#327327 - 04/11/2009 19:06 What is a 'segfault error'
bodybag
Loc: Southern California
Player crashed while sync was in progress today. Could not sync music. When i unplugged the player and attempted to restart, it gave me 'segfault error' and 'sigkill error' when begining to boot.
Advise.
* EDIT *
Ok, after several reboots I have the player attempting to rebuild it's database. Can someone give me a link to the FAQ where it describes how to force the player to rebuild the database manually instead of using Emplode. I've had to use this a few time on this particular player , so it's not unusuall I'd have to do it again.
Edited by bodybag (04/11/2009 19:18)
Bodybag - So Cal
Not a Whiner any more!!!
#327328 - 04/11/2009 20:17 Re: What is a 'segfault error' [Re: bodybag]
Manual database rebuilds are detailed in the first hit on this FAQ search on "rebuild database manually".
A segmentation fault is a serious software program crash. It often, but not always, indicates some kind of a hardware error on the player.
#327329 - 05/11/2009 12:25 Re: What is a 'segfault error' [Re: bodybag]
I used to get that on one of my players where the header for the hard drive needed to be re-soldered.
#327330 - 05/11/2009 13:49 Re: What is a 'segfault error' [Re: JBjorgen]
bodybag
thank you, i was just going to ask what type of hardware problems would cause this.
I'm going to swap the drives into one of my standby players and try to resolve the database thing first. Then I'll see what I can do to fix the problem on the original.
Bodybag - So Cal
#327331 - 05/11/2009 15:10 Re: What is a 'segfault error' [Re: bodybag]
Database errors are also a common cause of segfaults.
#327332 - 05/11/2009 16:03 Re: What is a 'segfault error' [Re: mlord]
And hard disk trouble, including cable problems and headers that need resoldering, are a common cause of database errors. smile
#327436 - 09/11/2009 21:06 Re: What is a 'segfault error' [Re: tfabris]
bodybag
I'm guessing it was a problem with a loose or partially corroded HD cable. I swapped the drives into a standby player I had, but then put the standby drives into the player that was giving the segfault error. Both players are working properly now and I was able to rebuild the databases by just re-syncing with Emplode.
So at this point unplugging the IDE cable and reconnecting it has at least temporarily fixed the problem.
Bodybag - So Cal
#327440 - 09/11/2009 23:22 Re: What is a 'segfault error' [Re: bodybag]
Sometimes that means it was an issue with the cable, sometimes it means you just wiggled the IDE header and the cracked solder joints are touching for now, but will come undone again later. Carefully check the IDE headers.
