#322872 - 01/06/2009 14:15 play list corrupt
SpeedBump
I am trying to fix my old empeg (have not used it in 3-5 year) (used a different car well i should say Harley anyway)
i had a hard drive problem, i have taken care of that, i have copied all of the music from the dieing hard drives over to a new 160 gig drive, i am running v3.00-alpha11, and v508.hijack.mk2.
i have expanded the drives and such with builder_bigdisk_v4
i have also used jemplode to copy all of the music off of the empeg just in case (that took about 2 days)
anyway whenever i try and synchronize i get 0000.0 sigkill err.
the number changes sometimes when using jemplode.
i get a diffrent error when i try and synchronize with empeg.
the empeg likes to "building music databases" a lot, upon searching on that lead me to fix the hard drive problem.
also when i try and play music from the empeg it will not let it play anything. the tuner works just fine.
i am kind of at a loss on how to fix the problem short of wiping everything off of it and reloading all of the music. (2 days) ugh.
Stephen
#322873 - 01/06/2009 14:38 Re: play list corrupt [Re: SpeedBump]
I received many of the symptoms you describe when I was using the alpha software. Try going back to 2.0 final instead of the alpha software, manually rebuild the databases, and see if that fixes it.
#322887 - 01/06/2009 18:22 Re: play list corrupt [Re: tfabris]
SpeedBump
going back to 2.0 final has fixed the problems yeah smile
however when i upgrade 3.00-alpha11 the music does not play. the playlists are all there frown
#322889 - 01/06/2009 18:56 Re: play list corrupt [Re: SpeedBump]
Well, it's alpha.. smile
#322896 - 01/06/2009 22:00 Re: play list corrupt [Re: tfabris]
SpeedBump
