread.
#310562 - 28/05/2008 15:09 Re: dead temp sensor [Re: mlord]
And the other relevant post.
#310592 - 29/05/2008 10:54 Re: dead temp sensor [Re: canuckInOR]
Boelle
i did the fix with no problems, but how do i change the corrected temp in hijack? can that only be done in the real hijack and not the special one used when fixing the sensor?
#310593 - 29/05/2008 11:06 Re: dead temp sensor [Re: Boelle]
Boelle
btw.. there is a jumper located just in front of the power connector.. does any know what it is for?
#310594 - 29/05/2008 11:38 Re: dead temp sensor [Re: Boelle]
I believe it was intended for a factory fan, but isn't really useful as such (constant voltage, no s/w control, ..).
#310595 - 29/05/2008 11:40 Re: dead temp sensor [Re: Boelle]
If you mean the -4 degree adjustment, then that's a config.ini parameter.
But the chip is accurate to within one degree already, so the numbers you see are quite good for the vicinity of the chip itself.
In config.ini:
[hijack]
temperature_correction=0 ;; default is -4
#310599 - 29/05/2008 11:58 Re: dead temp sensor [Re: mlord]
Boelle
it's just because it reads around 8 degrees to much
my plan is to have a precision termometer just on top of the chip and see what difference there is....
#310625 - 29/05/2008 14:27 Re: dead temp sensor [Re: Boelle]
Boelle
the sensor says 28 degrees centigrade, but an external termometer says 25,5 to 26,1
is it normal to be off like that?
#310634 - 29/05/2008 15:25 Re: dead temp sensor [Re: Boelle]
Boelle
just re soldered pin 8.. now the temp is precise
