Page 2 of 2 < 1 2
#325967 - 11/09/2009 14:50 Re: RAM Issues [Re: tman]
Ah, gotcha. It seemed less likely, but I wasn't certain.
So far I haven't crashed once (*knock knock*) since the BIOS update and the consequent speed drop.
Does anyone have a good link for where I can learn about overclocking my system? Like I said, I have a really good HS/F on my 920 CPU, and I don't want to crank it up to 4GHz or anything, but I've heard that 3.2 is typically safe with the stock HS/F, so I figured it would be very safe with my giant HS/F. Seriously, this thing is huge! As you can see below. Those are two 120mm fans on the sides of the heatsink. Here's the one I have.
#325976 - 11/09/2009 17:01 Re: RAM Issues [Re: Dignan]
Heh...you've spent all this time fighting instability and now you want to overclock it?
PEBCAK.
#325979 - 11/09/2009 18:25 Re: RAM Issues [Re: JBjorgen]
How loud is that setup?
#325980 - 11/09/2009 18:44 Re: RAM Issues [Re: andym]
Thats one huge case!
You overclock an i7 by changing the BCLK setting. The multipler is locked for the cores. The QPI multipler can be set however for 6.4MT/s even on a 920 however. You may need to turn off the built in Intel core boost feature.
#325981 - 11/09/2009 19:08 Re: RAM Issues [Re: tman]
Of course! Now that it's stable, I can do that smile
PEBCAK.
Hey! ...not always wink
Not that loud, actually. The only slightly annoying noise is the high-pitched whine of the hard disk. I can live with it, though. The PC sits on my desk (clearly), and only about 8-12 inches from my left ear, so I would not be happy if it were too loud. The fans on the HS/F are virtually silent.
I'll take that as a compliment! wink I got it as a reaction to the Dell I had before, which left me no room to work inside of. I admit I went a bit...overboard smile If I put an optical drive at the top of the case, I need to find extra long cables to connect it.
Thanks, I'll see if I can figure this out sometime...
Page 2 of 2 < 1 2
