#317228 - 10/12/2008 20:30 File uppercase renamer utility/script
I'm looking for a quick way to rename a bunch of files and folders all to uppercase. Methods acceptable are DOS command line utilities, or something that will run from Cygwin. Ideally, scriptable, and will recurse subdirectories automatically. So far, the method I am using is really slow for the ~7500 files I need to do this to.
for i in `find * -depth`; do (mv $i `echo $i | sed 's%[^/][^/]*$%%'``echo $i | sed 's!.*/!!' | tr [:lower:] [:upper:]`); done
That is currently taking I think around 45 minutes to an hour to do what I need.
Thanks in advance
#317229 - 10/12/2008 20:44 Re: File uppercase renamer utility/script [Re: drakino]
Can't help you with the script right now, but I'm deeply curious and fascinated as to why this would be a necessary task. I'm sure the story is hilarious.
#317230 - 10/12/2008 21:27 Re: File uppercase renamer utility/script [Re: drakino]
This is the script I use. Feed it a list of pathnames (files or directories) as args.
#!/bin/bash
# Convert names from current or specified directory(s) to all uppercase:
ls -1 "$@" | awk -v Q="'" '
        if (toupper($0) != $0) {
                system("/bin/mv " Q $0 Q" "Q toupper($0) Q);
To convert an entire directory tree, use it like this:
## Assumes above script is saved as "uppercase" somewhere in $PATH
cd bigdirtree
find . -type d | xargs uppercase
Edited by mlord (10/12/2008 21:30)
#317231 - 10/12/2008 21:31 Re: File uppercase renamer utility/script [Re: drakino]
oliver
Something like this has come up in the past, the request was to turn everything into first letter uppercase for mp3 files.
I was bored, and wrote a simple .net module, looks like you've have to change line 41 to VbStrConv.Uppercase, recompile, and it should work.
#317233 - 10/12/2008 21:45 Re: File uppercase renamer utility/script [Re: mlord]
Happy Birthday wfaulk
That's likely to be just as slow as Tom's current solution, which is probably slow because of the spawning of 7500 instances of "mv". Yours might actually be slower, because awk's system() probably ends up executing via "sh -c".
#317234 - 10/12/2008 22:08 Re: File uppercase renamer utility/script [Re: drakino]
This should be fairly fast:
find . -type f | upper.pl
Where upper.pl is:
#!/usr/bin/perl
while (<>) {
        chomp();
        my $oldname = $_;
        my $newname = $oldname;
        $newname =~ s#^(.+)/([^/]+)$#$1/\U$2\E#;
        rename($oldname, $newname) if ($oldname ne $newname);
If you also want to change directories, run it again with:
find . -depth -type d | upper.pl
You could potentially do it in one step, but it would take me longer to write. Edit: Actually, I think you can do it all in one step with just "find . -depth | upper.pl".
Edge cases that fail include having filenames and pathnames with spaces in them, and providing filenames without any slashes in them. Thus, make sure to do "find ." and not "find *".
Also, I'd definitely test this out in a sandbox somewhere. I've done about 3 minutes of testing, if that.
Edited by wfaulk (10/12/2008 22:15)
#317235 - 10/12/2008 22:12 Re: File uppercase renamer utility/script [Re: drakino]
This is totally off the wall, but I believe that MP3 Tag Studio would do what you want.
In "Browse/edit tags", choose the "Show all filetypes" box.
In "Direct rename files",
(1) choose advanced mode,
(2) and in General settings choose "Case fix and replace".
(3) Set "Expected file name format" to "<Title>",
(4) and "Output file name format" to "<Title>"
(5) in "Setup", set "Capitalization mode" to "Full uppercase".
(6) Check the "Include subdirs" box
Go as far up the directory tree as you need to go (Root?) and click Execute.
OK, I just tested this on a temporary directory, 19 folders and subfolders, 525 files, about 3.5 GB. It worked, it took 0.8 seconds to run. That's the good news. The bad news is that it only changes the filenames, and not the directory names. But maybe you can modify your script to do just the directories after the filenames are changed?
#317238 - 10/12/2008 23:31 Re: File uppercase renamer utility/script [Re: drakino]
Mojo
Unregistered
This took 46.5 seconds on 1140 files. Estimated time to rename 7500 files would be ~5 minutes. This is on a 2.16 Ghz Intel Core2Duo.
proc rename {file} {
	if { [file isdirectory $file] } {
		foreach nextFile [glob -nocomplain "$file/*"] {
			rename $nextFile
	file rename -force -- $file this_is_a_hack
	file rename -force -- this_is_a_hack "[file dirname $file]/[string toupper [file tail $file]]"
	return
On Windows, download ActiveState Tcl if you don't already have it and paste the rename procedure in tclsh.exe. Then do:
rename name_of_parent_folder
The "this_is_a_hack" portion of the code is because of a silly bug in Tcl that doesn't let you rename a file to itself with different capitalization on Windows. It makes it take twice as long, but it still beats 45 minutes.
