#310768 - 31/05/2008 13:35 Which mini-ITX board to buy?
StigOE
"Inspired" by Mark's post about his low wattage server and the fact that my gateway/mail/web-server died a week ago (don't know if it is hardware or software problem since I haven't had the chance to check it yet), I figured I'd build a mini-ITX machine with a couple of laptop drives in it to use as my firewall, mail and web server. I checked a netshop in Norway and they had a few boards, but since the internet is dog slow here at work, I thought I'd ask here for advice where several people have experience with various mini-ITX boards already...
Is SATA interface for 3.5" and 2.5" the same or would I need some kind of adapter like with IDE drives?
The machine will be running Linux (Clarkconnect firewall-distro), Xmail mail-server with ClamAV anti-virus scanning, Apache, Perl, php and MySQL for a content management system under Apache. It will be running basically headless, but connected to a KVM switch. Since it would act as a firewall, I would need two network cards, but I guess I can use a USB-dongle for the internet side.
The various boards I found are:
Gigabyte GA-GC230D, Intel® Atom™1.6GHz, Mini-ITX, I945GC, DDR2, LAN, PCI, SATA (no other info yet, not available until July 1st)
VIA EPIA-EN12000EG,EDEN V4/1200Mhz,SATA, Mini-ITX, DDR2-533, Fanless,LAN,Firewire (max 1GB RAM)
VIA EPIA-CN13000G, C7/1300Mhz, Mini-ITX, DDR2-533, SATA, VGA, LYD, LAN (max 1GB RAM)
VIA EPIA-EX15000G, C7/1500Mhz, Mini-ITX, CX700M2,DDR2,VGA,DVI,LAN,Tv-Out,Firewire (max 1GB RAM)
VIA EPIA-LT15000AG, C7/1500Mhz, Mini-ITX ,CX700, DDR2, VGA, LYD, LAN, COM (max 1GB RAM)
VIA EPIA-SN18000G, C7/1800Mhz, Mini-ITX DDR2, VGA, LYD, SATAII, PCI-Ex16 (max 4GB RAM, available end of next week)
So, does anybody have a suggestion as to which board I should get?
Tia,
Stig
#310770 - 31/05/2008 14:05 Re: Which mini-ITX board to buy? [Re: StigOE]
I'd go for the Atom. It is quite a bit more powerful than the current VIA C7s.
There are other manufacturers of Intel Atom boards. Intel make some as well.
What is LYD?
#310772 - 31/05/2008 14:19 Re: Which mini-ITX board to buy? [Re: tman]
Maybe it's supposed to be LVD?
#310773 - 31/05/2008 14:39 Re: Which mini-ITX board to buy? [Re: tman]
StigOE
What is LYD?
Oops, didn't notice that... blush Lyd = sound
May be I need to look some other places also, not just in Norway... smile Seems like the ITX cases are also quite big.
Stig
#310774 - 31/05/2008 14:47 Re: Which mini-ITX board to buy? [Re: StigOE]
If you don't mind it being a 1GHz C7 then the VIA Pico-ITX boards would work and they're pretty small. VIA sell a kit called the ARTiGO.
#310775 - 31/05/2008 15:15 Re: Which mini-ITX board to buy? [Re: StigOE]
I cannot find my old postings/photos of my own mini-ITX server, but I did find this thread which has some notes about PSUs for them and the like.
More in a minute or three..
#310776 - 31/05/2008 15:28 Re: Which mini-ITX board to buy? [Re: StigOE]
My own mini-ITX server acts as our xDSL gateway (PPPoE client), runs apache2 (web), smtpd (incoming email), spam filtering, imap/pop3 (for email clients), cupsd (print server), NFS/Samba fileservers, vpn/ssh (for remote access), manages our backyard kitty-cam, records/reencodes scheduled CBC radio shows off the web, acts as our complete SPI firewall (with custom enhancements), holds/serves my entire online photo archives, and half a dozen other minor services that I've forgotten about.
Needless to say it uses (Debian) Linux for the task, which enables it to just work fine on low-power hardware. The motherboard is a VIA EPIA-CL6000E, chosen because it is totally fanless/silent and has *two* onboard 10/100 ethernet ports, plus a plethora of other built-ins including USB2, VGA, PS2 KB/Mouse, sound, parallel port, and a gazillion serial ports.
I've equipped it with 512MB of SDRAM, which is plenty. It could handle a full GB, but then it would consume more power for no good reason.
Fanless is *very* nice, so I paired it with a snap-on PSU designed for it (also fanless), which is fed from a +12V power brick (no fan there, either). One big (for the day) notebook drive on the inside, and voila -- a nice 24/7 micro-server.
It has been rebooted maybe 5 times in the past 3-4(?) years since installation: basically only when I needed to rearrange the power cords, or wanted to try a newer Linux kernel on it. It has already outlived one UPS, and watched silently as other systems came and went.
It has one now-open PCI slot, that used to house a third ethernet port for a DMZ for an old wireless AP we once had.
The interface/connectors are 100% identical -- no issues there.
That's not a heavy load by any stretch, so go for whatever system you can get that is fanless (silent!), assuming you are pairing it with notebook drives. And look for a motherboard that has dual-onboard ethernet, which will save you a couple of watts of power.
#310777 - 31/05/2008 15:30 Re: Which mini-ITX board to buy? [Re: tman]
StigOE
I think I'll go for something a bit more powerful when I'm building something now. The machine is running dual 1GHz on the infamous Abit VP6 motherboard now (well, should have been running... smile). Looked at the T7 from Tranquilpc that you linked to, but they will use 2-3 weeks for sending it.
Stig
#310778 - 31/05/2008 15:33 Re: Which mini-ITX board to buy? [Re: StigOE]
Stig
The thing about "more powerful", is that it will use more power. 600Mhz is plenty of ooomph for a light server such as this, and can be done totally silent.
Modern CPUs can probably do 1GHz fanless, but above that it's just a waste of valuable energy much of the time.
#310779 - 31/05/2008 15:40 Re: Which mini-ITX board to buy? [Re: mlord]
My own mini-ITX server ... motherboard is a VIA EPIA-CL6000E ...
Oh, and it lives in a cookie tin:
Description: "zippy", our 24/7 server.
Description: Inside the cookie tin..
#310780 - 31/05/2008 15:46 Re: Which mini-ITX board to buy? [Re: mlord]
I would probably go with a VIA EPIA SN10000EG (1GHz fanless) mini-ITX board today.
It has both PATA(IDE) and SATA interfaces, dual onboard LAN, an a PCIe slot for expansion.
Edit: Here's another link for it, with price and good photos.
Edited by mlord (31/05/2008 18:13)
#310781 - 31/05/2008 15:48 Re: Which mini-ITX board to buy? [Re: mlord]
StigOE
Thanks, Mark.
Looks like the fanless boards they have at the netshop are only up to 1GHz, and the only one with two NICs is 800MHz. This machine will be in my basement, so it doesn't have to be totally noiseless, so maybe futureproof it some by choosing around 1500MHz processor would be better?
Stig
#310782 - 31/05/2008 15:59 Re: Which mini-ITX board to buy? [Re: mlord]
StigOE
Thanks again, Mark.
I found this also on the netshop, but there were no info other than it contained LAN.
Hmm, maybe I should listen to the resident Linux expert and order this card...? smile
#310783 - 31/05/2008 16:04 Re: Which mini-ITX board to buy? [Re: StigOE]
I'm just a big fan of no fans! smile
  • totally silent, so it can live upstairs in my office, and share a UPS with the DSL modem and our low-power (~4-watts) 24-port network switch.
  • fanless means it's not wasting as much power as systems with fans.
  • no fan to fail and kill the system later.
#310784 - 31/05/2008 16:42 Re: Which mini-ITX board to buy? [Re: tman]
There might be better VIA alternatives than the Atom already... smile
(see here for the official press release, including a table with the available speeds)
#310785 - 31/05/2008 17:07 Re: Which mini-ITX board to buy? [Re: BartDG]
StigOE
I've ordered the board Mark linked to, along with a stick of RAM and a couple of harddrives, so hopefully the package arrives about the same time I get home. It won't be completely noiseless as I will be running it with a regular, although lownoise, PSU. At least for now. I'm quite impulsive as long as I've had the time to think thorougly through something... smile
Stig
#310788 - 31/05/2008 18:03 Re: Which mini-ITX board to buy? [Re: StigOE]
If you eventually upgrade to a silent PSU, I highly recommend the PicoPSU ones, in conjunction with a fanless +12VDC power brick that plugs into the wall.
cheers
#310790 - 31/05/2008 18:18 Re: Which mini-ITX board to buy? [Re: mlord]
I've updated my post above with a better link for this board,
with lots of good photos showing the heatsinks, connectors, etc..
#310793 - 31/05/2008 20:52 Re: Which mini-ITX board to buy? [Re: mlord]
I've got a big ugly full tower here running 24/7 that I should really get rid of. It ran MythTV (taken over by Sky+), Asterisk (taken over by cheap mobile phones) and a bunch of other fairly redundant stuff.
Thinking about a fanless Epia SN, 8GB Compactflash, Chenbro E34069 (fanless PSU), DVDRW, 1TB Drive (for now), and 2GB RAM. Comes to 550... which is a lot for what is an upgrade of a machine that does work at the moment. Wish I had something smaller and neater like this to start with!
#310798 - 31/05/2008 22:38 Re: Which mini-ITX board to buy? [Re: mlord]
StigOE
I've seen those and they seem nice. Problem is to get them for a reasonable price here. I found the picoPSU-120W and a 12V 5A brick for ~170 USD (incl VAT) in a Norwegian netshop, but I don't know if the power brick would be big enough. I guess it will. I haven't been able to find any power figures for the mainboard. It would only be the mainboard with a couple of 2.5" drives and possibly a couple of USB devices.
Edit: Checked the status and they were out of stock. Bummer. They did have another kit, rated for 60W, with a brick and a bigger PCB that would need to be mounted inside a case, and this kit was ~80 USD. Looks like it might be a M1-ATX PSU.
Stig
Edited by StigOE (31/05/2008 23:08)
#310808 - 01/06/2008 11:33 Re: Which mini-ITX board to buy? [Re: StigOE]
Mmm.. well, the PicoPSU is normally about $50 by itself, and a suitable +12V brick should be fairly cheap. 60W should be enough: figure 30-35W max for the motherboard with CPU running flat out, and then (overkill) 5W per drive.
So a 60W brick should do the job. www.mini-box.com sells the PicoPSU-120 with a 60W brick together for USD$55 (total!). Or you could save a further $5 by getting the same brick with a lower-rated PicoPSU-90 for $50 from them.
They do ship internationally, though the cost may be excessive since they're US-based, and many places in the US don't seem to offer AirMail as a shipping method. Quite odd, that.
EDIT: Yup, they fall into that category: $118.25 for the overkill of UPS Worldwide Express to Norway.
Or you could have one of us pick it up and bring it along to the 10th Birthday party for you.
Edited by mlord (01/06/2008 11:37)
#310810 - 01/06/2008 11:40 Re: Which mini-ITX board to buy? [Re: mlord]
Perhaps somebody in the US (I'm in Canada) might offer to acquire one, and then just airmail it your way. The PicoPSU by itself will actually fit in a small padded envelope, and could be sent letter mail.
But the brick would require Small Packet Airmail, costing perhaps $20 or so to ship.
#310813 - 01/06/2008 13:09 Re: Which mini-ITX board to buy? [Re: sein]
I'm in a very similar position, I've got a 4U industrial rackmount box humming away in the study which used to do everything. Now it's relegated to MythTV and mail duties, the mail I'm probably going to knock on the head and move to Gmail. It's now got to the point where I don't think I need anything on permanently. Once the Freesat HD DVR comes out I'll probably turn it off. Then I've got think about what I'm going to do with 8 fixed IP addresses!
#310817 - 01/06/2008 15:17 Re: Which mini-ITX board to buy? [Re: mlord]
StigOE
$20 for shipping wouldn't be so bad, $118 would... smile
Seems like it's more common with FedEX, UPS and the like instead of USPS. One time when I bought something on ebay, they would have to drive for an hour to use USPS...
Unfortunately I can't go to the Empeg meet. I made a suggestion for the work schedule for this year, making sure I would be able to attend, but then the office changed it so I've just started at work again when the meet is.
If someone that can accept PayPal paid with creditcard, would be willing to buy the picoPSU-120 and the 60W brick and send it to me, I'd appreciate it.
Stig
#310818 - 01/06/2008 16:31 Re: Which mini-ITX board to buy? [Re: StigOE]
Mmm.. I just checked for Canadian sources, and there are a couple of possibilities:
I can get the PicoPSU-120 + 60W brick for about CDN$55, plus taxes + delivery to me here, for CAD$72.42 total. Small Packet Air to Norway then adds $31.50 to that, for a grand total of about CDN$104.
Seems a shame that shipping (twice) doubles the total for you.
#310819 - 01/06/2008 16:52 Re: Which mini-ITX board to buy? [Re: mlord]
I asked about buying Air Mail stamps once, some time ago. The answer was, they weren't available any more, as the only difference between Air Mail and First Class was that Air Mail was loaded on the plane first.
Currently the USPS has a FedEx like next day shipping. With the same price structures.
#310821 - 01/06/2008 17:35 Re: Which mini-ITX board to buy? [Re: StigOE]
I do have a cautionary tale about fanless though. I have a fanless 500MHz VIA that acts as my off-site backup server and lives in a friend's apartment.
To start with I didn't have a case fan, just the fanless motherboard a single 3.5 inch drive and the power supply. After having three hard drives die within about a 2.5 year period I took a look at hard drive temperatures.
I found the drive was running at well over 50 degrees C. So I now have two case fans mounted and the latest drive has last two years without complaint.
So don't assume just that your board is fanless that your drives will be happy.
I also have one of those T2 boxes, with a head pipe to make the board fanless, but again I have ended up fitting case fans to get the drive temperatures down.
#310822 - 01/06/2008 17:55 Re: Which mini-ITX board to buy? [Re: andy]
I've got a T2 box too, although I never had a drive 'die' I had several occasions where I had to turn it off to allow the drives to cool down.
#310823 - 01/06/2008 18:01 Re: Which mini-ITX board to buy? [Re: andym]
Yeah, I wouldn't really recommend the T2. In fact I've given up on mini-itx altogether since I discovered that a Dell Vostro 200 Slim case machine is actually quieter than my T2, hugely more powerful and can be had for £179 + P&P + tax. My next quiet server will be one of these.
Admittedly it will use more power than a mini-itx, but not much.
Edited by andy (01/06/2008 18:20)
#310824 - 01/06/2008 18:08 Re: Which mini-ITX board to buy? [Re: andy]
The motherboard manual for my VIA board cautioned that proper airflow is a requirement for fanless.
So I have the board in a vertical mount, with lots of case holes above/below the board to allow a chimney effect to circulate fresh air across the heat sinks.
The hard drive is, of course, mounted at the bottom of the case, below all of the heat-generating components. A modern notebook drive only gives off 1-2W of heat, so it will self-cool so long as nothing else interferes.
