#31091 - 14/05/2001 14:31 Better shuffle ctrl in playlist / song properties
Captain_Chaos
Loc: Amersfoort, The Netherlands
I'd like to have better control over the shuffling / non-shuffling of tracks. Specifically:
1. It'd be nice if I could mark single tracks / entire playlists as 'don't play this when shuffle mode is on'. I would use this for audio books that I have on the player, and for intro / interlude tracks (such as the first track on Americana, the Keith B Real tracks on Big Willie Style, etc.). I don't want to hear those tracks when I'm shuffling because they don't have any relation to the surrounding music, but when I'm playing single albums I do want to hear them to recreate the atmosphere of the original album.
2. Somewhat lower on my wish list, but still handy, would be a 'never shuffle this playlist' setting. I would set this on the above mentioned audio books. This way, I would not have to unset shuffle mode when I want to listen to a book (or something else that I would never want to have shuffled) and then set it when I want to return to listening music.
An unrelated wish:
3. When I select a playlist, and the song that is currently playing is contained in that playlist, it would be nice if the player would just continue playing the current song as opposed to selecting a new one from the new playlist.
Are these wishes automatically seen by Empeg, or do I have to send this somewhere else to bring them to their attention?
Regards,
Pepijn Schmitz
#31092 - 14/05/2001 14:49 Re: Better shuffle ctrl in playlist / song properties [Re: Captain_Chaos]
They are automatically seen by Empeg. They do read this BBS and the wish list forum, and they do pay close attention. They don't always respond directly here, but rest assured that they're listening.
Your specific list of wishes, although not specifically addressed in 1.1, will be mostly handled by upcoming features in 1.1. To wit:
Version 1.1 will have a "search by playlist" feature, and it will also let you select the insertion mode of the searches. Instead of just "search" and "append", you'll also get "insert".
So, in 1.1, to do what you want, you simply need to select "insert by playlist", and the playlist you select will be inserted after the current song.
It'd be nice if I could mark single tracks / entire playlists as 'don't play this when shuffle mode is on'. I would use this for audio books that I have on the player. (...) 'never shuffle this playlist'
There is a way around this now, although somewhat inelegant, and 1.1 will have a more interesting way of handling it.
As I understand it, the root of your problem is the separation of books and music.
Right now, you could just create two main playlists off the root. One called "Books" and the other called "Music". When you decide you want to shuffle all your music, it's only one extra click to do it. You could even go the extra step and tag this playlist and all its subfolders as "always randomize".
In 1.1, there will be a feature called "Wendy Filters", allowing you to choose various things to include or not include. You could tag all your audio books with a Wendy flag named "book", and then create two Wendy filters: one that included only books, and one that specifically excluded books. A few clicks would select the desired filter.
In both cases, you would need to turn off shuffle yourself, but that's just one click on the remote control ("0" key).
#31093 - 14/05/2001 15:07 Re: Better shuffle ctrl in playlist / song properties [Re: tfabris]
Captain_Chaos
Yeah I know, I'm already using that method to separate my books and music, but it would be nice if I could just press the big round button three times to play all my music, especially while driving...
Also, it doesn't solve the problem of single tracks that I don't want to play when shuffle is on, but I can see how those 'Wendy filters' would solve both problems. Thanks for the info!
I have two new questions though:
1. Did you just happen to be online, or do you read these forums 24 / 7? :-)
2. Where does the name 'Wendy filter' come from?
Regards,
Pepijn
#31094 - 14/05/2001 15:30 Re: Better shuffle ctrl in playlist / song properties [Re: Captain_Chaos]
I use a little VB program that monitors the BBS. During the day, while I work at my computer, it periodically checks the BBS in the background. When new messages are posted, it blinks a tray icon. That way I can still be productive at work while keeping half an eye on the BBS.
Ex-girlfriend of Hugo's. Do some searches on the BBS...
#31095 - 14/05/2001 17:10 Re: Better shuffle ctrl in playlist / song properties [Re: Captain_Chaos]
muzza
Tony was also used by the millitary in testing sleep respressive drugs. He has now no need of sleep and uses his 'spare' time to monitor this BBS and fight crime in black latex suits.
Thank heavens he uses his power fo good instead of evil. mwaa haa haahaa haaa
Murray 06000047
I don't think, therefore I am not.
#31096 - 14/05/2001 17:50 Re: Better shuffle ctrl in playlist / song properties [Re: muzza]
I think I'm probably more like "invisible boy" in Mystery Men...
#31097 - 15/05/2001 03:03 Re: Better shuffle ctrl in playlist / song properties [Re: Captain_Chaos]
The player has an option for "Ignore as child", which if you set it on your Books playlist would do exactly what you're asking. Sadly, the tickbox for that option in emplode is missing .
This is fixed in 1.1.
From Hugo's then girlfriend Wendy; the feature's first intended use was to pretend, whenever Wendy was in his car, that he didn't have any Carter USM tracks on his player. The feature took so long to implement that Hugo's now not seeing Wendy any more, and I don't believe his current girlfriend has any great objection to Carter USM, but the name has stuck. (Tony, should this be a FAQ? Perhaps when 1.1 is actually released?)
#31098 - 15/05/2001 03:20 Re: Better shuffle ctrl in playlist / song properties [Re: peter]
This is fixed in 1.1..
I happened to have emplode v1.0x open at the time, so it's fixed in v1.0x as well, now.
It'll get released with the next version of the v1.0x branch (which I guess will be v1.03), along with support for the new tuner module.
#31099 - 15/05/2001 04:07 Re: Better shuffle ctrl in playlist / song properties [Re: tfabris]
Geoff
Loc: Northern Ireland
To wit:
To woo... (the mice scatter, looking skywards...)
Geoff
Got one of the first Mark 2 empegs...
Geoff
Mk1 Blue - was 4GB, now 16GB
Mk2 Red - was 12GB, now 60GB
#31100 - 15/05/2001 06:48 Re: Better shuffle ctrl in playlist / song properties [Re: Geoff]
SE_Sport_Driver
So what is the deal with Carter USM? Do they have a bad name in the UK?
32GB (JUST UPGRADED!) Mk. II BLUE
Detroit, MI USA
www.PfeifferBeer.com
#31101 - 15/05/2001 07:00 Re: Better shuffle ctrl in playlist / song properties [Re: SE_Sport_Driver]
No, I just think Wendy didn't like them very much. The only song of theirs I know is "Only Living Boy In New Cross", which I quite like (although it does have the unfortunate side-effect that I can't stop humming it when I walk through New Cross, and I imagine most of the locals have tired of it by now).
#31102 - 15/05/2001 08:47 Re: Better shuffle ctrl in playlist / song properties [Re: peter]
Depending on how the Wendy Filter UI ends up in the final release, there may be an entire page on the Wendy filters alone.
#31103 - 15/05/2001 09:05 Re: Better shuffle ctrl in playlist / song properties [Re: peter]
Wendy really hated jimbob's voice, which is obviously an acquired taste... great band though, pity they are no more... their lyrics were always the right mix of clever, witty, and cutting :)
