Page 3 of 3 < 1 2 3
#325635 - 31/08/2009 14:41 Re: $79 for 1TB Seagate drives at Amazon [Re: andym]
Originally Posted By: andym
I did wonder, I have Samsung EcoGreens in my ReadyNAS and looking at the SMART data and it only shows 7 power cycles and over 3000 operating hours which makes me think they've been spinning pretty much constantly since I bought them.
Power cycles aren't the spin up/down cycles though.
#325636 - 31/08/2009 15:19 Re: $79 for 1TB Seagate drives at Amazon [Re: tman]
smartctl shows a Start_Stop_Count of 7 which is identical to the Power_Cycle_Count.
#325650 - 31/08/2009 21:47 Re: $79 for 1TB Seagate drives at Amazon [Re: peter]
Do they spin down even if the host isn't telling it to do so?
Apparently they did in early firmware versions. I've just checked mine, though, and it's had 270 spin-up cycles in 2500 power-on hours, which sounds about right (two or three a day) for the ones initiated by the OS ("hdparm -S 242 /dev/sda").
Check the head load/unload counts in the output from smartctl -a
EDIT: mmm.. that's probably the same as the "Start_Stop_Count", which Andy has already checked. Dunno for sure, though, as I won't allow any of those drives into our gear here. smile
"Load_Cycle_Count" is the one to look at.
Edited by mlord (31/08/2009 21:55)
#325653 - 31/08/2009 23:35 Re: $79 for 1TB Seagate drives at Amazon [Re: mlord]
On my eight WD10EADS-00L5B1 drives, the Start_Stop_Count and Load_Cycle_Count (raw) values are the same on the same drive, either 58 or 59. And they've been up and running for a little over two months.
#325669 - 01/09/2009 14:23 Re: $79 for 1TB Seagate drives at Amazon [Re: mlord]
Srsly. Load_Cycle_Count and Start_Stop_Count are both about 270, much less than Power_On_Hours at about 2500, and much more than Power_Cycle_Count at 17.
#325680 - 01/09/2009 20:55 Re: $79 for 1TB Seagate drives at Amazon [Re: peter]
Okay, so that's an indication that they may have fixed the issue with newer firmware, as you suggested.
Good!
Either that, or they're just not reporting it any more in the S.M.A.R.T. data.
#325683 - 01/09/2009 21:13 Re: $79 for 1TB Seagate drives at Amazon [Re: peter]
g_attrill
Loc: Hants, UK
I have a WD10EADS and it shows power on hours 1380, power cycle 172 and start/stop and load cycle are both 174.
#327107 - 27/10/2009 17:38 Re: $79 for 1TB Seagate drives at Amazon [Re: mlord]
The events that trigger the counter to be incremented sound like they are slow events .. like daily or something. But after a while, it becomes a bit of a crap shoot as to whether your next reboot/shutdown coincides with the bad counter value.
Coworker just had an ST3750330NS go brick on him. Suddenly. Right after a reboot.
Anyone know if that drive is one of the affected ones?
#327108 - 27/10/2009 17:42 Re: $79 for 1TB Seagate drives at Amazon [Re: tfabris]
robricc
Newegg reviews don't look so hot.
#327109 - 27/10/2009 17:46 Re: $79 for 1TB Seagate drives at Amazon [Re: tfabris]
... And if his is one of the models with the firmware bug, is there a chance he can recover once it's bricked?
#327112 - 27/10/2009 18:10 Re: $79 for 1TB Seagate drives at Amazon [Re: tfabris]
You have to send it to Seagate for them to do their magic on it but it should come back with full access to data. I assume they have some sort of secret manufacturer programming interface which allows them to reset the log.
#327113 - 27/10/2009 18:14 Re: $79 for 1TB Seagate drives at Amazon [Re: tfabris]
Yes
#327115 - 27/10/2009 19:20 Re: $79 for 1TB Seagate drives at Amazon [Re: tman]
Thanks. frown
#327117 - 27/10/2009 20:38 Re: $79 for 1TB Seagate drives at Amazon [Re: tfabris]
Wow, Seagate have been the Sony of hard drives this past year. Damn. I pretty much exclusively buy Seagate, so I'm knocking some wood right now.
I applied updated firmware to my 1.5TB drives as soon as I got them, which was a little while after Seagate finally released their fix. At the time I had to live-chat to get the firmware files as they weren't available for free download.
#327127 - 28/10/2009 01:57 Re: $79 for 1TB Seagate drives at Amazon [Re: hybrid8]
The HD has buggy badly written spyware that doesn't even work properly which is installed without your approval and it leaves a backdoor open the size of an oil tanker when you try to uninstall it?
#327128 - 28/10/2009 02:16 Re: $79 for 1TB Seagate drives at Amazon [Re: tman]
The HD has buggy badly written spyware ... ?
I was referring to the Sony battery fiasco which was a much bigger deal than their root kit issue. Week after week and month after month we kept hearing about a new batch of batteries. So too with Seagate's drives. FIrst 1.5TB, then 1TB, now ES models at 750GB.
#327129 - 28/10/2009 02:21 Re: $79 for 1TB Seagate drives at Amazon [Re: tman]
Since the rootkit fiasco, Sony has not received a dime of my money, and it is unlikely that they ever will again.
#327140 - 28/10/2009 11:57 Re: $79 for 1TB Seagate drives at Amazon [Re: tanstaafl.]
robricc
I've crossed LG off the list.
BlueBirds
Reviews
#327159 - 28/10/2009 18:01 Re: $79 for 1TB Seagate drives at Amazon [Re: robricc]
Re: Sony (new today)... See what I mean?
#327164 - 28/10/2009 18:52 Re: $79 for 1TB Seagate drives at Amazon [Re: hybrid8]
Of course, bad power adaptors aren't just a Sony problem.
#327165 - 28/10/2009 18:55 Re: $79 for 1TB Seagate drives at Amazon [Re: hybrid8]
No. Not really. If it was only Sony that ever recalled a faulty part that was manufactured by somebody else then yes there would be a point to you mentioning that.
I've got a bunch of replacement Dell laptop PSUs because the originals had a similar problem to these VAIO ones. My original Xbox has a special replacement mains lead that has a RCD built into it because the socket is flakey. There are a multitude of recalls for car parts which are even more dangerous because there is a serious chance of injury or death.
Whilst it is bad that they sold these potentially dangerous PSUs, it isn't specific to Sony. They're not even made by Sony. They asked one of the big PSU manufacturers that they'd like a PSU that outputs this voltage at this current and they'd like their logo stamped on the outside. I wouldn't be surprised if Apple used the same manufacturers.
#327193 - 29/10/2009 14:30 Re: $79 for 1TB Seagate drives at Amazon [Re: robricc]
Which naturally leads to the next question -- what's a decent 1TB or larger drive that isn't going to go south mysteriously?
#327196 - 29/10/2009 15:27 Re: $79 for 1TB Seagate drives at Amazon [Re: canuckInOR]
If you scroll backward in this very thread, you'll see Mark Lord advocating and me buying Western Digital Caviar Black 1TB hard drives. They were also standard equipment on my recent Mac Pro.
#327198 - 29/10/2009 16:34 Re: $79 for 1TB Seagate drives at Amazon [Re: DWallach]
I also bought a pair of the WD Caviar Black drives and have been completely satisfied. Of course, they've only been on-line for a couple of months, and one of them is only powered up for a few hours every few days or so for backups.
BTW, be wary of buying this drive from Amazon. Many of the reviews state that the drive was extremely inadequately packaged, rattling around loose in an over-sized box and arriving DOA. By contrast, Newegg shipped my drives wrapped in bubble wrap in a properly sized box filled with styrofoam packing peanuts. You'll pay about $15 more at Newegg, but it is money well spent.
#327203 - 30/10/2009 03:09 Re: $79 for 1TB Seagate drives at Amazon [Re: tanstaafl.]
Ross Wellington
Hi,
I have used 8 of the WD 1TB drives (4 each for system storage, 4 for disk to disk back-ups every 2 weeks) in my i7 SPICE simulation system.
They seem to work fine for me.
Heeded Mark's warning NOT to buy Seagate drives.
#327265 - 02/11/2009 00:59 Re: $79 for 1TB Seagate drives at Amazon [Re: DWallach]
Cool... wasn't sure if there was any more recent recommendations, or if the newer Seagates were okay.
#327276 - 02/11/2009 12:38 Re: $79 for 1TB Seagate drives at Amazon [Re: canuckInOR]
They don't seem to be. Even Patrick is having issues with a Seagate drive here now, and their firmware-of-death saga is less than a year old yet. Avoid.
Page 3 of 3 < 1 2 3
