#330162 - 17/02/2010 16:02 When good mice go bad.
SWMBO & I use pretty much identical mice on our machines. Her's has a nice ladybug motif, whereas mine is boring Logitech silver. But mechanically and electrically they are the same Logitech M-UV69a/55a USB mouse.
And oddly, both of them wore out within days of each other. The left mouse buttons got bouncy and jittery, making use of Thunderbird much more difficult.
We like the mice, though, and see no reason to spend money on replacements. So into the junk pile of disused old serial and PS2 mice, for fresh micro-switches:
Description: Guts of one of the two mice.
Description: Microswitches.. all very similar. The middle one is one that had died; the others were culled from older, less used Logitech mice.
#330163 - 17/02/2010 16:07 Re: When good mice go bad. [Re: mlord]
Hmm.. being Logitech mice, I suppose they're under some kind of warranty, but shipping costs would likely kill that deal.
#330164 - 17/02/2010 16:41 Re: When good mice go bad. [Re: mlord]
IMO-
A 'warranty' these days is mostly a 'feel-good' selling angle.
fine print translation: "Sure, we'll warranty that for you! You are responsible for sending it to and from our repair center and a nominal repair fee, but the parts are free! You're better off buying another one of our pieces of crap than trying to fix the one you've got. Or, you could be smarter and just buy something else that's better quality..."
Nice fix on the mice! A neat afternoon project for you, I bet.
I love it when the power to repair something is within your own means. That's what I find frustrating about flash cards that go bad. There's absolutely no way to do anything about it.
*sigh*
#330169 - 17/02/2010 18:02 Re: When good mice go bad. [Re: mlord]
Inside a failed microswitch.
Description: Inside a failed microswitch.
#330172 - 17/02/2010 19:33 Re: When good mice go bad. [Re: Robotic]
Don't forget "include the original receipt (no photocopies)".
I know that I always hang onto every receipt for every device I ever buy and file them away for seven years.
#330186 - 18/02/2010 00:37 Re: When good mice go bad. [Re: wfaulk]
Most warranties are "repair or replace at our option".
Anyone have a notion of where the price break is, that makes an electronic device actually worth repairing.
edit: Repairing by the mfgr.
Edited by gbeer (18/02/2010 00:38)
#330198 - 18/02/2010 08:11 Re: When good mice go bad. [Re: wfaulk]
Even if you did, it wouldn't matter, because most of them are "printed" on that heat-sensitive paper. This means that they're blank after 90 days anyway.
#330199 - 18/02/2010 08:12 Re: When good mice go bad. [Re: gbeer]
They often replace it with a refurbished unit. Then, presumably, they repair/refurbish yours and give it to someone else as a replacement later.
#330267 - 20/02/2010 07:27 Re: When good mice go bad. [Re: Roger]
A bit of contact cleaner might have helped before going to the point of replacing the switches.
#330270 - 20/02/2010 13:23 Re: When good mice go bad. [Re: Shonky]
Yes, but where's the fun in that?
#330272 - 20/02/2010 14:15 Re: When good mice go bad. [Re: Shonky]
I doubt that contact cleaner would have had any effect whatsoever on the non-springy spring that was 75% of the the problem. smile
Mind you, I've kept the original worn switches, and can always "refurbish" those as needed in the future, where "refurbish" means (1) bend the spring back into a spring shape, and (2) remove the oxide from the switch contact.
cheers
