#313188 - 26/08/2008 13:00 XP taskbar animation
When WinXP opens a new window, the icon/button that gets created in the taskbar does this stupid expansion animation thing. Is there any way to turn that off so that the icon/button just pops into existence? It doesn't seem to be under Control Panel → Display Properties → Appearance → Effects.
The reason I ask is that I have a virtual desktop app that gets bogged down on this slow computer I'm using when Windows redraws the icons/buttons that it adds and removes on desktop switching.
#313190 - 26/08/2008 13:16 Re: XP taskbar animation [Re: wfaulk]
I don't have an XP box handy (I'm on 2003), but does TweakUI have a setting for this?
#313191 - 26/08/2008 13:30 Re: XP taskbar animation [Re: Roger]
Good idea; I hadn't thought to look there. But there's nothing I can find.
#313193 - 26/08/2008 13:52 Re: XP taskbar animation [Re: wfaulk]
I don't notice any animation for the taskbar on my XP machine.
I wonder if I shut it off somehow...
#313199 - 26/08/2008 14:47 Re: XP taskbar animation [Re: Robotic]
It's probably pretty quick on a computer that's not as overloaded as mine. Basically, the button/icon pops up about as wide as the actual icon on the left side of it. Then it expands toward the right until it gets to its full size.
#313203 - 26/08/2008 17:00 Re: XP taskbar animation [Re: wfaulk]
Get a faster computer :P
If you're running a virtual desktop app and its this slow already just doing redraw then you should get something else.
#313206 - 26/08/2008 17:10 Re: XP taskbar animation [Re: tman]
Feel free to email my manager.
#313210 - 26/08/2008 18:34 Re: XP taskbar animation [Re: wfaulk]
Would more RAM fix it? Could you just buy some and send him the bill?
That's what I do. wink
#313218 - 26/08/2008 22:28 Re: XP taskbar animation [Re: wfaulk]
lectric
Loc: New Orleans, LA
I just use classic mode. Turns all that crap off, and I know where everything is to boot!
#313219 - 26/08/2008 23:09 Re: XP taskbar animation [Re: lectric]
If you're using classic mode anyway then you should disable the theme service to save a bit of memory/CPU.
#313223 - 27/08/2008 01:54 Re: XP taskbar animation [Re: tman]
my computer>properties>advanced tab>performance settings
Then uncheck "slide taskbar buttons".
And whatever else strikes your fancy. The more unchecked the faster the UI gets.
#313229 - 27/08/2008 05:57 Re: XP taskbar animation [Re: lectric]
This is in classic mode.
#313230 - 27/08/2008 06:02 Re: XP taskbar animation [Re: gbeer]
Aha!
Virtual beers all around.
#313236 - 27/08/2008 14:26 Re: XP taskbar animation [Re: gbeer]
Excellent find!
Mine was already configured for 'maximum performance' and so none of the boxes were checked.
Very sad that TweakUI doesn't access these settings.
