#311004 - 05/06/2008 20:08 Renaming doubled file names?
Let's say I've got a user's system with a folder tree full of files that all happen to be named like this:
filename.txt.txt
othername.txt.txt
somename.txt.txt
I want to rename them using the DOS rename command. The following does NOT work:
rename *.txt.txt *.txt
Anyone know the correct way to fix this?
#311005 - 05/06/2008 20:10 Re: Renaming doubled file names? [Re: tfabris]
Never mind, found it:
rename *.txt *.
