#322743 - 28/05/2009 19:28 Backup empeg contents to PC
Dava
Loc: Bucks UK
Hi all,
Its good to see the BBS is still going strong, I have been away for some time....
I have been looking for a way to backup the entire contents of the empeg back to PC where:
1.The playlists are maintined and the MP3s created in them. ( think emplode/jemplode do this to some extent)
2.Modify the tags on the PC to those of my anal empeg DB (I wasn't so carful before uploading in some cases but fixed in emplode later)
Excuse me if this has been asked 100 times but I could not find a suitable thread here.
Rather than just having an empeg/linux backup lying around on one of my Windows PCs, It would make sense to make it playable and I have 10 years worth of random additions now.
Any pointers would be appreciated.
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
#322744 - 28/05/2009 19:43 Re: Backup empeg contents to PC [Re: Dava]
Jemplode does all of that nicely, with a tiny bit of configuration.
#322749 - 28/05/2009 20:55 Re: Backup empeg contents to PC [Re: Dava]
Jemplode will do the second thing, which is to write ID3v2 tags back into the files as you download them off of the player.
As far as the first thing, playlists, that's a different animal. If you download things via Jemplode you can have it create a folder structure that matches your playlist structure. Which might be fine for some people.
A case where it wouldn't be fine is if you have the same song (or album) in multiple playlists. Then, if you download each playlist off of jemplode, you might download the song more than once.
Relevant FAQ entries are here:
Can I copy MP3 files back onto my PC from the player?
Is there anything I should keep in mind when I grab files from the player?
Can I back up the player's playlists and music files?
What is the best way to organize and listen to my music?
How can I keep my PC and my car player in perfect synch?
#322797 - 29/05/2009 15:59 Re: Backup empeg contents to PC [Re: tfabris]
Dava
Loc: Bucks UK
Thanks both,
With drive space so cheap I am not worried too much about dupes. My 60GB of tunes barely touches the sides of a recent desktop drive. How things change in 10 years...
#322800 - 29/05/2009 17:36 Re: Backup empeg contents to PC [Re: Dava]
Okay, then you just go into Jemplode, Tools/options, and you set up the downloaded file name format to include the playlist name as a folder name with backslashes.
I forget the exact syntax to do that in the Jemplode configuration box, does remember where that's documented or have a link to where Mike described that on the BBS?
#322803 - 29/05/2009 19:00 Re: Backup empeg contents to PC [Re: tfabris]
Here's the ~/.openrio/jempegrc config file from my system here:
#jEmplode Properties
#Sat Nov 08 15:17:24 EST 2008
jempeg.promptsBeforeUpdate=true
jempeg.connections.inetAddress=10.0.0.13
jempeg.autoUpdateHijack=false
jempeg.soup.num=5
updateTagsOnDuplicates=false
rebuildFromMemory=false
jempeg.removeID3v1=true
jempeg.writeID3v2=true
jempeg.connections.specificAddress=true
jempeg.soup.1.externalForm=tag,title\:source
jempeg.allowUnknownTypes=false
sortPlaylistsFirst=false
jempeg.lookAndFeel=system
jempeg.playlist.sort.tag=title
jempeg.jEmplode.promptsBeforeUpdate=true
jempeg.filenameFormat.tune={artist}-{source}-{title}{ext}
jempeg.preserveID3v2=true
jempeg.soup.0.name=Artists
jempeg.connections.serialPort=false
jempeg.connections.doNotBroadcastTo=
jempeg.soup.2.name=Genres
jempeg.soup.4.externalForm=search,title\:(type \= "tune")
jempeg.soup.4.name=All
jempeg.downloadFullPath=false
jempeg.soup.0.externalForm=tag,title\:artist
deduplication=true
jempeg.recursiveColors=true
jempeg.soupFilenameFormat.tune={artist}-{source}-{title}{ext}
jempeg.connections.USB=false
jempeg.connections.ethernetBroadcast=false
jempeg.hijackSaveLocation=
jempeg.playlist.sort.direction=true
jempeg.downloadDir=
jempeg.soup.3.externalForm=tag,title\:year
jempeg.jEmplode.autoUpdateHijack=false
jempeg.recursiveSoupColors=false
jempeg.useFastConnection=true
jempeg.onlyShowFailedImports=true
importM3U=true
jempeg.hijackMkVersion=mk2
jempeg.hijackLogin=empeg
stripArticlesWhenComparing=true
jempeg.hijackURL=http\://empeg-hijack.sourceforge.net
jempeg.disableSoupUpdating=false
jempeg.soup.1.name=Albums
jempeg.connections.autoSelect=false
jempeg.currentDownloadDirectory=/root
jempeg.soup.3.name=Years
jempeg.useHijack=false
jempeg.soup.2.externalForm=tag,title\:genre
jempeg.hijackPassword=empeg
tonySelections=false
And here (attached) is the jemplode_tags.pdf documentation file I have for it all.
jemplode_tags.pdf (446 downloads)
Description: jemplode_tags.pdf
