#33199 - 24/06/2001 02:00 Compatibility List V 1.03
crazymelki
Loc: Switzerland
As you know the release V 1.03 is done. It's not possible to make a compatibility of all third party software to V 1.03.
Like:
displayserver V x.xx (link to download)
Picker and Voladj V x.xx (link to download)
Logoediter V x.xx (")
Emptris V x.xx (")
ect....
So everybody knows witch third party software can be used with V 1.03
It's only a suggestion....
cm
crazymelki.com
#33200 - 24/06/2001 03:18 Re: Compatibility List V 1.03 [Re: crazymelki]
EngelenH
Loc: Belgium/Holland
Don't know if it exists yet ... But maybe some place where there are links to these various things as well. Though that would mean some extra work to maintain.
Hans
Mk2 - Blue & Red - 080000431
Mk2 This message will selfdestruct in 5 seconds to prevent reproduction.
#33201 - 24/06/2001 11:00 Re: Compatibility List V 1.03 [Re: crazymelki]
The current version of the Logo editor should still be 100 percent compatible with 1.03. In fact, it'll even be compatible with 1.1 when it comes out.
Picker/Voladj will need some work before they are 1.03 compatible. I am waiting for Richard to release an official 1.03 compatible Voladj, and then I think a new version of Frank's ioctl utility will be needed for it. At that time, I will re-assemble a new picker/voladj zip file and post it.
I can't speak for the other programs.
#33202 - 24/06/2001 11:55 Re: Compatibility List V 1.03 [Re: crazymelki]
fvgestel
Loc: Netherlands
displayserver 1.1 runs fine on 1.03. For remote control funtionality, you can install the ir_trans kernel for v1.03rc1, which also has the irfake hack. http://empeg.dyndns.org/empeg
Frank van Gestel
Frank van Gestel
#33203 - 25/06/2001 05:00 Re: Compatibility List V 1.03 [Re: fvgestel]
Wire
Loc: Jylland, Denmark
Frank,
How come the codes for the Pioneer stuff has changed? Or is that a question to ask the empeg people?
Lars
Lars MkII 40gig 090000598
#33204 - 25/06/2001 06:14 Re: Compatibility List V 1.03 [Re: Wire]
fvgestel
Loc: Netherlands
The empeg people have changed the way the IR-driver works. The state-machines have changed so that they generate different IR-codes.
Frank van Gestel
Frank van Gestel
#33205 - 25/06/2001 09:05 Re: Compatibility List V 1.03 [Re: tfabris]
I believe Richard e-mailed me code that will work in 1.03. When I get to work, I'll double check that it works and get a working kernel posted. Along with a new ioctl program.
Is there any specific help sites that have instructions on getting a crosscompiler to work right? Or are the instructions and toolchain on the developer site still working right for the newer kernels? I do now have a 4 proc machine at work at my disposal with SuSE 7.2 on it. Would be much quicker to compile the kernels on there compaired to on the empeg.
#33206 - 25/06/2001 13:52 Re: Compatibility List V 1.03 [Re: drakino]
rmitz
Loc: Pittsburgh, PA, USA
Can I get a copy of that patch? I was just going to sit down to get the old code working..As to cross compiling, it depends on your system. Under debian, it's as easy as doing an "apt-get install task-cross-arm".
Fly me to the moon...
#33207 - 25/06/2001 15:03 Re: Compatibility List V 1.03 [Re: rmitz]
I need to figure out what I did with the patch, I should have it posted soon.
As for the cross compiling, the main problems I ran into was using the old toolchain. http://www.hulkster.net/empeg/prog.php3 is back up, so I have the toolchain from there. (It was down last time I was trying this)
#33208 - 25/06/2001 21:31 Re: Compatibility List V 1.03 [Re: drakino]
borislav
Loc: Sunnyvale, CA, USA
Be careful with 'make -j' - 2.2 kernels have issues with it. In particular, the 'make dep' step should run without -j.
Borislav
