Page 2 of 3 < 1 2 3 >
#317629 - 29/12/2008 16:40 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
Loc: Isle of Wight, UK
OK, W set to zero and uploaded tracks with no errors. I guess that means that your modified hijack is what fixed the problem.
Just out of interest, will enabling/disabling write-caching have any performance benefits/detriments in this environment?
Do you have any idea why I was unable to use /dev/hdb to specify the slave SSD with hdparm?
Steve
#317634 - 30/12/2008 02:23 Re: SSD upgrade woes... [Re: Major_Sarcasm]
fixed the problem.
Great. I'll make it an "official" release shortly.
I think I'd suggest disabling it, as our kernel doesn't know
anything about safely flushing the write cache, and
(contrary to common opinion) the empeg s/w *does*
write to the media (dynamic data partition)
during normal playback operation.
So just leave write-caching
off for safety with these slow-writing SSDs.
For regular hard disks, no issues either way.
No. But that *has to work* if you want a two-drive system.
I'm probably just missing something obvious..
Edited by mlord (30/12/2008 02:25)
#317635 - 30/12/2008 02:40 Re: SSD upgrade woes... [Re: mlord]
Or maybe not. Sourceforge seems to have finally broken my scripts,
and removed the ability to easily upload binary files.
I refuse to use their absolutely STUPID "file release manager"
crap for Hijack, so this might be the end of Hijack availability
at Sourceforge
Hmmph.
EDIT: hacked it, working again. For now.
Edited by mlord (30/12/2008 11:44)
#317638 - 30/12/2008 03:28 Re: SSD upgrade woes... [Re: mlord]
I've also updated the bigdisk builder stuff on my server,
to include Hijack v504 in the images. Untested, of course. smile
#317642 - 30/12/2008 11:29 Re: SSD upgrade woes... [Re: mlord]
Major_Sarcasm
I added the second drive back in late last night and uploaded ~27GB of files with no problems whatsoever. I had a look in the fids folders on each drive and it seems to be balancing the files between the two.
Mark, as ever, I am most grateful for your assistance.
Steve
#317648 - 30/12/2008 16:34 Re: SSD upgrade woes... [Re: mlord]
Mark, you are awesome.
#318440 - 25/01/2009 04:57 Re: SSD upgrade woes... [Re: tfabris]
101
Loc: US
I am using v504 disk builder image with a single 64 GB SSD of the same brand and getting a ton of these virtual memory errors:
VM: do_try_to_free_pages failed for mkfs.ext2...
show_message("1530.-1 nomem err")
This is on an old 12MB player, any ideas why?
#080000512 green 12GB
#318441 - 25/01/2009 12:15 Re: SSD upgrade woes... [Re: 101]
Which exact builder file are you using (name and bytecount, please)?
Can you capture a trace from the serial port while running it (helps a LOT)?
Thanks.
#318442 - 25/01/2009 13:55 Re: SSD upgrade woes... [Re: mlord]
101
Loc: US
builder_bigdisk_v3.upgrade
2.16 MB (2,267,745 bytes)
MD5 0b8b1f793a7e2a7e8253fad6a35afc41
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v504 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Mon Dec 29 23:29:04 EST 2008
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 7, serial number 80000512) 12MB DRAM
Command line: mem=12m
Memory: 10944k/12M available (996k code, 20k reserved, 324k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
show_message("Hijack v504 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005000).
empeg RDS driver initialised
empeg power-pic driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xffaa
ide_data_test: wrote 0x5555 read 0xff55
hda: TS64GSSD25-M, ATA DISK drive
hda: TS64GSSD25-M, 61136MB w/0kB Cache, CHS=7793/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:02:0
0
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init+ /bin/mount -n /proc
+ log 'Builder image'
+ echo 'Builder image'
Builder image
+ echo 'POPUP show_message("Builder image")
9999 Builder image'
+ DRIVE1=
+ '[' -e /proc/ide/hdb -a -e /proc/ide/hdc ']'
+ '[' -e /proc/ide/hdb ']'
+ '[' -e /proc/ide/hdc ']'
+ /bin/mount -n -t ext2 -o ro,nocheck /dev/hda4 /drive0
+ '[' -d /drive0/fids ']'
+ /bin/umount /drive0
+ /bin/mkswap /dev/hda6
Setting up swapspace version 0, size = 16412672 bytes
+ /bin/swapon /dev/hda6
Adding Swap: 16028k swap-space (priority -1)
+ /bin/mkswap /dev/hda3
Setting up swapspace version 0, size = 24670208 bytes
+ /bin/swapon /dev/hda3
Adding Swap: 24092k swap-space (priority -2)
+ log 'Tuning hda5'
+ echo 'Tuning hda5'
Tuning hda5show_message("Tuning hda5")
+ echo 'POPUP 9999 Tuning hda5'
+ /bin/tune2fs -c -1 -i0 /dev/hda5
tune2fs 1.17, 26-Oct-1999 for EXT2 FS 0.5b, 95/08/09
Setting maximal mount count to -1
Setting interval between check 0 seconds
+ makedrive hda4 /drive0
+ dev=/dev/hda4
+ log 'Making hda4 filesystem'
+ echo 'Makishow_message("Making hda4 filesystem")
ng hda4 filesystem'
+ echo 'POPUP 9999 Making hda4 filesystem'
+ /bin/mkfs.ext2 -v -s 1 -i 131072 -m 0 /dev/hda4
mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
Linux ext2 filesystem format
Filesystem label=
488256 inodes, 62492850 blocks
0 blocks (0.00%) reserved for the super user
First data block=1
Block size=1024 (log=0)
Fragment size=1024 (log=0)
7629 block groups
8192 blocks per group, 8192 fragments per group
64 inodes per group
Superblock backups stored on blocks:
        8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409, 663553,
        1024001, 1990657, 2809857, 5120001, 5971969, 17915905, 19668993,
        25600001, 53747713,
Writing inode tables: done
Writing superblocks and filesystem accounting information: show_message("1530.-1
 nomem err")
#318443 - 25/01/2009 16:09 Re: SSD upgrade woes... [Re: 101]
Mmm.. looks like you are doing everything The Right Way(tm).
So, the mkfs thinks it is running out of memory,
which is very odd given the amount of swap space
we allocate for its use.
If I can find my 32GB CF card, I'll give this a try
on that later today in a Mk2 12MB unit. And then perhaps
again with a larger hard disk.
Edited by mlord (25/01/2009 16:17)
#318444 - 25/01/2009 16:18 Re: SSD upgrade woes... [Re: mlord]
If you grok Linux, you could just finish off the process by hand.
A reboot (from its present state) will give you a shell prompt
at the serial console, where you could re-issue the mkfs.ext2
command from the script by hand.
Edited by mlord (25/01/2009 16:19)
#318446 - 25/01/2009 22:32 Re: SSD upgrade woes... [Re: mlord]
101
Loc: US
I know enough to fumble around, but I couldn't figure out how to get a prompt on the builder image as every reboot attempts to reformat the drive. Seems like it would be pretty easy to work around if I could get to a prompt. Is that mkfs cmd the end of the script?
Thank you so much for such a ridiculously fast response btw, and I really appreciate the help.
#318447 - 25/01/2009 22:48 Re: SSD upgrade woes... [Re: 101]
Here's a builder version that logs you in, and tells you what to do.
Have fun. smile
Edited by mlord (25/01/2009 22:49)
#318448 - 26/01/2009 01:09 Re: SSD upgrade woes... [Re: mlord]
101
Loc: US
Thanks for that new image. However, when I manually run the first cmd (mkfs.ext2) I get the same nomem error.
#318449 - 26/01/2009 01:30 Re: SSD upgrade woes... [Re: 101]
Mmm.. bummer, but not completely unexpected.
I'm not sure why it fails to use the swap space for memory, but.. oh well.
Can you connect the drive to a Linux box (internally,
or externally via USB or whatever)
and just do the same commands to it from there?
That's the workaround at this point.
Edited by mlord (26/01/2009 01:31)
#318450 - 26/01/2009 01:41 Re: SSD upgrade woes... [Re: mlord]
I've scrounged up a Mk2 and a 60GB (hard) drive here now,
and we will see what happens with it.. gimme a few minutes..
Edited by mlord (26/01/2009 01:42)
#318451 - 26/01/2009 02:01 Re: SSD upgrade woes... [Re: mlord]
Mmm.. no problems here. But regardless, this might help:
builder_bigdisk_v3_alt.upgrade
This one has tweaked mkfs options to (hopefully) reduce the amount of RAM required.
Give it a whirl..
#318455 - 26/01/2009 12:12 Re: SSD upgrade woes... [Re: mlord]
101
Loc: US
The alt one you posted (link is a little squirrely)seems to have made it through the script. There was one error "zeroing hda3":
/bin/cat: write error: No space left on device
Not sure if that was normal or not, just sounds like it wrote to the end.
Do you think the problem is related to the empeg-flash driver? Seems like something is being loaded that is bigger than normal and causing an issue with this SSD on a 12MB player.
#318460 - 26/01/2009 13:32 Re: SSD upgrade woes... [Re: 101]
It doesn't mean flash as in SSD. There is a small amount of flash memory inside the empeg that stores some current state and config data.
#318461 - 26/01/2009 14:11 Re: SSD upgrade woes... [Re: 101]
Yes, that's normal. Ignore it.
No. Linux on the empeg doesn't even know you have an SSD.
It thinks of it and treats it exactly as a regular hard drive.
So, the _alt_ builder worked though, and you should now be all set.
#318466 - 26/01/2009 19:15 Re: SSD upgrade woes... [Re: mlord]
I've now updated the bigdisk builder images (at rtr.ca)
with Hijack v508. There's also now a new _v4_ builder
which uses a 4KB blocksize (rather than 1KB),
and a 4X higher bytes:inodes ratio.
These changes make it much more suitable for large disks
and/or low-memory usage.
Edited by mlord (26/01/2009 19:16)
#318474 - 26/01/2009 22:57 Re: SSD upgrade woes... [Re: mlord]
101
Loc: US
Thanks again so much for the help Mark, all seems to be working.
Only issues I have now are config related. I've been using the old 2.0 beta for like 7 years and I need to figure out how to get the fader back and now the player no longer shuts off in the car. So I'll need to do some searches to get up to speed on restoring that functionality, and what else is new.
SSD issues seem to be resolved.
#318526 - 27/01/2009 23:44 Re: SSD upgrade woes... [Re: 101]
101
Loc: US
Okay, I am completely baffled. I've done some searches and apparently I have "home mode in the car" syndrome and saw all these threads about a blown diode and HW replacement etc.
I will say that being a HW guy (encoder replacement was much more straight forward to me than swapping in an SSD) this is ridiculous. I put in my old drive with the old firmware and all functionality returned with 0 issues. Clearly this is a software problem, yet there's many threads on diode replacement and I couldn't find anything pointing to software.
What is the deal here? I have been out of the loop for years and just want to replace my dying mechanical HD with an SSD.
Can I just image my old drive to the SSD? At this point I could care less about losing a few gig to an LBA issue. I just want it to work with no hassle, as I don't have as much time to spend on this as I would like.
Suggestions? Please?
#318544 - 28/01/2009 13:05 Re: SSD upgrade woes... [Re: 101]
What is shown on the Hijack Menu's "Force AC/DC Power Mode"
screen on your player?
Post the four lines here, please.
#362525 - 10/09/2014 19:18 Re: SSD upgrade woes... [Re: Major_Sarcasm]
haffi
Loc: Iceland
Hi all I know this is an old thread but I am having similar problems...
I inserted a SSD 120GB Kingston SSD now into the Empeg with Adapter and It is getting the HDA timeout issues on the Display.
Can someone help me with this ? Is there a way to telnet into the empeg ? my Serial port does way to much of Crashing my computer ( since its a usb adapter ).
I used the Big disk Image first and then the hijack 5.18.
I am able to upload some tracks but it crashes the player all the time.
I have tried swapping out the SSD and the Adapter , plus the HDD cable with the same results.
Hafþór Hilmarsson
CCIE VOICE #24527
Iceland.
#362526 - 10/09/2014 21:18 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Yeah, my apologies for putting this on the back burner. Hijack has a telnetd built-in, which can be enabled by putting "ktelnetd_port=23" into the "[hijack]" section of the player's config.ini file.
For the adapter, I don't yet know what's wrong, and haven't made the time to investigate yet. But I have seem similar behaviour with some adapters in the past, and might still have one on hand that misbehaves like that. So.. there's hope.
With luck, it's just a timing thing: SSDs respond _instantly_ to stuff that takes milliseconds with mechanical drives, and something may just not be ready for that as soon as it ought to be.
#363920 - 02/05/2015 15:37 Re: SSD upgrade woes... [Re: Major_Sarcasm]
haffi
Loc: Iceland
Any new Mlord ? my player works ok... but if I try to fast forward and randomly it freezez up , and I think your right with the timing issues.
Where can I start.
If I telnet to the empeg and try fsck -fay /dev/hda4 it just says
empeg:/# fsck -fay /dev/hda4
fsck -fay /dev/hda4
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Error allocating block bitmap (1): Memory allocation failed
Parallelizing fsck version 1.19 (13-Jul-2000)
my
empeg:/# hdparm -I /dev/hda
hdparm -I /dev/hda
/dev/hda:
ATA device, with non-removable media
Model Number: KINGSTON SVP200S3120G
Serial Number: 50026B72270195F5
Firmware Revision: 501ABBF0
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5
Standards:
Used: unknown (minor revision code 0x0110)
Supported: 8 7 6 5
Likely used: 8
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 234441648
LBA48 user addressable sectors: 234441648
device size with M = 1024*1024: 114473 MBytes
device size with M = 1000*1000: 120034 MBytes (120 GB)
Capabilities:
LBA, IORDY(can be disabled)
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Advanced power management level: 254
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5 udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
Security Mode feature set
* Power Management feature set
* Write cache
Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
Power-Up In Standby feature set
* SET_FEATURES required to spinup after power up
* 48-bit Address feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* WRITE_{DMA|MULTIPLE}_FUA_EXT
* 64-bit World wide name
* IDLE_IMMEDIATE with UNLOAD
Write-Read-Verify feature set
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* SATA-I signaling speed (1.5Gb/s)
* SATA-II signaling speed (3.0Gb/s)
* SMART Command Transport (SCT) feature set
Security:
Master password revision code = 65534
supported
not enabled
not locked
not frozen
not expired: security count
not supported: enhanced erase
2min for SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 50026b72270195f5
NAA : 5
IEEE OUI : 26b7
Unique ID : 2270195f5
Integrity word not set (found 0x0000, expected 0x6ea5)
Hafþór Hilmarsson
CCIE VOICE #24527
Iceland.
#363921 - 03/05/2015 07:11 Re: SSD upgrade woes... [Re: Major_Sarcasm]
haffi
Loc: Iceland
Player displays this and then the empeg is non responsive
0000.0 hda: err: stat_timo
Hafþór Hilmarsson
CCIE VOICE #24527
Iceland.
#363922 - 03/05/2015 13:25 Re: SSD upgrade woes... [Re: Major_Sarcasm]
When that message appears on the display, there will be a corresponding, more detailed message at the serial port.
Something like: hda: stat_timo: status=0x80
followed by another line describing what it was trying to do at the time.
Any chance you could capture those messages and post them here?
Based on the value it prints for "status=0x..", it might be possible to work around the issue.
In particular, if it says "status=0x88", and "no DRQ after issuing WRITE", then it's a very easy fix.
Thanks.
Edited by mlord (03/05/2015 13:33)
#363923 - 03/05/2015 13:41 Re: SSD upgrade woes... [Re: haffi]
fsck -fay /dev/hda4
To work around that problem with fsck, just do "swapon -a" before starting the fsck command.
Edited by mlord (03/05/2015 13:42)
