#313043 - 17/08/2008 13:53 Resizing NTFS partition?
I need to split my Vista laptop hard disk -- currently a single NTFS partition -- into two NTFS partitions.
What's the most reliable way to do it? Is it worth paying for Partition Magic, or is there something cheaper or even free? Are the open-source partition tools OK with Vista partitions these days?
#313044 - 17/08/2008 15:05 Re: Resizing NTFS partition? [Re: Roger]
Schido
#313045 - 17/08/2008 16:51 Re: Resizing NTFS partition? [Re: Schido]
Originally Posted By: Schido
As long as the controller is recognised by the OS. The SAS/SATA controllers in my Poweredges weren't.
#313046 - 17/08/2008 16:51 Re: Resizing NTFS partition? [Re: andym]
A newer kernel on the Live media should cure that.
#313047 - 17/08/2008 16:54 Re: Resizing NTFS partition? [Re: mlord]
I ended up using a recent xubuntu live cd (which I happened to have lying around), and then installed gparted on that.
#313048 - 17/08/2008 17:55 Re: Resizing NTFS partition? [Re: Roger]
You could just use Disk Management to do it. It's the GUI part of diskpart.exe, the official MS tool to resize NTFS partitions since XP.
#313049 - 17/08/2008 22:23 Re: Resizing NTFS partition? [Re: drakino]
I'm pretty certain that XP diskpart.exe does not support shrinking. It supports extending though. The GUI supports neither. Not relevant here, but though I'd put that out there.
#313057 - 18/08/2008 05:05 Re: Resizing NTFS partition? [Re: drakino]
Didn't work last time I tried (not on this hard disk, though) -- I followed the instructions and it only offered me the option to shrink the partition by 1 or 2 Gb. I want to shrink it by 60Gb or so...
I'll look at gparted. I suspect the problem might be moving stuff out of the way -- does gparted do that?
#313058 - 18/08/2008 06:38 Re: Resizing NTFS partition? [Re: Roger]
I was able to successfully shrink a partition using the *vista* version of Disk Management recently. Perhaps they improved it since XP.
#313059 - 18/08/2008 06:57 Re: Resizing NTFS partition? [Re: tfabris]
This was with the Vista version of Disk Management. I'll try it again today.
#313060 - 18/08/2008 11:17 Re: Resizing NTFS partition? [Re: Roger]
Well, whaddya know? I managed to reclaim about 40Gb. I think the main problem is finding a defragger that'll move stuff out of the way. Fortunately, this is a fairly new build, so Windows hasn't had a chance to put stuff in the way...
#313062 - 18/08/2008 12:35 Re: Resizing NTFS partition? [Re: Roger]
TigerJimmy
Certainly not the Windows defragger... Which one did you use?
#313063 - 18/08/2008 12:54 Re: Resizing NTFS partition? [Re: Roger]
Happy Birthday wfaulk
JkDefrag will do that and is free.
#313064 - 18/08/2008 13:34 Re: Resizing NTFS partition? [Re: TigerJimmy]
Turns out that Windows hadn't had a chance to put stuff in the way, so the Windows defragger was enough. I'll check out JkDefrag, though -- thanks Bitt.
#313065 - 18/08/2008 13:43 Re: Resizing NTFS partition? [Re: Roger]
I've always used Boot It NG to do any resizing/repartitioning.
#313082 - 18/08/2008 23:47 Re: Resizing NTFS partition? [Re: wfaulk]
This is another free defragger that I have had good results with. It is quite fast.
