Page 2 of 2 < 1 2
#334488 - 26/06/2010 02:21 Re: Losing left audio channel [Re: Ross Wellington]
Okay... I have some results...
1) Another capacitor trick by connecting the capacitor from the small blue 100 Ohm resistor array pin 4 or 8 to the INA2137 pin 8 and bypass most of the path. It's very unlikely that both INA2137s could be damaged, but possible I guess.
This seems to have not done anything, for either front or rear.
2) We could also place the capacitor between the INA2137 pins 8 & 9 as a quick test too.
I get some fain, muddy output on the rear, nothing on the front.
3) Another capacitor trick by connecting the capacitor from the small blue 100 Ohm resistor array pin 4 or 8 to the emi filter bottom pad.
Music! This works for both front and rear.
I tried going back to the top pad of the 100 ohm resistor on the front, which also works.
Going to the bottom pad of the 100 ohm resistor produced a loud tone, and then, after removing the cap, continuous audio, but at a reduced volume compared to when using the top pad of the resistor. The same trick with the rear produced a tone, but at much lower volume, and I get intermittent audio, at an even more reduced volume than the left.
Going back to the black tantalum does nothing to improve things.
I broke out the multimeter again, and checked out the top row (farthest from the INA2137 chips) of resistors. Working left to right (as in the photo), I get (1) something alternating between 100k+ and no continuity, (2) 164 ohms, (3) same as #1, (4) 100 ohms.
Something tells me that's not right. frown
#334490 - 26/06/2010 02:40 Re: Losing left audio channel [Re: canuckInOR]
Okay... found a 100 ohm resistor in my parts bin, and used it to bypass #1 and #3, which gives clean audio again. Looks like we've found our culprits! I'll see if I can get one of our engineers to replace them.
Any idea why these would go bad, and if there's anything I can do to prevent it in the future? edit: could this be a result of the bad ground connection on the amp, that you mentioned in your earlier post?
#334645 - 30/06/2010 15:57 Re: Losing left audio channel [Re: canuckInOR]
10 minutes with an iron, and everything works perfectly again.
Thanks to everyone who chimed in, and especially Ross for walking me through the troubleshooting.
#334660 - 30/06/2010 22:12 Re: Losing left audio channel [Re: canuckInOR]
Ross Wellington
Congratulations.
#334668 - 01/07/2010 06:38 Re: Losing left audio channel [Re: canuckInOR]
Glen_L
Loc: Elk Grove, CA
Thanks so much for your detailed and thorough troubleshooting. I've had the same problem for years now and it's driven me crazy, but I just didn't have the know-how to narrow it down. Hopefully Stu will be able to revisit this along with a few other problems that have cropped up.
No longer a stranger, finally a full-fledged member! \:D
Page 2 of 2 < 1 2
